PIMPLE at twoLiquidMixingFoam - p_rgh divergence - slow solving |
July 26, 2019, 02:49 |
Greetings to all!
I am still new to OpenFOAM and actually work on my thesis. I am facing a problem with twoLiquidMixingFoam by using PIMPLE. Ich wanted to try out PIMPLE because I'd like to speed up my simulation an get a higher stability. But at the moment I can't generate a fast an stable PIMPLE solution. I think the problem is the p_rgh which does not converge. So the residualControll can't work an the advantage from the PIMPLE algorythm is not given anymore. So here my concret questions. 1) What can I do when my p_rgh is not sinking with PIMPLE? PISO is working fine, but also slow! 2) How can I speed up the PIMPLE in general? 3) Is there an easy Way to get a higher deltaT than 1E-06? I would be very happy if there is someone who can help me with this. Here are my Options: fvSolution Code:
solvers { "alpha.*" { nAlphaCorr 1; nAlphaSubCycles 1; cAlpha 1; solver smoothSolver; smoother GaussSeidel; tolerance 1e-4; relTol 0; nSweeps 1; } //If not using GAMG for pressure choose PCG Solver. For faster Solving tol:1e-4 and relTol 0.05. p_rgh { solver PCG; preconditioner DIC; tolerance 1e-3; //StartVals:1e-5,StartVals:1e-6 relTol 0.001; //StartVals:0.01,StartVals:0.001 minIter 3; maxIter 100; } p_rghFinal { solver PCG; preconditioner DIC; tolerance 1e-4; //StartVals:1e-5,StartVals:1e-6 relTol 0.000; //StartVals:0.01,StartVals:0.001 minIter 5; //maxIter 100; } //For the Velocity - coupled (increasing stability). U { type coupled; solver PBiCCCG; preconditioner DILU; tolerance (1e-3 1e-3 1e-3); relTol (0.1 0.1 0.1); minIter 3; maxIter 100; } UFinal { type coupled; solver PBiCCCG; preconditioner DILU; tolerance (1e-4 1e-4 1e-4); relTol (0 0 0); minIter 3; maxIter 100; } "(k|omega)" { solver smoothSolver; smoother symGaussSeidel; tolerance 1e-03; relTol 0.1; } "(k|omega)Final" { $U; tolerance 1e-04; relTol 0.1; } } PIMPLE { nNonOrthogonalCorrectors 3; nCorrectors 3; nOuterCorrectors 50; turbOnFinalIterOnly false; residualControl { U 5e-03; p_rgh 5e-03; k 5e-03; omega 5e-03; alpha.adblue 5e-03; ".*" 5e-03; } } relaxationFactors { fields { p 0; pFinal 1; } equations { "(U|k|epsilon)" 0.7; "(U|k|epsilon)Final" 1; } } Code:
ddtSchemes { default Euler; } gradSchemes { default cellLimited Gauss linear 0.5; grad(U) cellLimited Gauss linear 0.5; } divSchemes { default none; div(rhoPhi,U) Gauss upwind; div(phi,alpha) Gauss vanLeer; div(phi,k) Gauss upwind; div(phi,omega) Gauss upwind; div(phi,e) Gauss upwind; div((nuEff*dev2(T(grad(U))))) Gauss linear; div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear; } /* divSchemes { default none; div(rhoPhi,U) Gauss linearUpwind grad(U); div(phi,alpha) Gauss vanLeer; div(rhoPhi,U) Gauss upwind; //linear; div(phi,alpha) Gauss vanLeer; div(phi,k) Gauss upwind; //limitedLinear 1; div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear; }*/ laplacianSchemes { default Gauss linear limited 0; //Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default limited 0; } wallDist { method meshWave; } Code:
application twoLiquidMixingFoam; startFrom latestTime; startTime 0; stopAt endTime; //endTime; writeNow; endTime 20; deltaT 0.0000000005; writeControl adjustableRunTime; writeInterval 0.00005; purgeWrite 0; writeFormat binary; writePrecision 7; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable yes; adjustTimeStep on; maxCo 0.5; maxAlphaCo 0.5; maxDeltaT 1; functions { #includeFunc residuals #includeFunc pressureDifferencePatch } If you need more information to help me let me know it.
