Power and Enthalpy in fvOptions file
Like Tree1Likes
  • 1 Post By Bloerb
Old   April 25, 2019, 06:22
Default Power and Enthalpy in fvOptions file
Raza Javed
Raza Javed is on a distinguished road
Hello everyone,
I am trying to generate a heat source using Power of 10W using fvOptions file. So for this, I have given the value of 10 to "h" in fvOptions like below:
heatSource
    type            scalarSemiImplicitSource;
    active          true;
    scalarSemiImplicitSourceCoeffs
        selectionMode   all; // all, cellSet, cellZone, points
       // cellZone        heatSrc;
        //cellSet         c1;
        volumeMode      absolute; // specific;
        injectionRateSuSp
            h     (10 0);
I have read in this forum that If I need a power of say 10W, then I just need to put that value as "h (10 0)" in fvOptions and the volumeMode should be "absolute".
The temperature of my heat source is changing when I check it in paraview but I don't understand that how this power(W) is changing my temperature? What is the mathematical relationship between them? Also some people also say that this 'h' is Enthalpy, so I am confused that if this is enthalpy then how can I put my power directly in "h" ?
Also I went through the solver log file to see how solver reads the fvOtption file. And it shows the following:
    Adding fvOptions
Creating finite volume options from "constant/fvOptions"
Selecting finite volume options model type scalarSemiImplicitSource
    Source: heatSource
    - selecting all cells
    - selected 10599 cell(s) with volume 123000
What does this mean?
-selected 10599 cell(s) with volume 123000
This value remains the same even if I change the value of "h" in my fvOptions file.
I shall be very thankful if someone can clear my doubts.
Thank you
Raza Javed is offline   Reply With Quote
Old   April 26, 2019, 11:03
Bloerb will become famous soon enough
This simply means, that your fvOptions is applied to 10599 cells which have a combined volume of 123000 m³.
Lets assume you have the following equation:
\nabla\cdot \left(\alpha \nabla h \right) = 0
This is the equation for heat conduction inside a solid. It is an equation for enthalpy, but can also be formulated with temperature directly. You can add an explicit source term S to this equation:
\nabla\cdot \left(\alpha \nabla h \right) = S
Now this source term describes internal heat generation. Again, please check a fundamentals book in heat transfer for that.
Now:
scalarSemiImplicitSource has an explicit and implicit part.
h     (10 0);
This means that to the equation for h and explicit part of 10 should be added and an implicit part of 0. This changes our equation to
\nabla\cdot \left(\alpha \nabla h \right) = 10
I hope this helps
saidc. likes this.
Bloerb is offline   Reply With Quote
fvoptions, heat sources, openfoam, power, temperature
Power dependent heat source using fvOptions Raza Javed OpenFOAM Running, Solving & CFD 0 April 15, 2019 09:45
Surface emissive power and virtual radiometers Dani87 FLUENT 1 November 30, 2018 07:58
Calculation of power in CFD Post for a radial turbine AntonZ CFX 0 May 30, 2017 00:10
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 16:45
Flow power computation Atit Koonsrisuk CFX 0 February 23, 2005 13:44
