Problem with GroovyBC with two time limits
Like Tree2Likes
  • 2 Post By Stefanie.S.W.
Old   April 23, 2019, 06:48
Default Problem with GroovyBC with two time limits
Stefanie Wolf
Stefanie.S.W. is on a distinguished road
Hello everyone,
I am using two groovy inlets and a constant inlet. One inlet is leading to an error message and I can not make out why.
This are my Inlets:
  1. Inlet Water: constant velocity
  2. Inlet Oil: starts with V_oil at t=0. The velocity decreases, at t=805sek V_oil =0.
  3. Inlet Water+LM (Surfactant): Mixture of 3%LM and 97%Water. It starts at t=805sek and stops at t=1409sek. During this time the velocity is constant.
The fist two inlets work fine. The third inlet works until 1408.999 sek. It leads to the following error:
[1] #0 Foam::error:rintStack(Foam::Ostream&) at ??:?
[1] #1 Foam::sigFpe::sigHandler(int) at ??:?
[1] #2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
[1] #3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&)
This is the timestep at which the error "Floating point exception" occurs:
Courant Number mean: 0.111955 max: 0.890235
deltaT = 0.001
Time = 1409
MULES: Solving for alpha.water
water volume fraction, min, max = 0.0145146 -2.49133e-23 1
MULES: Solving for alpha.oil
oil volume fraction, min, max = 0.00164353 -1.24074e-69 1
MULES: Solving for alpha.lm
lm volume fraction, min, max = 0 0 0.03
MULES: Solving for alpha.air
air volume fraction, min, max = 0.983842 0 1
Phase-sum volume fraction, min, max = 1 0.999485 1
water volume fraction, min, max = 0.0145148 -3.68429e-23 1
oil volume fraction, min, max = 0.00164353 -2.22909e-67 1
Phase-sum volume fraction, min, max = 1 0.997947 1.00593
water volume fraction, min, max = 0.0145148 -3.41819e-23 1
oil volume fraction, min, max = 0.00164353 -2.71414e-67 1
Phase-sum volume fraction, min, max = 1 0 1.00586
Following are the files from the 0-Directory
Alpha.water
FoamFile
version 2.0;
format ascii;
class volScalarField;
location "0";
object alpha.water;
dimensions [0 0 0 0 0 0 0];
internalField uniform 0;
boundaryField
wall
type zeroGradient;
atmosphere
type inletOutlet;
inletValue uniform 0;
value uniform 0;
outlet
type inletOutlet;
value uniform 0;
inlet_rain
type inletOutlet;
inletValue uniform 1;
value uniform 1;
phi phi.water;
inlet_oil
type inletOutlet;
value uniform 0;
inlet_lml
type groovyBC;
valueExpression "time()>805 && time()<1409 ? 0.97 : 0";
value uniform 0;
phi phi.water;
defaultFaces
type empty;
Alpha.lm
FoamFile
version 2.0;
format ascii;
location "0";
object alpha.oil;
boundaryField
wall
type zeroGradient;
atmosphere
type inletOutlet;
value uniform 0;
outlet
type inletOutlet;
value uniform 0;
inlet_rain
type inletOutlet;
value uniform 0;
inlet_oil
type inletOutlet;
value uniform 0;
inlet_lml
type groovyBC;
valueExpression "time()>805 && time()<1409 ? 0.03: 0";
value uniform 0;
phi phi.lm;
defaultFaces
type empty;
U.water
FoamFile
version 2.0;
format ascii;
class volVectorField;
location "0";
object U.water;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
wall
type noSlip;
atmosphere
type pressureInletOutletVelocity;
value $internalField;
phi phi.water;
outlet
phi phi.water;
inlet_rain
type fixedValue;
value uniform (0 -0.010455 0);
phi phi.water;
inlet_oil
type fixedValue;
value uniform (0 0 0);
inlet_lml
type groovyBC;
valueExpression "time()>805 && time()<1409 ? vector(0,-(0.039735),0) : vector(0,0,0)";
phi phi.water;
U.lm
FoamFile
version 2.0;
format ascii;
location "0";
object U.lm;
boundaryField
wall
