Cant Run pimpleDyMFoam but pimpleFoam Works
Like Tree3Likes
  • 3 Post By snak
Old   February 10, 2019, 17:47
Default Cant Run pimpleDyMFoam but pimpleFoam Works
E
Jikst is on a distinguished road
Every time I try to run a dynamic mesh AMI case using pimpleDyMFoam I get the following message:
$ mpirun -np 4 pimpleDyMFoam -parallel | tee log.pimpleDyMFoam
The dynamic mesh functionality in pimpleDyMFoam has been merged into pimpleFoam
and the pimpleDyMFoam tutorials moved into the pimpleFoam tutorials directory
I get 1 of these messages each time for each processor and then nothing happens. I already changed the dynamic mesh to the new syntax. This error happens even when trying to run in series but only for pimpleDyMFoam not pimpleFoam.
Jikst is offline   Reply With Quote
Old   February 11, 2019, 11:04
shinji nakagawa
snak is on a distinguished road
Originally Posted by Jikst View Post
You can use pimpleFoam for DyM cases if you use OpenFOAM 6. The pimpleDyMFoam tutorials have been moved into the pimpleFoam directory. (The error message you provided implies the use of of6, I assume)
https://github.com/OpenFOAM/OpenFOAM...b261b122db197c
toolpost, saatt and Jikst like this.
snak is offline   Reply With Quote
parallel run is slower than serial run (pimpleFoam) !!! mechy OpenFOAM 18 August 17, 2016 18:19
Pinning the processors in cluster to run a solver coolcrasher OpenFOAM Running, Solving & CFD 0 November 5, 2015 07:11
pimpleDyMFoam won't restart from latestTime xixchubbsxix OpenFOAM Running, Solving & CFD 1 September 30, 2015 06:26
Can not run OpenFOAM in parallel in clusters, help! ripperjack OpenFOAM Running, Solving & CFD 5 May 6, 2014 16:25
Problem with parallel run of my solver based on pimpleDyMFoam o.kotsur OpenFOAM Running, Solving & CFD 0 October 6, 2013 04:44
