Trouble understanding the terms of UEqns.H in twoPhaseEulerFoam |
February 12, 2019, 19:49 |
Rep Power: 10 |
Hi all,
I am trying to add variable source terms in the twoPhaseEulerFoam. However I am unable to understand the various terms of the momentum equation. I am trying to add two force terms fsid and fl in the momentum equation. However don't know where to add the terms. Could somebody explain what the bold terms physically mean? I also cannot find the laplacian term for viscous stresses. Thanks and regards, Shantanu Code:
//#include "Random.H" //#include "StochasticDispersionRAS.H" #include "contErrs.H" Info<< "Constructing momentum equations" << endl; MRF.correctBoundaryVelocity(U1); MRF.correctBoundaryVelocity(U2); MRF.correctBoundaryVelocity(U); fvVectorMatrix U1Eqn(U1, rho1.dimensions()*U1.dimensions()*dimVol/dimTime); fvVectorMatrix U2Eqn(U2, rho2.dimensions()*U2.dimensions()*dimVol/dimTime); dimensionedScalar dimen ( "dimen", dimensionSet(0,0,1,0,0,0,0), scalar(1.0) ); dimensionedScalar dimen1 ( "dimen1", dimensionSet(0,0,-1,0,0,0,0), scalar(1.0) ); dimensionedScalar dimen2 ( "dimen1", dimensionSet(0,0,-1,0,0,0,0), scalar(1.0) ); volVectorField gr_alpha = fvc::grad(alpha2); volTensorField grU_2 = (fvc::grad(U2))*dimen; volScalarField sc = grU_2 && (grU_2 + grU_2.T()); const scalar csid = 25; const scalar a = 4e-6; //const scalar k = .1; const scalar eps = 0.206; //Lift force //dimensionedScalar up = ("up", [0 0 -1 0 0 0 0], 1.0); //const scalar up =1.0; volScalarField up = .1629+ (.2088/(.1476+(Foam::sqrt(sc)))); //volScalarField up = /*1.0*sc/(sc+ROOTSMALL)*/ sc*dimen1; const scalar cl = 1.2; volVectorField fsid = U2*dimen1; // copy of the field; volVectorField fl = U2*dimen1; volScalarField dis = wallDist(mesh).y(); volVectorField ncap = wallDist(mesh).n(); //Info<<"data="<<dis<<"\n"<<endl; //Info<<"ncap="<<ncap<<"\n"<<endl; Random rnm; forAll(fsid, cellI) { // Random :: Random(){} // Random rnm; //Random rnm Random.rndGen(); //cachedRandom& rnm = this->owner().rndGen(); scalar rn = rnm.GaussNormal<scalar>(); //Info<<rn<<endl; //volScalarField dis = wallPoint.data_(); //wallPointData<scalar> wpd; //scalar dis = wpd.updateCell(); //wallDist wpd; // volScalarField dis = wallDist(mesh).y(); // Info<<"data="<<dis<<"\n"<<endl; fsid[cellI][0] = (Foam::sqrt(sc[cellI]))*alpha2[cellI]*a*eps*rn*csid*-((gr_alpha[cellI][0])/(mag((gr_alpha[cellI]))+ROOTSMALL));//*dimen; fsid[cellI][1] = (Foam::sqrt(sc[cellI]))*alpha2[cellI]*a*eps*rn*csid*-((gr_alpha[cellI][1])/(mag((gr_alpha[cellI]))+ROOTSMALL));//*dimen; fsid[cellI][2] = (Foam::sqrt(sc[cellI]))*alpha2[cellI]*a*eps*rn*csid*-((gr_alpha[cellI][2])/(mag((gr_alpha[cellI]))+ROOTSMALL));//*dimen; } forAll(fl,cellI) { fl[cellI][0] = ((cl*(up[cellI])*(sc[cellI])*a*a*a)/((dis[cellI])+ROOTSMALL))*(-ncap[cellI][0]);//*dimen1; fl[cellI][1] = ((cl*(up[cellI])*(sc[cellI])*a*a*a)/((dis[cellI])+ROOTSMALL))*(-ncap[cellI][1]);//*dimen1; fl[cellI][2] = ((cl*(up[cellI])*(sc[cellI])*a*a*a)/((dis[cellI])+ROOTSMALL))*(-ncap[cellI][2]);//*dimen1; } //Info<< "fsid = "<< fsid << " s\n\n" << endl; volScalarField Kd(fluid.Kd()); { volScalarField Vm(fluid.Vm()); { U1Eqn = ( fvm::ddt(alpha1, rho1, U1) + fvm::div(alphaRhoPhi1, U1) - fvm::Sp(contErr1, U1) + MRF.DDt(alpha1*rho1 + Vm, U1) + phase1.turbulence().divDevRhoReff(U1) == //+ fvm::Sp(fluid.Kd()/rho1, U1) - Vm *( fvm::ddt(U1) + fvm::div(phi1, U1) - fvm::Sp(fvc::div(phi1), U1) - DDtU2 ) + fvOptions(alpha1, rho1, U1) ); U1Eqn.relax(); U1Eqn += fvm::Sp(Kd, U1); fvOptions.constrain(U1Eqn); U1.correctBoundaryConditions(); fvOptions.correct(U1); } { U2Eqn = ( fvm::ddt(alpha2, rho2, U2) + fvm::div(alphaRhoPhi2, U2) - fvm::Sp(contErr2, U2) + MRF.DDt(alpha2*rho2 + Vm, U2) + phase2.turbulence().divDevRhoReff(U2) == - Vm *( fvm::ddt(U2) + fvm::div(phi2, U2) - fvm::Sp(fvc::div(phi2), U2) - DDtU1 //- fsid*dimen*dimen1 - fl*dimen*dimen1 //- fvm::Sp(fluid.Kd()/rho1, U1) ) + fvOptions(alpha2, rho2, U2) //- fsid ); U2Eqn.relax(); U2Eqn += fvm::Sp(Kd, U2); fvOptions.constrain(U2Eqn); U2.correctBoundaryConditions(); fvOptions.correct(U2); } } |
November 19, 2021, 11:27 |
Mehrdad
Did you manage to understand the equations? where's the viscous stress term?
fvm, momentum, source terms, twophaseeulerfoam, ueqn.h |
Understanding Terms in Compressible pEqn | AMK53 | OpenFOAM Running, Solving & CFD | 5 | September 18, 2019 02:50 |
TwoPhaseEulerFoam: trying to understand the terms in UEqns.H | ARUN K RAJ | OpenFOAM Programming & Development | 1 | February 19, 2015 06:43 |
MUSCL scheme: having trouble understanding what total variation diminishing means | JMDag2004 | OpenFOAM Running, Solving & CFD | 2 | January 16, 2015 09:10 |
Question in definition of terms in solve | titio | OpenFOAM Running, Solving & CFD | 0 | March 19, 2009 17:02 |
K-Epsilon model? | Brindaban Ghosh | Main CFD Forum | 2 | June 24, 2000 05:22 |
