Hojatollah Gholami
the results log was
Current fsi relative residual norm: 0.237396
Alternative fsi residual: 0.000451543
Time = 0.0904, iteration: 53
Maximal accumulated displacement of interface points: 0.00287293
GAMG: Solving for cellMotionUx, Initial residual = 0.284575, Final residual = 8.25916e-07, No Iterations 9
GAMG: Solving for cellMotionUy, Initial residual = 0.00633877, Final residual = 8.60538e-07, No Iterations 4
GAMG: Solving for cellMotionUx, Initial residual = 0.00251555, Final residual = 4.99283e-07, No Iterations 5
GAMG: Solving for cellMotionUy, Initial residual = 9.75429e-05, Final residual = 4.5803e-07, No Iterations 2
GAMG: Solving for cellMotionUx, Initial residual = 0.000216841, Final residual = 7.5024e-07, No Iterations 3
GAMG: Solving for cellMotionUy, Initial residual = 4.78647e-06, Final residual = 9.52308e-08, No Iterations 2
GAMG: Solving for cellMotionUx, Initial residual = 2.45077e-05, Final residual = 2.78931e-07, No Iterations 2
GAMG: Solving for cellMotionUy, Initial residual = 5.75566e-07, Final residual = 2.52936e-08, No Iterations 2
GAMG: Solving for cellMotionUx, Initial residual = 2.58656e-06, Final residual = 6.38896e-08, No Iterations 2
GAMG: Solving for cellMotionUy, Initial residual = 8.15413e-08, Final residual = 6.81777e-09, No Iterations 2
Evolving fluid solver: simpleFluid
Courant Number mean: 0.00509794 max: 0.0718506 velocity magnitude: 2.13169
DILUPBiCG: Solving for Ux, Initial residual = 1.69255e-05, Final residual = 2.04556e-10, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 3.87838e-05, Final residual = 5.12499e-10, No Iterations 1
DILUPBiCG: Solving for T, Initial residual = 2.60503e-06, Final residual = 7.08107e-19, No Iterations 3
GAMG: Solving for p, Initial residual = 0.463702, Final residual = 8.96859e-07, No Iterations 166
GAMG: Solving for p, Initial residual = 5.29002e-07, Final residual = 4.72136e-07, No Iterations 2
GAMG: Solving for p, Initial residual = 4.72136e-07, Final residual = 4.21393e-07, No Iterations 2
time step continuity errors : sum local = 1.0671e-11, global = 1.00739e-12
Courant Number mean: 0.00509605 max: 0.0718506 velocity magnitude: 2.13165
DILUPBiCG: Solving for Ux, Initial residual = 0.00034187, Final residual = 1.31826e-09, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 0.000647049, Final residual = 4.43769e-09, No Iterations 1
DILUPBiCG: Solving for T, Initial residual = 1.64656e-07, Final residual = 4.07583e-19, No Iterations 3
GAMG: Solving for p, Initial residual = 0.00470111, Final residual = 9.5084e-07, No Iterations 70
GAMG: Solving for p, Initial residual = 9.51131e-07, Final residual = 8.46786e-07, No Iterations 2
GAMG: Solving for p, Initial residual = 8.46786e-07, Final residual = 7.53965e-07, No Iterations 2
time step continuity errors : sum local = 1.90879e-11, global = -1.63793e-12
Courant Number mean: 0.00509605 max: 0.0718506 velocity magnitude: 2.13166
DILUPBiCG: Solving for Ux, Initial residual = 8.49261e-05, Final residual = 2.9928e-10, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 0.000162847, Final residual = 1.10464e-09, No Iterations 1
DILUPBiCG: Solving for T, Initial residual = 4.69454e-09, Final residual = 1.72592e-20, No Iterations 3
GAMG: Solving for p, Initial residual = 0.000448699, Final residual = 9.6565e-07, No Iterations 44
GAMG: Solving for p, Initial residual = 9.65837e-07, Final residual = 8.5836e-07, No Iterations 2
GAMG: Solving for p, Initial residual = 8.5836e-07, Final residual = 7.63068e-07, No Iterations 2
time step continuity errors : sum local = 1.9316e-11, global = -1.59423e-12
