July 5, 2019, 10:09 |
FSI foam-extend using meshes from ANSA
George Linaker
Rep Power: 8 |
Dear all,
Was wondering if anyone has encountered this problem I've been stuck on for a while now. I successfully ran the 3dTube example in foam-extend extend-bazaar, but I have then tried using the fsiFoam solver for an idealised bifurcation Unfortunately I get floating point exception errors. I have generated the meshes for the fluid and solid domain in ANSA (attachment). Having thought my mesh was the cause I've tried to replicate the mesh in the 3dTube example in ANSA, but this case crashes after a few timesteps with floating point exception errors also. Am I being naive to the requirements of the case set-up for the solver? Any help greatly appreciated Best wishes, George |
fluid-structure, foam-extend 4.0, fsi |
[blockMesh] Errors during blockMesh meshing | Madeleine P. Vincent | OpenFOAM Meshing & Mesh Conversion | 51 | May 30, 2016 10:51 |
decomposePar is missing a library | whk1992 | OpenFOAM Pre-Processing | 8 | March 7, 2015 07:53 |
how to extend FSI 2D codes to 3D, need advises | abouziar | Main CFD Forum | 1 | May 30, 2008 04:08 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 06:51 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
