Inaccurate results for some turbulent annular flows using K-Omega SST
Like Tree3Likes
  • 3 Post By donree4
Old   March 19, 2019, 08:14
Default Inaccurate results for some turbulent annular flows using K-Omega SST
Haydn Trett
donree4 is on a distinguished road
Hey all,
This is my first post here, and i'm relatively new to OpenFOAM so forgive me for my inexperience and ignorance
I'm conducting a comparative study between ANSYS Fluent and OpenFOAM. I've simulated various turbulent annular flows in ANSYS Fluent and i'm now trying to replicate the results in OF (Identical mesh, turbulence model, numerical methods/procedures etc). The results show great agreement with experimental data for most cases, however one case has proven troublesome, and i'm not particularly sure as to why. Any support you guys can provide would be much appreciated
Potentially useful information:
The 'behaving' case (Nouri)
- External Radius: 40.3mm
- Internal Radius: 20.1mm (Radius ratio ~0.5)
- Reynolds Number: 8900
- Data type: Experimental
The 'troublesome' case (Chung)
- Internal Radius: 4.03mm (Radius Ratio ~0.1)
- Data type: DNS
Methods
- 2D asymmetric meshes were generated in ANSYS Fluent and converted to OpenFOAM using the 'FluentMeshToFoam' and 'makeAxialMesh' commands.
- Each case used identical case files, re-purposed (i.e with appropriate BCs) as appropriate. The code:
U
| \\ / O peration | Version: v1812 |
| \\ / A nd | Web: www.OpenFOAM.com |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
inlet
type fixedValue;
value uniform (0.4 0 0);
topwall
type noSlip;
outlet
type zeroGradient;
bottomwall
type noSlip;
frontAndBackPlanes
type empty;
frontAndBackPlanes_pos
type wedge;
frontAndBackPlanes_neg
type wedge;
P
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
inlet
type zeroGradient;
topwall
type zeroGradient;
outlet
type fixedValue;
value uniform 0;
bottomwall
type zeroGradient;
frontAndBackPlanes
type empty;
type wedge;
type wedge;
k
FoamFile
version 2.0;
format ascii;
object k;
internalField uniform 6e-4; // k =1.5 x (0.72 x 0.05)^2
boundaryField
inlet
type turbulentIntensityKineticEnergyInlet;
intensity 0.05;
value uniform 1;
outlet
type zeroGradient;
topwall
type fixedValue;
value uniform 1e-12;
bottomwall
type fixedValue;
frontAndBackPlanes
type empty;
type wedge;
type wedge;
omega
FoamFile
version 2.0;
format ascii;
object omega;
dimensions [0 0 -1 0 0 0 0];
internalField uniform 36.8098;
boundaryField
inlet
type fixedValue;
value 36.8098;
outlet
type zeroGradient;
topwall
type omegaWallFunction;
value $internalField;
bottomwall
frontAndBackPlanes
type empty;
type wedge;
type wedge;
nut
FoamFile
version 2.0;
format ascii;
location "0";
object nut;
dimensions [0 2 -1 0 0 0 0];
boundaryField
inlet
type calculated;
value uniform 0;
topwall
type nutkWallFunction;
value uniform 0;
outlet
type calculated;
value uniform 0;
bottomwall
value uniform 0;
frontAndBackPlanes
type empty;
type wedge;
type wedge;
controlDict
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object controlDict;
application simpleFoam;
startFrom latestTime;
stopAt endTime;
endTime 10000;
deltaT 1;
writeControl timeStep;
writeInterval 1;
purgeWrite 1;
writeFormat ascii;
writePrecision 10;
writeCompression off;
timeFormat general;
timePrecision 6;
fvSchemes
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSchemes;
ddtSchemes
default steadyState;
gradSchemes
default leastSquares;
divSchemes
default Gauss linear;
div(phi,U) Gauss linearUpwind grad(U);
div(phi,k) Gauss upwind;
div(phi,omega) Gauss upwind;
laplacianSchemes
default Gauss linear corrected;
interpolationSchemes
default linear;
snGradSchemes
default corrected;
wallDist
method meshWave;
fvSolution
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSolution;
solvers
p
solver GAMG;
smoother GaussSeidel;
tolerance 1e-06;
U
solver GAMG;
tolerance 1e-06;
k
solver GAMG;
tolerance 1e-06;
omega
solver GAMG;
tolerance 1e-06;
SIMPLE
nNonOrthogonalCorrectors 0;
consistent no;
residualControl
p 1e-6;
U 1e-6;
k 1e-6;
omega 1e-6;
relaxationFactors
fields
p 0.3;
equations
U 0.7;
k 0.8;
omega 0.8;
turbulenceProperties
FoamFile
version 2.0;
format ascii;
class dictionary;
location "constant";
object turbulenceProperties;
simulationType RAS;
RAS
RASModel kOmegaSST;
turbulence on;
printCoeffs on;
transportProperties
FoamFile
version 2.0;
format ascii;
class dictionary;
object transportProperties;
nu 1.63e-6;
transportModel Newtonian;
Thanks in advance,
DonRee4
donree4 is offline   Reply With Quote
Old   March 19, 2019, 19:15
Default Solution
Haydn Trett
I found this related forum post (Problem with SST-Model - strange behaviour) that suggested reducing the k and omega tolerances from 1e-6 to 1e-12. I chose a value of 1e-10 instead for faster convergence and found that my results improved greatly (as seen in the attached). Hopefully this is useful to someone.
LES of turbulent channel flows cedric_duprat OpenFOAM Running, Solving & CFD 220 November 18, 2019 05:19
Non-Newtonaian Turbulent Flows meroney FLUENT 0 August 30, 2009 16:46
simulation results for k-w model and SST model Li CFX 7 June 29, 2007 05:19
turbulent separated flows Yin Fidelity CFD 9 February 19, 2003 12:50
calculating recirculating turbulent flows with k-e Abhijeet Vaidya Main CFD Forum 10 November 18, 2002 09:21