Greetings Philipp Conen |
August 1, 2019, 20:20 |
Gavin Ridley
Rep Power: 7 |
Your relaxation factor for p appears to be zero. Do you know why under-relaxation is desired? You should set that factor to be around 0.2-0.5 or 0.5-1 depending on whether you use vanilla PIMPLE or consistent PIMPLE respectively. Could you try changing that relaxation factor to say, 0.2? By the way, a rule of thumb to get decent convergence is relax_U+relax_p=1. I'm not sure why mathematically this works well, but it seems to. |
August 5, 2019, 09:10 |
Dear Gavin,
thank you for reply to my question. I understood underrelaxtion as a function of stability and calculation speed. So I used 0 for a highly stable calculation. I also used 0.1/0.3 and 1 as underrelaxtionfactor. With 1 the speed was high an p decreased. But p decreased very very slow an only up to 0.98. So this lead to no win in this case. But I try again and save your thumb rule in my head. Thank you really much. I subscribe back in some days.
August 6, 2019, 01:26 |
Dear Gavin,
I let the calculation run over night. A URF = 0.2 doesnt change my Problem of slow and unstable calculation. Code:
PIMPLE: Iteration 50 DILUPBiCG: Solving for Ux, Initial residual = 0.001560208, Final residual = 1.034981e-13, No Iterations 2 DILUPBiCG: Solving for Uy, Initial residual = 0.001074642, Final residual = 9.620375e-14, No Iterations 2 DILUPBiCG: Solving for Uz, Initial residual = 0.001472009, Final residual = 4.359329e-14, No Iterations 2 DICPCG: Solving for p_rgh, Initial residual = 0.2390144, Final residual = 0.01121177, No Iterations 175 DICPCG: Solving for p_rgh, Initial residual = 0.01796031, Final residual = 0.0008353669, No Iterations 9 DICPCG: Solving for p_rgh, Initial residual = 0.003443909, Final residual = 0.0009118244, No Iterations 1 DICPCG: Solving for p_rgh, Initial residual = 0.001411461, Final residual = 0.0007466737, No Iterations 1 time step continuity errors : sum local = 2.034207e-10, global = -8.159711e-12, cumulative = -1.751579e-06 DICPCG: Solving for p_rgh, Initial residual = 0.001202807, Final residual = 0.0006922544, No Iterations 1 DICPCG: Solving for p_rgh, Initial residual = 0.0008900349, Final residual = 0.0008900349, No Iterations 0 DICPCG: Solving for p_rgh, Initial residual = 0.0008900349, Final residual = 0.0008900349, No Iterations 0 DICPCG: Solving for p_rgh, Initial residual = 0.0008900349, Final residual = 0.0008900349, No Iterations 0 time step continuity errors : sum local = 2.425377e-10, global = -1.069591e-11, cumulative = -1.75159e-06 DICPCG: Solving for p_rgh, Initial residual = 0.0008933383, Final residual = 0.0008933383, No Iterations 0 DICPCG: Solving for p_rgh, Initial residual = 0.0008933383, Final residual = 0.0008933383, No Iterations 0 DICPCG: Solving for p_rgh, Initial residual = 0.0008933383, Final residual = 0.0008933383, No Iterations 0 DICPCG: Solving for p_rgh, Initial residual = 0.0008933383, Final residual = 9.720371e-05, No Iterations 70 time step continuity errors : sum local = 2.648834e-11, global = -6.587787e-12, cumulative = -1.751597e-06 DILUPBiCG: Solving for omega, Initial residual = 2.603568e-07, Final residual = 2.998042e-10, No Iterations 1 DILUPBiCG: Solving for k, Initial residual = 2.077727e-08, Final residual = 5.145305e-12, No Iterations 1 ExecutionTime = 48113.92 s ClockTime = 50635 s fieldValueDelta pressureDifferencePatch write: subtract(p) = 9.150395e+33 Courant Number mean: 3.484067e-07 max: 1.177855 Interface Courant Number mean: 0 max: 0 deltaT = 3.205731e-22 Time = 7.30141e-05 Code:
residualControl { U 5e-06; p_rgh 5e-03; k 5e-06; omega 5e-06; alpha.adblue 5e-06; ".*" 5e-06; }
August 6, 2019, 12:14 |
Gavin Ridley
Rep Power: 7 |
OK, I see your problem. It's OK to have nonlinear tolerances set around 1e-3 (what's in the convergence control part of fvSolution), but your linear tolerances have to be way below that. Look at your p_rgh linear solve section (the part where you can select PCG or GAMG). Your tolerance is 1e-3. This is way too high. This needs to be 1e-8, or even 1e-10 if you want to get linear nonlinear residual around 1e-7. In my experience, depending on the mesh, the linear residuals should be about three orders of magnitude smaller than the nonlinear residuals.
