Problem while running decomposePar
Like Tree1Likes
  • 1 Post By simrego
Old   May 6, 2019, 00:27
Question Problem while running decomposePar
LT
NewKid is on a distinguished road
While running decomposePar in a case on 360 cores, everything is OK.
But while running this command on 420 or 480 cores, it reports in some subdomains there is no points and cells, then sprayFoam solver can not go on after it shows the radiation model.
The decomposeParDict file is shown as follows:
numberOfSubdomains 480;
method simple;
simpleCoeffs
n (20 6 4);// 2);//(4 2 11);//(4 11 2);//(7 4 4);// 1 8);
delta 0.001;
hierarchicalCoeffs
n (1 1 1);
delta 0.001;
order xyz;
metisCoeffs
processorWeights
1
1
1
multiLevelCoeffs
level0 //node级别
numberOfSubdomains 2; //区域的数目,我笔记本4核心单cpu的,只有一个node
method scotch;
level1//core级别
numberOfSubdomains 4; //子区域数目4,因为有4个核心
method scotch;//使用scotch方法
manualCoeffs
dataFile "";
distributed no;
roots
NewKid is offline   Reply With Quote
Old   May 6, 2019, 07:18
anonymous
simrego is on a distinguished road
Hi!
Maybe this is a silly guess but try to use the scotch method for decomposition, not the simple one. Maybe you have some cores with 0 cells because of the simple method.
Also scotch will give you a better balance for the cores.
(Or you can use pscotch if you compiled it.)
Swift likes this.
simrego is offline   Reply With Quote
Old   May 8, 2019, 05:22
Wink
LT
Hi, simrego. Thanks so much for your suggestion!
What bothers me is that while I run decomposePar of OF 4.0 instead of OF 3.0 on my machine, everything is fine, no cells never happens.
And I use multiLevel instead of simple, which is said to fit the multi-nodes computation. And in the different levels (node and core), the decompose method is scotch.
Everything is OK now.
Anyway, thank you
Regards!
decomposepar, no cells, no points
Problem running movingCylinders case in parallel with foam-extend-3.1 mhkenergy OpenFOAM Running, Solving & CFD 5 March 3, 2017 06:20
ANSYS Licensing Problem, Processes Running but Showing as Not Running penguinman ANSYS 3 September 27, 2016 14:30
[waves2Foam] Problem in running Allrun and also setWaveFields ankitchy OpenFOAM Community Contributions 2 March 9, 2015 09:10
[Other] Problem running after decomposition paul.m.edwards OpenFOAM Meshing & Mesh Conversion 0 January 14, 2015 13:55
problem with running in parallel dhruv OpenFOAM 3 November 25, 2011 06:06
