simpleFoam crashing when calculating p after few timesteps (k-Epsilon model included)
Like Tree1Likes
  • 1 Post By Carlo_P
Old   July 12, 2019, 16:12
Post simpleFoam crashing when calculating p after few timesteps (k-Epsilon model included)
Santi Parera
Kalabagh is on a distinguished road
Hi Foamers,
I'm relatively new in OpenFoam, and I'm getting started with turbulence modelling.
My simulation consists on a stirred tank in where there is a vertical centered mixer. From the simulation I'm interested on the moments and forces for improving the tank design.
But I feel the turbulence produced by the mixed is not neglectable.
As I say in the title, after having improved the mesh, the solver keeps crashing at 6 to 9 timestep.
I just want to know what is happening and where I have to focus.
Here is the log:
Time = 9
smoothSolver: Solving for Ux, Initial residual = 5.05182e-20, Final residual = 5.05182e-20, No Iterations 0
smoothSolver: Solving for Uy, Initial residual = 1.54245e-17, Final residual = 1.54245e-17, No Iterations 0
smoothSolver: Solving for Uz, Initial residual = 4.36724e-21, Final residual = 4.36724e-21, No Iterations 0
GAMG: Solving for p, Initial residual = 4.53748e-08, Final residual = 4.53748e-08, No Iterations 0
time step continuity errors : sum local = 1.38557e+107, global = -2.33602e+91, cumulative = -2.33602e+91
#0 Foam::errorprintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam::multiply(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
#4 Foam::tmp<Foam:dimensionedField<double, Foam::volMesh> > Foamoperator*<Foam::volMesh>(Foam:dimensionedField <double, Foam::volMesh> const&, Foam::tmp<Foam:dimensionedField<double, Foam::volMesh> > const&) at ??:?
#5 Foam::RASModels::kEpsilon<Foam::IncompressibleTurb ulenceModel<Foam::transportModel> >::correct() at ??:?
#6 ? in "/opt/openfoam5/platforms/linux64GccDPInt32Opt/bin/simpleFoam"
#7 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#8 ? in "/opt/openfoam5/platforms/linux64GccDPInt32Opt/bin/simpleFoam"
The number of iterations is low because I have reduced all the tolerances and relative tolerances in the fvSolution dict.
Thanks.
Kalabagh is offline   Reply With Quote
Old   July 15, 2019, 09:58
Carlo_P
Carlo_P is on a distinguished road
First of all, try to us alwyas minIteration at least equal to 3.
Then, try to run laminar.
Then, change the relaxation factor at 0.5 for all.
Then, redoo the mesh.
Did you run checkMesh?
These are normal suggestions. If these don't solve the problem, try to attach the folder 0 and at least fvSchemes file.
Thanks,
Cheeres
Carlo
hogsonik likes this.
Carlo_P is offline   Reply With Quote
Old   July 18, 2019, 15:49
Santi Parera
I have tried laminar and it converges in 51 iterations "with permissible residual control".
I've tried with rel facts all to 0.5.
You can find attached a picture of my mesh. And also the log of the checkMesh. The mesh crashes, as this can bethe reason of not the best results in laminar, I don't think it to be the main problem.
You can also find attached U, p, nut, k, epsilon and fvSchemes. Maybe there is a problem with the configuration of turbulent parameters or with the divSchemes.
Thanks for your help.
checkMesh.txt
U:
| \\ / O peration | Version: 5 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class volVectorField;
location "0";
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
//- Set patchGroups for constraint patches
inlet
type noSlip;
outlet
type noSlip;
empty
type noSlip;
TURBINA
type noSlip;
REACTOR
type noSlip;
p:
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
inlet
type zeroGradient;
outlet
type zeroGradient;
empty
type zeroGradient;
TURBINA
type zeroGradient;
REACTOR
type zeroGradient;
nut:
FoamFile
version 2.0;
format ascii;
object nut;
dimensions [0 2 -1 0 0 0 0];
boundaryField
inlet
type calculated;
value uniform 0;
outlet
type calculated;
value uniform 0;
empty
type zeroGradient;
TURBINA
type nutkWallFunction;
value uniform 0;
REACTOR
value uniform 0;
k:
FoamFile
version 2.0;
format ascii;
object k;
internalField uniform 0.227;
boundaryField
inlet
type fixedValue;
value uniform 0.227;
//no hi ha necessitat, no pertany a la malla final
outlet
type zeroGradient;
empty
type zeroGradient;
TURBINA
type kqRWallFunction;
REACTOR
epsilon:
FoamFile
version 2.0;
format ascii;
object epsilon;
dimensions [0 2 -3 0 0 0 0];
internalField uniform 0.376;
boundaryField
inlet
type fixedValue;
value uniform 0.376;
// no hi ha necessitat, no pertany a la malla final
outlet
type zeroGradient;
empty
type zeroGradient;
TURBINA
type epsilonWallFunction;
REACTOR
crashing, turbulence kinetic enregy
Difficulty in calculating angular velocity of Savonius turbine simulation alfaruk CFX 14 March 17, 2017 07:08
K epsilon Model CFD22 Main CFD Forum 2 July 21, 2015 15:27
Jump in epsilon values near the wall : low re k-epsilon model malaboss OpenFOAM Verification & Validation 1 February 1, 2013 17:36
Problem with SimpleFoam for a solution around an OneraM6 wing gara1988 OpenFOAM Running, Solving & CFD 3 November 13, 2012 06:47
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 18:27
