How to create different concentric cylinders using topoSet |
April 20, 2019, 14:32 |
bharadwaz
Rep Power: 8 |
Hello foamers
I had a small problem in solving chtMultiregionFoam I need to solve concentric cylinders which should be created using topoSet as far as in openFoam-6 we can create an only solid cylinder by prescribing the starting point of axis the ending point of axis and the radius of a cylinder But no option of a hollow cylinder can anyone help me Thanks in advance |
April 23, 2019, 04:58 |
Robert
Rep Power: 12 |
Why do you want a hollow cylinder? The closest you might get is: create two cylinders at the same position but with different diameters. Substract the smaller toposet from the larger. Voila! Annulus. But still no hollow cylinder.
If you liked my answer to your question, please consider leaving a "Like" in return |
May 1, 2019, 06:29 |
bharadwaz
Rep Power: 8 |
name cathode; // name of the set type cellSet; action new; // creating a new set or add source cylinderAnnulusToCell; // using a selection box sourceInfo { p1 ( 0 0 0.03 ); // start point on cylinder axis p2 ( 0 0 0.07 ); // end point on cylinder axis outerRadius 0.009 ; innerRadius 0.004 ; } } |
chtmultiregionfoam, mesh, openfoam, toposet |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 92 | May 21, 2024 08:56 |
Possible to create cyliner baffle (internal) using topoSet or stl Mesh? | keepfit | OpenFOAM | 4 | February 19, 2017 15:40 |
[mesh manipulation] Problem with topoSet and FaceZone creation | ADGlassby | OpenFOAM Meshing & Mesh Conversion | 7 | September 16, 2013 12:05 |
[GAMBIT] Dynamic mesh for concentric cylinders | mijama | ANSYS Meshing & Geometry | 1 | October 20, 2009 02:58 |
Actuator disk model | audrich | FLUENT | 0 | September 21, 2009 08:06 |
