Floating point exception (core dumped) issue by solving the change of pitchAxis |
April 23, 2019, 22:52 |
Ze Shao
Rep Power: 7 |
Dear all
I am new to OpenFoam.I tried to find out how to get the force coefficients by putting the code in the controlDict. As shown below, application icoFoam; startFrom startTime; startTime 0; stopAt endTime; endTime 100; deltaT 0.001; writeControl timeStep; writeInterval 5; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable true; functions { forceCoeffs1 { type forceCoeffs; functionObjectLibs ("libforces.so"); writeControl timeStep; enabled true; writeInterval 10; patches ( body ); //change to your patch name rho rhoInf; rhoInf 1000; // rhoInf - reference density CofR (0 0 0); // CofR - Centre of rotation liftDir (0 1 0); // dragDir - Direction of drag coefficient dragDir (1 0 0);// liftDir - Direction of lift coefficient pitchAxis (0 0 0); // pitchAxis - Pitching moment axis magUInf 1.0; // magUinf - free stream velocity magnitude lRef 1; // lRef - reference length, which is the chord length for an airfoil and the diameter for a cylinder Aref 12.0; // Aref - reference area, which is the chord*span for an airfoil, and diameter*length for your cylinder } } It always show "Floating point exception (core dumped). However, if I change the pitchAxis (0 0 0) to pitchAxis (0 0 1), it will work. I do not know why. In fact, I do not need to know the pitching moment in my case. Would you please do me a favour to explain it? Kind regards, Ze |
April 24, 2019, 11:26 |
During creation of the forceCoeffs function object axes vectors are normalised, to make their lengths equal to one. Normalisation is made by division axis vector by its norm. If you set axis vector to (0 0 0), its magnitude becomes 0, and you get FPE. If you do not need pitching moment, simply ignore it. |
force coefficients, pitchaxis |
Maximum number of iterations exceeded chtmultiregionsimpleFoam | Moncef | OpenFOAM Running, Solving & CFD | 28 | July 13, 2020 14:26 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Unstabil Simulation with chtMultiRegionFoam | mbay101 | OpenFOAM Running, Solving & CFD | 13 | December 28, 2013 13:12 |
SLTS+rhoPisoFoam: what is rDeltaT??? | nileshjrane | OpenFOAM Running, Solving & CFD | 4 | February 25, 2013 04:13 |
Error while running rhoPisoFoam.. | nileshjrane | OpenFOAM Running, Solving & CFD | 8 | August 26, 2010 12:50 |