By the way, you may want to post the results of checkMesh, since that can SERIOUSLY impact solution convergence. (Especially if dropping your linear convergence criterion still doesn't help) |
August 16, 2019, 08:18 |
Dear Gavin,
sorry for my late reply, but thanks for your answer! I tought I close calculations with PIMPLE, but I would like to try out your ideas. So here are my new fvSolutions: Code:
solvers { "alpha.*" { nAlphaCorr 1; nAlphaSubCycles 1; cAlpha 1; solver smoothSolver; smoother GaussSeidel; tolerance 1e-8; relTol 0; nSweeps 1; } //If not using GAMG for pressure choose PCG Solver. For faster Solving tol:1e-4 and relTol 0.05. p_rgh { solver PCG; preconditioner DIC; tolerance 1e-8; //StartVals:1e-5,StartVals:1e-6 relTol 0.001; //StartVals:0.01,StartVals:0.001 } p_rghFinal { solver PCG; preconditioner DIC; tolerance 1e-8; //StartVals:1e-5,StartVals:1e-6 relTol 0.000; //StartVals:0.01,StartVals:0.001 } //For the Velocity - coupled (increasing stability). U { type coupled; solver PBiCCCG; preconditioner DILU; tolerance (1e-8 1e-8 1e-8); relTol (0.1 0.1 0.1); } UFinal { type coupled; solver PBiCCCG; preconditioner DILU; tolerance (1e-8 1e-8 1e-8); relTol (0 0 0); } "(k|omega)" { solver smoothSolver; smoother symGaussSeidel; tolerance 1e-08; relTol 0.1; } "(k|omega)Final" { $U; tolerance 1e-08; relTol 0.1; } } PIMPLE { nNonOrthogonalCorrectors 1; nCorrectors 3; nOuterCorrectors 20; turbOnFinalIterOnly false; residualControl { U 5e-03; p_rgh 5e-03; k 5e-03; omega 5e-03; alpha.adblue 5e-03; ".*" 5e-03; } } relaxationFactors { fields { p 0.2; pFinal 1; } equations { "(U|k|epsilon)" 0.2; "(U|k|epsilon)Final" 1; } } Code:
Mesh stats points: 1720306 faces: 4913997 internal faces: 4744352 cells: 1604851 faces per cell: 6.018222 boundary patches: 6 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 1501520 prisms: 45802 wedges: 0 pyramids: 0 tet wedges: 216 tetrahedra: 0 polyhedra: 57313 Breakdown of polyhedra by number of faces: faces number of cells 4 13322 5 11049 6 11441 7 13 8 132 9 10444 10 3 11 101 12 6080 13 4 14 44 15 3991 17 3 18 686 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology fans 71745 86100 ok (non-closed singly connected) inlet_adblue 26 39 ok (non-closed singly connected) inlet_exhgas 4116 4347 ok (non-closed singly connected) outlet 4277 4573 ok (non-closed singly connected) sheet 3315 4329 ok (non-closed singly connected) wall 86166 90014 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (-0.15985 -0.15985 -1.687) (0.15985 0.15985 0.5) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (2.59768e-16 -2.335864e-16 1.8714e-16) OK. Max cell openness = 3.274699e-16 OK. Max aspect ratio = 9.2792 OK. Minimum face area = 9.54776e-08. Maximum face area = 3.987172e-05. Face area magnitudes OK. Min volume = 1.279944e-09. Max volume = 1.729588e-07. Total volume = 0.1752509. Cell volumes OK. Mesh non-orthogonality Max: 58.76045 average: 6.463263 Non-orthogonality check OK. Face pyramids OK. Max skewness = 3.728606 OK. Coupled point location match (average 0) OK. Mesh OK. Many thanks!