DILUPBiCG: Solving for Ux, Initial residual = 2.10751e-05, Final residual = 2.8395e-10, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 4.09195e-05, Final residual = 2.77616e-10, No Iterations 1
DILUPBiCG: Solving for T, Initial residual = 1.11622e-09, Final residual = 3.26274e-21, No Iterations 3
GAMG: Solving for p, Initial residual = 0.000111793, Final residual = 9.7267e-07, No Iterations 24
GAMG: Solving for p, Initial residual = 9.72714e-07, Final residual = 8.56298e-07, No Iterations 2
GAMG: Solving for p, Initial residual = 8.56298e-07, Final residual = 7.55912e-07, No Iterations 2
time step continuity errors : sum local = 1.91344e-11, global = -1.45064e-12
Setting traction on solid patch
Total force (fluid) = (-5.04694 -22.6577 1.92893e-13)
Total force (solid) = (4.77552 22.2434 -1.94685e-13)
Evolving solid solver: unsTotalLagrangianSolid
DICPCG: Solving for D, Initial residula = 0.000161116, Final residual = 1.9265e-07, No outer iterations = 20
Max relative residual = 0.091944, Relative residual = 9.12633e-05, enforceLinear = 0
Current fsi relative residual norm: 1
Alternative fsi residual: 0.00320077
Time = 0.0904, iteration: 54
Maximal accumulated displacement of interface points: 0.0417414
GAMG: Solving for cellMotionUx, Initial residual = 0.644976, Final residual = 7.91795e-07, No Iterations 10
GAMG: Solving for cellMotionUy, Initial residual = 0.0229824, Final residual = 4.80133e-07, No Iterations 6
GAMG: Solving for cellMotionUx, Initial residual = 0.00277923, Final residual = 5.50974e-07, No Iterations 5
GAMG: Solving for cellMotionUy, Initial residual = 0.000126275, Final residual = 5.73838e-07, No Iterations 2
GAMG: Solving for cellMotionUx, Initial residual = 0.000287842, Final residual = 9.94785e-07, No Iterations 3
GAMG: Solving for cellMotionUy, Initial residual = 6.24588e-06, Final residual = 1.14872e-07, No Iterations 2
GAMG: Solving for cellMotionUx, Initial residual = 3.26168e-05, Final residual = 3.7052e-07, No Iterations 2
GAMG: Solving for cellMotionUy, Initial residual = 7.43987e-07, Final residual = 2.96932e-08, No Iterations 2
GAMG: Solving for cellMotionUx, Initial residual = 3.46038e-06, Final residual = 8.51121e-08, No Iterations 2
GAMG: Solving for cellMotionUy, Initial residual = 1.03042e-07, Final residual = 7.7279e-09, No Iterations 2
Courant Number mean: 0.00774371 max: 0.722412 velocity magnitude: 20.3402
DILUPBiCG: Solving for Ux, Initial residual = 0.000510444, Final residual = 2.70013e-07, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 0.0019864, Final residual = 1.16873e-09, No Iterations 2
DILUPBiCG: Solving for T, Initial residual = 4.38472e-05, Final residual = 9.18841e-14, No Iterations 3
GAMG: Solving for p, Initial residual = 0.926829, Final residual = 9.80306e-07, No Iterations 200
GAMG: Solving for p, Initial residual = 2.89641e-07, Final residual = 2.58609e-07, No Iterations 2
GAMG: Solving for p, Initial residual = 2.58609e-07, Final residual = 2.30905e-07, No Iterations 2
time step continuity errors : sum local = 9.80875e-11, global = -9.42611e-12
Courant Number mean: 0.00781173 max: 0.569187 velocity magnitude: 26.6585
DILUPBiCG: Solving for Ux, Initial residual = 0.0146298, Final residual = 7.35807e-07, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 0.00898921, Final residual = 3.71578e-09, No Iterations 2
DILUPBiCG: Solving for T, Initial residual = 6.64144e-06, Final residual = 4.72606e-15, No Iterations 3
GAMG: Solving for p, Initial residual = 0.0559703, Final residual = 9.43765e-07, No Iterations 98
GAMG: Solving for p, Initial residual = 9.75612e-07, Final residual = 8.69077e-07, No Iterations 2
