Implicit term in the continuity equation
Like Tree1Likes
  • 1 Post By Tobi
Old   March 28, 2019, 06:33
Default Implicit term in the continuity equation
pod
pod is on a distinguished road
Hello everyone,
I'm trying to use a continuity equation in chtMultiRegionFoam that looks like it (similarly to the one used in cavitatingFoam):
fvScalarMatrix rhoEqn
        fvm::ddt(rho)
      + fvm::div(phi2, rho)
        fvOptions(rho)
which basically has the second term implicit instead of explicit like in normal heat transfer solvers.
I get this known problem:
valueInternalCoeffs cannot be called for a calculatedFvPatchField
    on patch ...
    You are probably trying to solve for a field with a default boundary condition
I know this comes out if you set "calculated" b.c. type but I think mine should be fine:
in the 0 folder:
dimensions      [1 -3 0 0 0 0 0];
internalField   uniform 147;
boundaryField
        type            zeroGradient;
In the fluid part changeDictionary:
    rho
    boundaryField
        type            zeroGradient;
                value           uniform 147;
does anyone have any idea?
thanks a lot
pod is offline   Reply With Quote
Old   March 28, 2019, 07:37
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
the density field should be set automatically to calculated as the boundary values are "calculated" from other values. It is not a field like a passive scalar and I don´t think that your density field has zeroGradient patch types - even though you defined it. To check it, just plot rho before your continuity equation.
Furthermore, your equation is a transport equation and not a continuity equation:
\frac{\partial \rho}{\partial t} + \nabla \bullet (\underbrace{\rho \textbf{U}}_{phi2} \rho) = S_{\rho}
This equation looks more like an incompressible transport equation for the density.
granzer likes this.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   March 28, 2019, 08:56
pod
Hello Tobi,
thanks a lot for your reply.
In reality phi2 is not equal to the definition of phi in heat transfer solvers (rho*U), but it is defined like:
surfaceScalarField phi2 = (fvc::interpolate(HbyA) & mesh.Sf())
         + rhorAUf*fvc::ddtCorr(U, linearInterpolate(U) & mesh.Sf()) - rhorAUf*mesh.magSf()*fvc::snGrad(p_rgh)/rhof;
in order to resemble the phi of cavitatingFoam, which is actually more similar to phiHbyA of chtMultiFoam. I forgot to mention that, sorry. So it is a continuity equation, right?
Also, the initialization of rho in cavitatingFoam's tutorials is similar to mine:
dimensions      [1 -3 0 0 0];
internalField   uniform 845;
boundaryField
    inlet
        type            fixedValue;
        value           uniform 845;
    outlet
        type            fixedValue;
        value           uniform 835;
    walls
        type            zeroGradient;
    frontBack
        type            zeroGradient;
that's why I don't understand what's wrong.
thanks
Old   March 29, 2019, 14:07
Michael Alletto
mAlletto will become famous soon enough
Originally Posted by pod View Post
Hello everyone,
        fvm::ddt(rho)
        fvOptions(rho)
    on patch ...
in the 0 folder:
boundaryField
        type            zeroGradient;
    rho
    boundaryField
        type            zeroGradient;
                value           uniform 147;
thanks a lot
The error you posted usually appears if the boundary condition is unknown. Did you try to remove the value under zeroGradient?
mAlletto is offline   Reply With Quote
boundary condition, chtmultiregionfoam, continuity equation, implicit explicit
courant number increases to rather large values 6863523 OpenFOAM Running, Solving & CFD 22 July 6, 2023 00:48
Domain Reference Pressure and mass flow inlet boundary AdidaKK CFX 75 August 20, 2018 06:37
pimpleDyMFoam computation randomly stops babapeti OpenFOAM Running, Solving & CFD 5 January 24, 2018 06:28
Stuck in a Rut- interDyMFoam! xoitx OpenFOAM Running, Solving & CFD 14 March 25, 2016 08:09
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 03:50
