How to stop a simulation with a physical criterion (other than time) ?
Like Tree3Likes
  • 3 Post By oxadampf
Old   May 23, 2019, 06:03
Default How to stop a simulation with a physical criterion (other than time) ?
Mat
Mat_fr is on a distinguished road
Hi foamers,
Everything's in the title.
I was wondering if there's a way to stop an openfoam simulation with a physical criterion (e.g. average pressure on a wall exceeding a threshold), using the dictionaries. And then to write the results, at this last time step.
Otherwise, I suppose I will have to modify the solver.
Thanks,
Mat
Mat_fr is offline   Reply With Quote
Old   November 7, 2019, 03:55
Benedikt Scholz
oxadampf is on a distinguished road
Hi Mat,
were you able to find a solution to your problem?
Thanks,
Ben
oxadampf is offline   Reply With Quote
Old   November 7, 2019, 04:55
Mat
No I didn't.
For the moment, I am recording some physical values and looking for which time my physical criterion is achieved. Then if I need I start again the simulation at a previous saved time step untill the criterion time I just found.
It's a bit anoying and takes a bit of time, but it's okay.
Good luck,
Mat
Old   November 7, 2019, 05:34
Benedikt Scholz
I think I found a solution. Writing a coded functionObject to the controlDict file can help. Something like this:
T__max__sample
enabled true;
type coded;
functionObjectLibs ("libutilityFunctionObjects.so");
region sample00;
redirectType T__max__sample;
writeControl timeStep;
writeInterval 1;
log true;
codeExecute
const volScalarField& T = mesh().lookupObject<volScalarField>("T");
if ( max(T).value() < 270 )
bool result=const_cast<Time&>(mesh().time()).writeNow() ;
FatalErrorIn("Stopped")
<< "Bla" << endl
<< exit(FatalError);
It terminates the simulation, if the max temperature in the region called "sample00" falls below 270 with a fatal error message (I know not pretty, but functional). Then, it writes the last timeStep.
This link helped me a lot:
Mixing #codeStream with coded-function-object
I hope this will help you.
Ben
Mat_fr, acgnipper and ancolli like this.
Old   November 7, 2019, 08:00
Mat
That's grand! Thanks for your time, Ben.
I haven't made it to the step of conded function objetc yet, and I should.
Regards,
Mat
[General] Extracting ParaView Data into Python Arrays Jeffzda ParaView 30 November 6, 2023 22:00
Time Step Continuity Errors simpleFoam Dorian1504 OpenFOAM Running, Solving & CFD 1 October 9, 2022 10:23
Unexpected deltaT decrease in pimpleFoam simulation robyTKD OpenFOAM Running, Solving & CFD 9 June 27, 2014 07:52
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 08:47
pisoFoam with k-epsilon turb blows up - Some questions Heroic OpenFOAM Running, Solving & CFD 26 December 17, 2012 04:34