August 16, 2019, 08:50 |
Dear Gavin,
as I can see the residualControl still does not work. Here is my log of the solver: Code:
ExecutionTime = 2664.28 s ClockTime = 2706 s ... PIMPLE: Iteration 19 DILUPBiCCCG: Solving for Ux, Initial residual = 4.711859e-05, Final residual = 3.277177e-07, No Iterations (1 1 1) DILUPBiCCCG: Solving for Uy, Initial residual = 4.83186e-05, Final residual = 3.355973e-07, No Iterations (1 1 1) DILUPBiCCCG: Solving for Uz, Initial residual = 0.0001946199, Final residual = 1.360958e-06, No Iterations (1 1 1) DICPCG: Solving for p_rgh, Initial residual = 5.80858e-05, Final residual = 9.92059e-08, No Iterations 343 DICPCG: Solving for p_rgh, Initial residual = 8.136671e-06, Final residual = 9.744144e-08, No Iterations 8 time step continuity errors : sum local = 4.032735e-11, global = -8.69936e-13, cumulative = 9.328705e-07 DICPCG: Solving for p_rgh, Initial residual = 1.862189e-05, Final residual = 9.564784e-08, No Iterations 337 DICPCG: Solving for p_rgh, Initial residual = 5.483464e-06, Final residual = 8.795988e-08, No Iterations 7 time step continuity errors : sum local = 3.640707e-11, global = 9.436154e-13, cumulative = 9.328715e-07 DICPCG: Solving for p_rgh, Initial residual = 2.539553e-06, Final residual = 8.357301e-08, No Iterations 5 DICPCG: Solving for p_rgh, Initial residual = 1.733912e-06, Final residual = 8.640904e-08, No Iterations 3 time step continuity errors : sum local = 3.576518e-11, global = 1.191871e-12, cumulative = 9.328727e-07 smoothSolver: Solving for omega, Initial residual = 5.109694e-07, Final residual = 1.162782e-09, No Iterations 1 smoothSolver: Solving for k, Initial residual = 2.773506e-05, Final residual = 4.273729e-09, No Iterations 1 PIMPLE: Iteration 20 DILUPBiCCCG: Solving for Ux, Initial residual = 0.0002354442, Final residual = 1.899741e-12, No Iterations (4 4 4) DILUPBiCCCG: Solving for Uy, Initial residual = 0.0002425355, Final residual = 1.873183e-12, No Iterations (4 4 4) DILUPBiCCCG: Solving for Uz, Initial residual = 0.0008617877, Final residual = 5.906528e-12, No Iterations (4 4 4) DICPCG: Solving for p_rgh, Initial residual = 0.153554, Final residual = 0.0001499837, No Iterations 350 DICPCG: Solving for p_rgh, Initial residual = 0.07839407, Final residual = 7.580352e-05, No Iterations 333 time step continuity errors : sum local = 1.608803e-08, global = 1.087189e-10, cumulative = 9.329814e-07 DICPCG: Solving for p_rgh, Initial residual = 0.04337104, Final residual = 4.208997e-05, No Iterations 348 DICPCG: Solving for p_rgh, Initial residual = 0.007981723, Final residual = 7.981384e-06, No Iterations 342 time step continuity errors : sum local = 1.83341e-09, global = 1.948213e-13, cumulative = 9.329816e-07 DICPCG: Solving for p_rgh, Initial residual = 0.004048247, Final residual = 3.857835e-06, No Iterations 350 DICPCG: Solving for p_rgh, Initial residual = 0.001300558, Final residual = 9.93526e-08, No Iterations 371 time step continuity errors : sum local = 2.305758e-11, global = 8.214406e-14, cumulative = 9.329817e-07 DILUPBiCCCG: Solving for omega, Initial residual = 5.757286e-05, Final residual = 2.727271e-07, No Iterations 1 DILUPBiCCCG: Solving for k, Initial residual = 0.0004608179, Final residual = 1.510417e-06, No Iterations 1 ExecutionTime = 2664.28 s ClockTime = 2706 s By the way I would like to ask what you mean with linaer and non-linear.