type noSlip;
atmosphere
phi phi.lm;
outlet
phi phi.lm;
inlet_rain
type fixedValue;
inlet_oil
type fixedValue;
inlet_lml
type fixedValue;
phi phi.lm;
Alpha.oil
FoamFile
version 2.0;
format ascii;
location "0";
object alpha.oil;
boundaryField
wall
type zeroGradient;
atmosphere
type inletOutlet;
value uniform 0;
outlet
type inletOutlet;
value uniform 0;
inlet_rain
type inletOutlet;
value uniform 0;
inlet_oil
type groovyBC;
valueExpression "time()<805 ? 1 : 0";
value uniform 0;
phi phi.oil;
inlet_lml
type inletOutlet;
value uniform 0;
defaultFaces
type empty;
U.oil
FoamFile
version 2.0;
format ascii;
location "0";
object U.oil;
boundaryField
wall
type noSlip;
atmosphere
phi phi.oil;
outlet
phi phi.oil;
inlet_rain
type fixedValue;
inlet_oil
type groovyBC;
valueExpression "time()<805 ? vector( 0, -(((805-time())/805)*0.38757764), 0) : vector(0,0,0)";
phi phi.oil;
inlet_lml
type fixedValue;
Alpha.air
FoamFile
version 2.0;
format ascii;
location "0";
object alpha.air;
boundaryField
wall
type zeroGradient;
atmosphere
type inletOutlet;
phi phi.air;
value uniform 1;
outlet
type inletOutlet;
value uniform 1;
inlet_rain
type inletOutlet;
value uniform 0;
inlet_oil
type groovyBC;
valueExpression "time()<805 ? 0 : 1";
value uniform 0;
inlet_lml
type groovyBC;
value uniform 0;
defaultFaces
type empty;
U.air
FoamFile
version 2.0;
format ascii;
location "0";
object U.air;
boundaryField
wall
type noSlip;
atmosphere
phi phi.air;
outlet
phi phi.air;
inlet_rain
type fixedValue;
inlet_oil
type fixedValue;
inlet_lml
type fixedValue;
p
FoamFile
version 2.0;
format ascii;
object p;
dimensions [1 -1 -2 0 0 0 0];
internalField uniform 1e5;
boundaryField
wall
type calculated;
inlet_rain
type calculated;
inlet_oil
type calculated;
inlet_lml
type calculated;
outlet
type calculated;
atmosphere
type calculated;
defaultFaces
type empty;
p.rgh
FoamFile
version 2.0;
format ascii;
object p;
boundaryField
wall
type fixedFluxPressure;
inlet_rain
inlet_lml
inlet_oil
outlet
type prghPressure;
p $internalField;
atmosphere
type prghPressure;
p $internalField;
defaultFaces
type empty;
nut
FoamFile
version 2.0;
format ascii;
location "0";
object nut;
dimensions [0 2 -1 0 0 0 0];
boundaryField
wall
type nutkWallFunction;
value uniform 0;
atmosphere
type calculated;
value uniform 0;
inlet_oil
type calculated;
value uniform 0;
inlet_rain
type calculated;
value uniform 0;
inlet_lml
type calculated;
value uniform 0;
outlet
type calculated;
value uniform 0;
defaultFaces
type empty;
Does anyone see why the GroovyBC time()<1409 leads to an error?
Thank you for your time and help!
Stefanie.S.W. is offline   Reply With Quote
Old   May 2, 2019, 08:28
Stefanie Wolf
I changed my bc for U.lm to:
inlet_lml
type fixedValue;
value $boundaryField; //$internalField;
phi phi.lm;
But this did not fix the Inlet.
At sek 1409 I get an error again:
$ mpirun -np 2 multiphaseEulerFoam -parallel >>log.Solve6
[1] #0  Foam::error::printStack(Foam::Ostream&) at ??:?
[1] #3  Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
[1] #4  ? in "/opt/openfoam6/platforms/linux64GccDPInt32Opt/bin/multiphaseEulerFoam"
[1] #5  ? in "/opt/openfoam6/platforms/linux64GccDPInt32Opt/bin/multiphaseEulerFoam"
[1] #6  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
Do you have any other idea what I have done wrong?
Thank you for your help!
Stefanie
Old   May 2, 2019, 10:04
Stefanie Wolf
I found my mistake:
No phase was defined at Inlet_lml after t=1409!
I had to change the bc for alpha.air and now it works.
