Why there are two differents libraries for rigid body motions in OpenFOAM?
Like Tree1Likes
  • 1 Post By Fauster
Old   March 10, 2019, 16:35
Default Why there are two differents libraries for rigid body motions in OpenFOAM?
Paul Palladium
Fauster is on a distinguished road
Dear Foamer,
I have two questions about the dynamic motions libraries of OpenFOAM. As far I understand there is two different libraries for calculating the movement of a rigid body.
src/rigidBodyDynamic
and
src/sixDoFRigidBodyMotion
For example in the DTChull tutorial we have two different kind of dictionary for one or the other.
What are the reason for having this two libraries ? What are the strengths and weaknesses for each one ? In which cases it's advisable to use one or the other ?
Another interesting point about restraints implementation :
In rigidBodyDynamic if you use a linearSpring it's seems that the spring generate a force and a torque on the body according to the source code :
// Force and moment on the master body including optional damping
vector force
(-stiffness_*(magR - restLength_) - damping_*(r & v))*r
vector moment(attachmentPt ^ force);
But in sixDoFRigidBodyMotion the restraintMoment is null.
restraintForce = -stiffness_*(magR - restLength_)*r - damping_*(r & v)*r;
restraintMoment = Zero;
Is this difference due to the way the six dof motion is solved ? I guess I need to carried out a test case to be sure that the results are equivalent between both libraries but If someone has alrady done the verification it would be amazing !
Thanks for your thought.
Paul
Fauster is offline   Reply With Quote
Old   March 17, 2019, 05:54
Krapf is on a distinguished road
Hi Fauster,
the difference between the two libraries is explained here: Flow induced 3D motion OpenFoam
Kind regards,
Krapf
Krapf is offline   Reply With Quote
Old   March 18, 2019, 06:03
Paul Palladium
Originally Posted by Krapf View Post
Hi Fauster,
Kind regards,
Krapf
Thanks for you answer.
For me there are also important differences. The way you define the constraints is very different between both libraries. From my point of view the restraints definition of rigidBodyDynamic.so is closer to commercial CFD packages.
The sixDoFRigidBodyMotion.so is based on this paper : http://link.aip.org/link/?JCP/107/5840/1
For the rigidBodyDynamic.so I didn't find the reference.
Since my last post I find out why there is no moment returned by the restraints in the sixDoFRigidBodyMotion.so library.
The explanation can be found in the sixDoFRigidBodyMotion.C file (inside function applyRestraints)
// Restraint position
point rP = vector::zero;
// Restraint force
vector rF = vector::zero;
// Restraint moment
vector rM = vector::zero;
// Accumulate the restraints
restraints_[rI].restrain(*this, rP, rF, rM);
// Update the acceleration
a() += rF/mass_;
// Moments are returned in global axes, transforming to
// body local to add to torque.
tau() += Q().T() & (rM + ((rP - centreOfRotation()) ^ rF)); <-- the moment generated by the force is calculated here
Paul
Krapf likes this.
Old   March 18, 2019, 12:31
"Rigid body dynamics algorithms" from Roy Featherstone is the source for rigidBodyDynamic: https://github.com/OpenFOAM/OpenFOAM...873570d1e7c8dc
Kind regards,
Krapf
Old   January 21, 2020, 11:24
David
kiski is on a distinguished road
Paul
Could you give the full citation please? the link is broken
kiski is offline   Reply With Quote
Old   September 7, 2020, 17:52
Johan Roenby
roenby will become famous soon enough
Regarding the dead link to the reference above (I know, but better late than never):
I believe the paper referred to is this one: https://doi.org/10.1063/1.474310
As far as I can see, it does not document how the sixDoFRigidBodyMotion library works - only how the symplectic body motion integrator works.
roenby is offline   Reply With Quote
Compiling new liquids libraries in OpenFOAM 6.0 version ruamojica OpenFOAM Programming & Development 1 September 26, 2018 21:06
Body fitted coordinates in OpenFOAM hfsf OpenFOAM Programming & Development 0 September 12, 2013 11:57
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 07:55
[ANSYS Meshing] Surface Body Named Selections for OpenFoam slowtype ANSYS Meshing & Geometry 2 April 20, 2011 11:35
Modified OpenFOAM Forum Structure and New Mailing-List pete Site News & Announcements 0 June 29, 2009 06:56
