Parameter Study
Like Tree1Likes
  • 1 Post By clapointe
Old   July 10, 2019, 06:52
Default Parameter Study
psapercace is on a distinguished road
I'm new to Openfoam and wondering how to change parameters automatically after a successful run. I have a pipe with constant inlet velocity which is simulated with SimpleFoam (in laminar mode). I want to increase the Reynolds number (by changing the inlet velocity or the kinematic viscosity) after each successful run with the solver and then rerun the solver and I want to find an automatic way to do that. This is easily done in COMSOL using a parametric sweep, but I'm wondering how it can be done in Openfoam.
psapercace is offline   Reply With Quote
Old   July 10, 2019, 16:16
clapointe is on a distinguished road
This can be done easily using a bash script. There are many ways to accomplish this, but one possible way in pesudo code :
for i in ...
cp baseCase case_$i
cd case_$i
sed 0/U (0 $i 0)
Allrun
cd ..
Where you have a (clean) case, call it baseCase, that gets copied some number of times. You then enter the new case directory, use sed to edit a file (in this case 0/U), and then the case can be run using an Allrun script like those used in foam tutorials. So looking into for loops and sed should put you on the right path.
Caelan
Lennart.H likes this.
clapointe is offline   Reply With Quote
Old   July 17, 2019, 12:17
for i in ...
cp baseCase case_$i
cd case_$i
sed 0/U (0 $i 0)
Allrun
cd ..
Caelan
It worked perfectly. Thanks.
Old   November 13, 2023, 07:18
Default Use caseFoam/PyFoam
David von Rüden
openFo is on a distinguished road
To add to this for future searchers. I would recommend using a tool like PyFoam or better caseFoam (https://github.com/DLR-RY/caseFoam). The latter is designed to do parameter studies. I can highly recommend it.
openFo is offline   Reply With Quote
[Workbench] odd problem of updating parameter study mesh funkvps ANSYS Meshing & Geometry 0 August 17, 2017 12:51
Results from parameter study -mAx- FloEFD, FloWorks & FloTHERM 4 March 4, 2015 05:18
Parametric study and time dependent parameter monitoring Crustulu FLUENT 1 April 12, 2013 06:54
Average of Expressions in Transient Run for Parameter Study BigPapi34 CFX 1 August 7, 2012 06:34
Force can not converge colopolo CFX 13 October 4, 2011 23:03