To test the new case I looked at a smaller time span of 20sek.
(rain: constant inflow, oil: from 0-10 sek, mixture of LM and water: from 10-15 sek).
This is the corrected case:
alpha.air
boundaryField
    wall
     type zeroGradient;
    atmosphere
        type            inletOutlet;
        phi             phi.air;
        value           uniform 1;
    outlet
        type            inletOutlet;
        value           uniform 1;
    inlet_rain
        type            inletOutlet;
        value           uniform 0;
    inlet_oil
        type            groovyBC;
        valueExpression "time()<10 ? 0 : 1";
        value           uniform 0;
    inlet_lml
        type            groovyBC;
        valueExpression "time()>10 && time()<15 ? 0 : 1";
        value           uniform 0;
    defaultFaces
        type            empty;
alpha.lm
boundaryField
    wall
        type            zeroGradient;
    atmosphere
        type            inletOutlet;
        value           uniform 0;
    outlet
        type            inletOutlet;
        value           uniform 0;
    inlet_rain
        type            inletOutlet;
        value           uniform 0;
    inlet_oil
        type            inletOutlet;
        value           uniform 0;
    inlet_lml
        type            groovyBC;
        valueExpression "time()>10 && time()<15 ? 0.03: 0";
        value           uniform 0;
        phi             phi.lm;
    defaultFaces
        type            empty;
alpha.oil
boundaryField
    wall
        type            zeroGradient;
    atmosphere
        type            inletOutlet;
        value           uniform 0;
    outlet
        type            inletOutlet;
        value           uniform 0;
    inlet_rain
        type            inletOutlet;
        value           uniform 0;
    inlet_oil
        type            groovyBC;
        valueExpression "time()<10 ? 1 : 0";
        value           uniform 0;
        phi             phi.oil;
    inlet_lml
        type            inletOutlet;
        value           uniform 0;
    defaultFaces
        type            empty;
alpha.water
boundaryField
    wall
        type            zeroGradient;
    atmosphere
        type            inletOutlet;
        value           uniform 0;
    outlet
        type            inletOutlet;
        value           uniform 0;
    inlet_rain
        type            inletOutlet;
        value           uniform 1;
        phi             phi.water;
    inlet_oil
        type            inletOutlet;
        value           uniform 0;
    inlet_lml
        type            groovyBC;
        valueExpression "time()>10 && time()<15 ? 0.97 : 0";
        value           uniform 0;
        phi             phi.water;
    defaultFaces
        type            empty;
U.lm
boundaryField
    wall
        type            noSlip;
    atmosphere
        phi                phi.lm;
    outlet
        phi                phi.lm;
    inlet_rain
        type            fixedValue;
    inlet_oil
        type            fixedValue;
    inlet_lml
        type            fixedValue;
        phi             phi.lm;
U.oil
boundaryField
    wall
        type            noSlip;
    atmosphere
        phi                phi.oil;
    outlet
        phi                phi.oil;
    inlet_rain
        type            fixedValue;
    inlet_oil
        type            groovyBC;
        valueExpression "time()<10 ? vector( 0, -(((10-time())/10)*0.38757764), 0) : vector(0,0,0)";
        phi             phi.oil;
    inlet_lml
        type            fixedValue;
U.water
boundaryField
    wall
        type            noSlip;
    atmosphere
        phi                phi.water;
    outlet
        phi                phi.water;
    inlet_rain
        type                fixedValue;
        phi                 phi.water;
    inlet_oil
        type                fixedValue;
    inlet_lml
        type              groovyBC;
        valueExpression   "time()>10 && time()<15 ? vector(0,-(0.039735),0) : vector(0,0,0)";
        phi               phi.water;
groovybc, multiphase boundary
Setting up Lid driven Cavity Benchmark with 1M cells for multiple cores puneet336 OpenFOAM Running, Solving & CFD 11 April 7, 2019 01:58
pimpleDyMFoam computation randomly stops babapeti OpenFOAM Running, Solving & CFD 5 January 24, 2018 06:28
a problem with convergence in buoyantSimpleFoam skuznet OpenFOAM Running, Solving & CFD 6 November 15, 2017 13:12
pressure in incompressible solvers e.g. simpleFoam chrizzl OpenFOAM Running, Solving & CFD 13 March 28, 2017 06:49
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
