parallel
Like Tree1Likes
  • 1 Post By hiaselhans
Old   February 8, 2019, 07:49
Default parallel
dolfus is on a distinguished road
Hello foamers,
I'm trying to run a case in parallel in a single machine wich has installed centOS 7 with 4 processors. BlockMesh it's okay but when running
mpirun -np 4 interFoam -parallel
an error shows up:
The value of the MCA parameter "plm_rsh_agent" was set to a path
that could not be found:
  plm_rsh_agent: ssh : rsh
Please either unset the parameter, or check that the path is correct
I've been triying to fix it, changing the vaule of the mca parameter but the error persists. I guess maybe it has something to do with docker, I'm not pretty sure.
Hope you could help me,
Regards.
dolfus is offline   Reply With Quote
Old   February 10, 2019, 13:08
hiaselhans is on a distinguished road
Hi Dofus,
i had the same problem and ended up using openfoam5-linux.
the problem tells that openssh_client is missing.
you can install openssh_client in your container like this:
sudo openfoam6-linux
apt update
apt install openssh_client
then, from another terminal get the container id or name with
[simon@simonpc ~]$ docker ps
 CONTAINER ID        IMAGE                           COMMAND                  CREATED             STATUS              PORTS               NAMES
50e05c988d80        openfoam/openfoam6-paraview56   "/bin/sh -c '/bin/sh…"   5 minutes ago       Up 5 minutes                            inspiring_stonebraker
[simon@simonpc ~]$ docker commit inspiring_stonebraker openfoam/openfoam6-paraview56
by this it should be installed in the image when you run "openfoam6-linux"
It solved that issue for me but still my logs are spammed with a lot of "Read -1, expected XXX" and i run cases either in foam5 or not parallel.
i opened a bug report here:
https://bugs.openfoam.org/view.php?id=3163
let me know what is your result..
peace
hiaselhans is offline   Reply With Quote
Old   February 18, 2019, 12:30
Thank you for your prompt reply. Unfortunately it didn't solve the problem so i ended up installing ubuntu server instead of centOS.
Old   February 19, 2019, 05:09
Hi Dolfus,
it seems the issue has been resolved:
i just did a "docker pull openfoam/openfoam6-paraview56" and i'm runnning fine now with no bugs.
peace!
Simon
dokeun likes this.
Old   April 20, 2019, 14:33
Dokeun, Hwang
dokeun is on a distinguished road
Hello there
I'm using OpenFoam-dev-parpaview56 in docker and I got the same log message.
So I ran the command 'docker pull openfoam/openfoam-dev-paraview56' but the same errors I got.
After searching for the answer, I found a thread that seems to be a solution but I can't understand their words especially last ones.
Would you please let me know what means and how to "Update dockerfile for MPI (required by gmsh) " in attached image and url below
https://github.com/open-mpi/ompi/issues/3625
Sincerely yours.
I'd run OpenFOAM by typing 'OpenFoam-dev-macos'.
I changed the method to run by typing 'docker run -i -t <image#> -v <host dir>:<container dir>'
And the problem solved...
dokeun is offline   Reply With Quote
centos 7, docker, openfoam, parallel
Error running openfoam in parallel fede32 OpenFOAM Programming & Development 5 October 4, 2018 17:38
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' muth OpenFOAM Running, Solving & CFD 3 August 27, 2018 05:18
Explicitly filtered LES saeedi Main CFD Forum 16 October 14, 2015 12:58
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 19:45
parallel Grief: BoundaryFields ok in single CPU but NOT in Parallel JR22 OpenFOAM Running, Solving & CFD 2 April 19, 2013 17:49
