Rep Power: 7 ![]() |
Hello Everyone,
I am simulating natural convection in a 2-D square cavity with hot wall at bottom and all other walls at ambient temperatures. I am using buoyantBoussinessqPimpleFoam My problem is that I want to set x-velocity component to be 0 at the side walls, whereas, I want to set a Neumann condition for the y-velocity at the side walls. Kindly please help me how to achieve this. Thank You. Last edited by Pavithra; June 11, 2019 at 02:57. Reason: A small change |
Maybe the directionMixed boundary condition could be helpful? Note that I did not use it myself, but it seems like you can specify Dirichlet and Neumann boundary conditions for each component using the valueFraction. Regards, Tom |
#3 | |
Thank you so much for your kind help. Yes, I have achieved the required boundary condition using directioMixed boundary type. Thank You. With Thanks, Pavithra. |
boundary condition u, buoyant boussinesq, openfoam |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field | xiexing | CFX | 3 | March 29, 2017 10:00 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
