June 26, 2019, 04:49 |
Linear solvers in OpenFOAM
Rahul
Rep Power: 8 |
Hey guys, I am doing a project on OpenFOAM simulating external flow over an airfoil. I am confused with various linear solvers available to solve the problem in the fvSoultion file.
Can anyone explain me the difference between GAMG and PCG solver for pressure and when is each one of them used? |
June 26, 2019, 12:34 |
Santiago Lopez Castano
Rep Power: 16 |
Geometric Agglomerated MultiGrid
Parallel Conjugate Gradient easy enough to look on the interwebs |
June 27, 2019, 03:45 |
Anton Kidess
Rep Power: 30 |
AFAIK -> PCG = Preconditioned Conjugate Gradient.
*On twitter @akidTwit *Spend as much time formulating your questions as you expect people to spend on their answer. |
June 27, 2019, 04:11 |
Rep Power: 16 |
June 30, 2019, 06:22 |
Ruiyan Chen
Rep Power: 10 |
Interesting topic! You can check out the following link to get some insights.
https://www.openfoam.com/documentati...e-solvers.html Note there are GAMG preconditioners for PCG solvers, which is NOT the GAMG solver(belongs to the Multigrid solver catagory). By the way I remember some people stating that PCG solvers are better than GAMG for parallel computing. Is this true? What is the reason behind it? |
July 2, 2019, 04:04 |
Anton Kidess
Rep Power: 30 |
More grids means more communication overhead. Not that important for small parallel simulations, but can become important for massive sims.
July 2, 2019, 23:37 |
Ruiyan Chen
Rep Power: 10 |
Thanks for the explanation!
Ruiyan |
gamg, linear solver, pcg |
ofgpu v1.1: GPU Linear Solvers for OpenFOAM Released | gocarts | OpenFOAM Announcements from Other Sources | 4 | March 8, 2019 12:21 |
OpenFOAM Training Jan-Apr 2017, Virtual, London, Houston, Berlin | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | September 21, 2016 12:50 |
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | September 14, 2016 04:19 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 06:36 |
Water pump OpenFOAM 15 ANSYS CFX 110 comparation | waynezw0618 | OpenFOAM Running, Solving & CFD | 39 | March 5, 2009 13:57 |
