Problem with creating R file for SSG turbulence model
Like Tree4Likes
  • 2 Post By Khozaei4000
  • 2 Post By Mizar
Old   June 26, 2019, 00:50
Default Problem with creating R file for SSG turbulence model
Mohammad Hossein Khozaei
Khozaei4000 is on a distinguished road
Hi guys
I am a bit new to OpenFoam, and I have problem to create R file to start simpleFoam simulation with SSG turbulence model. I have searched all forums, but it has not helped me.
My case is a simple pipe including a venturi-tube. Boundary conditions for inlet and outlet are velocity and pressure, respectively.
I finished simulation for my case with RNGkEpsilon model and it is converged well. Now, I intend to use the results of RNGkEpsilon model as initial values to start simulation with SSG model.
I understood that I have to use "simpleFoam –postProcess –func R" to create the missing R file. I did it several times, but it doesn't work. Actually I don't see any error in the terminal, and I guess the file is created properly. However, I couldn't find the file "turbulenceProperties:R" anywhere in my working directory, nor anywhere on my pc!
I would appreciate it if anybody can help me.
Thanks.
|  \\    /   O peration     | Version:  v1812                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      turbulenceProperties;
simulationType RAS;
RAS
    RASModel        kEpsilon;
    turbulence      on;
    printCoeffs     on;
controlDict:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
application     simpleFoam;
startFrom		latestTime;
stopAt          endTime;
endTime         2000;
deltaT          1;
writeControl    timeStep;
writeInterval   100;
purgeWrite      0;
writeFormat     ascii;
writePrecision  6;
writeCompression off;
timeFormat      general;
timePrecision   6;
runTimeModifiable true;
What I see in the terminal after using "simpleFoam –postProcess –func R" command:
Build  : v1812 OPENFOAM=1812
Arch   : "LSB;label=32;scalar=64"
Exec   : simpleFoam -postProcess -func R
Date   : Jun 26 2019
Time   : 03:05:41
Host   : default
PID    : 1141
I/O    : uncollated
Case   : /home/ofuser/workingDir/.........
nProcs : 1
trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE).
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 10
SIMPLE: convergence criteria
    field p      tolerance 0.01
    field U      tolerance 0.001
    field "(k|epsilon|omega|f|v2|R)"     tolerance 0.001
turbulenceFields R: storing fields:
Time = 10
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type RAS
Selecting RAS turbulence model kEpsilon
RAS
    RASModel        kEpsilon;
    turbulence      on;
    printCoeffs     on;
    Cmu             0.09;
    C1              1.44;
    C2              1.92;
    C3              0;
    sigmak          1;
    sigmaEps        1.3;
No MRF models present
No finite volume options present
    functionObjects::turbulenceFields R writing field: turbulenceProperties:R
End
ABHI8171 and Milad_ab like this.
Khozaei4000 is offline   Reply With Quote
Old   February 6, 2021, 10:03
Milad
Milad_ab is on a distinguished road
Dear Mohammad
I have the same problem as you. Have you solved it?
If yes, could you please inform me how can I solve it?
Thank you very much
Milad
Milad_ab is offline   Reply With Quote
Old   February 6, 2021, 12:05
Domenico Lahaye
dlahaye is on a distinguished road
Possibly below helps
simpleFoam tutorial PitzDaily using Reynolds stress tensor (LRR RASModel)
dlahaye is offline   Reply With Quote
Old   April 26, 2022, 17:02
Yushu
Mizar is on a distinguished road
I just found that '-postProcess -func R -latestTime' will only calculate R, instead of running the solver while calculating R. Therefore, I ran my solver first to complete the simulation, after that I ran 'mySolver -postProcess -func R -latestTime' to get R.
I previously thought if I added '-postProcess -func R -latestTime', the solver would run and also compute R, so I only executed 'mySolver', but this was actually telling the code to compute R from nothing! That's why it 'END' without any error message.
dlahaye and Dong Yan like this.
Mizar is offline   Reply With Quote
[swak4Foam] Installation Problem with OF 6 version Aurel OpenFOAM Community Contributions 14 November 18, 2020 17:18
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 22:53
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 towanda OpenFOAM Community Contributions 6 September 5, 2015 22:03
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 12:46