GAMG: Solving for p, Initial residual = 8.69078e-07, Final residual = 7.74239e-07, No Iterations 2
time step continuity errors : sum local = 3.06496e-10, global = 2.679e-11
Courant Number mean: 0.0078112 max: 0.542143 velocity magnitude: 25.3919
DILUPBiCG: Solving for Ux, Initial residual = 0.00386819, Final residual = 7.63941e-07, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 0.00355023, Final residual = 8.43555e-07, No Iterations 1
DILUPBiCG: Solving for T, Initial residual = 8.79361e-07, Final residual = 8.75165e-16, No Iterations 3
GAMG: Solving for p, Initial residual = 0.00463734, Final residual = 8.98097e-07, No Iterations 74
GAMG: Solving for p, Initial residual = 8.97377e-07, Final residual = 7.98972e-07, No Iterations 2
GAMG: Solving for p, Initial residual = 7.98973e-07, Final residual = 7.1143e-07, No Iterations 2
time step continuity errors : sum local = 2.82385e-10, global = 2.42679e-11
Courant Number mean: 0.00781099 max: 0.541624 velocity magnitude: 25.3676
DILUPBiCG: Solving for Ux, Initial residual = 0.000975643, Final residual = 1.63967e-07, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 0.000985652, Final residual = 3.47318e-07, No Iterations 1
DILUPBiCG: Solving for T, Initial residual = 1.494e-07, Final residual = 1.89168e-16, No Iterations 3
GAMG: Solving for p, Initial residual = 0.00123167, Final residual = 9.63733e-07, No Iterations 50
GAMG: Solving for p, Initial residual = 9.63516e-07, Final residual = 8.56075e-07, No Iterations 2
GAMG: Solving for p, Initial residual = 8.56075e-07, Final residual = 7.60856e-07, No Iterations 2
time step continuity errors : sum local = 3.02212e-10, global = 2.47939e-11
Total force (fluid) = (189.946 266.482 -2.23025e-12)
Total force (solid) = (-158.971 -326.598 2.14702e-12)
det: -0.909054, 1.001
DICPCG: Solving for D, Initial residula = 0.00883054, Final residual = 5.6837e-06, No outer iterations = 50
Max relative residual = 1.13098, Relative residual = 0.00110747, enforceLinear = 0
Alternative fsi residual: 0.0728413
Time = 0.0904, iteration: 55
Maximal accumulated displacement of interface points: 9.85912
GAMG: Solving for cellMotionUx, Initial residual = 0.707085, Final residual = 9.02776e-07, No Iterations 10
GAMG: Solving for cellMotionUy, Initial residual = 0.0370538, Final residual = 7.71471e-07, No Iterations 6
GAMG: Solving for cellMotionUx, Initial residual = 0.00297136, Final residual = 5.99365e-07, No Iterations 5
GAMG: Solving for cellMotionUy, Initial residual = 0.000111731, Final residual = 5.09348e-07, No Iterations 2
GAMG: Solving for cellMotionUx, Initial residual = 0.000378415, Final residual = 5.6832e-07, No Iterations 4
GAMG: Solving for cellMotionUy, Initial residual = 5.60756e-06, Final residual = 1.02387e-07, No Iterations 2
GAMG: Solving for cellMotionUx, Initial residual = 4.33015e-05, Final residual = 4.41035e-07, No Iterations 2
GAMG: Solving for cellMotionUy, Initial residual = 6.64832e-07, Final residual = 2.64947e-08, No Iterations 2
GAMG: Solving for cellMotionUx, Initial residual = 4.56358e-06, Final residual = 8.64536e-08, No Iterations 2
GAMG: Solving for cellMotionUy, Initial residual = 9.22762e-08, Final residual = 6.90697e-09, No Iterations 2
Courant Number mean: 0.161806 max: 179.4 velocity magnitude: 659.511
DILUPBiCG: Solving for Ux, Initial residual = 0.517266, Final residual = 3.11769e-07, No Iterations 4
DILUPBiCG: Solving for Uy, Initial residual = 0.865463, Final residual = 5.02855e-07, No Iterations 4
DILUPBiCG: Solving for T, Initial residual = 0.252526, Final residual = 3.39017e-08, No Iterations 5
Floating point exception (core dumped)