August 16, 2019, 08:59 |
geometry
ramona
Rep Power: 7 |
Hello
could you plz somebody help me how can I choose inlet and outlet for geometry in openfoam? |
August 16, 2019, 09:03 |
openfoam
#9 |
ramona
Rep Power: 7 |
hello every one
could you please tell me which class is good for openfoam I am new in this field and I want to learn openfoam and get certificate best regards ____________ Ramona |
August 16, 2019, 09:08 |
#10 |
Dear Ramona,
I think this Thread is not the best place for this question. But I allready answered to your inlet/outlet question. The secound question I do not understand. What do you mean with class?
August 16, 2019, 11:03 |
#11 |
Gavin Ridley
Rep Power: 7 |
As for linear and non-linear, maybe that isn’t the exactly correct term to use. Inner and outer pressure-velocity coupling iterations would be more correct to say, since the pressure-velocity coupled problem is a purely linear one. If you want more details on that coupling, I recommend checking out either Ferziger and Perric’s book or alternatively Patankar and Spalding’s if you want something more mathematically mild.
So, a few things. In your relaxation terms, you have both field and equation relaxation. Your equation relaxation can usually be 1, since this is usually not the unstable part of the problem. Field relaxation is what you need. You should see a pretty solid speed-up when you remove equation relaxation. Of course, if you find that this makes your solve crash, you should add back some equation relaxation. Stabilization of the linear solve can usually be done with modest under-relaxation factors of .7 or .9, usually not low like .2. I see that you’re using the the coupled velocity solver. I’ve not messed with that; it does the pressure-velocity coupling in a wholly different way from the usual CFD solve. This may have to do with why stuff here is working different than what I’m used to (segregated p/U coupling). Another possibility could be your nonorthogonal terms making an issue. Does your fvSchemes use a corrected laplacian scheme? If so, you may also want to consider under-relaxing the nonorthogonal correction term, which is done in the fvSchemes file. You may also want to have two nonorthogonal corrections rather than just one, given that your mesh nonorthogonality is around 50. |
August 16, 2019, 11:10 |
thank you
#12 |
ramona
Rep Power: 7 |
Dear Pconen
I am very new with openfoam I used to use sim scale and for openfoam I want to learn step by step and I am looking for good source for start to learn openfoam thank you I saw your answered for inlet and outlet thanks |
August 19, 2019, 03:15 |
#13 |
Dear Gavin,
thank you very much! At the moment I have hard work with my thesis. But I will try your ideas as soon as possible. Thanks!
divergence, pimple, p_rgh, slow, twoliquidmixingfoam |
chtMultiRegionSimpleFoam: maximum number of iterations excedeed. | Nkl | OpenFOAM Running, Solving & CFD | 19 | October 10, 2019 02:42 |
decompose dependent solution | arionfard | OpenFOAM | 3 | December 10, 2018 09:36 |
Adapt Fluent Mesh to weirOverflow tutorial | WaterHammer1985 | OpenFOAM Running, Solving & CFD | 2 | July 5, 2018 02:37 |
Segmentation fault when using reactingFOAM for Fluids | Tommy Floessner | OpenFOAM Running, Solving & CFD | 4 | April 22, 2018 12:30 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
