PV coupling in OpenFoam
Like Tree2Likes
  • 2 Post By simrego
Old   February 3, 2019, 11:06
Default PV coupling in OpenFoam
YCarv is on a distinguished road
I apologize if this is a silly question, but I am new to OpenFoam.
Is there any solver that handles pressure-velocity equations in a fully-coupled manner ? (such as the 'Coupled' option in Fluent, for instance). I can't seem to find any.
Thank you !
YCarv is offline   Reply With Quote
Old   February 4, 2019, 05:21
anonymous
simrego is on a distinguished road
Hi!
There is a coupled solver but only in foam-extend. I'm not so familiar with this but you can find a brief explanation here:
http://www.tfd.chalmers.se/~hani/kur...15_NoPause.pdf
If you are using the foundation (v5, v6) or the esi group (v1806, v1812) version, you won't find a coupled solver. You can couple only the vectorial quantities. So for the velocity you can solve 3 equation, one for each direction, or you can solve them together, but you can't couple the p and U equations.
granzer and YCarv like this.
simrego is offline   Reply With Quote
Old   February 13, 2019, 19:22
I will try getting foam-extend and using this solver ! Thank you ! (:
coupled equations, coupled solver
Map of the OpenFOAM Forum - Understanding where to post your questions! wyldckat OpenFOAM 10 September 2, 2021 06:29
OpenFOAM v3.0+ ?? SBusch OpenFOAM 22 December 26, 2016 15:24
OpenFOAM for subsurface flow, or coupling with a subsurface flow code? chljl OpenFOAM Running, Solving & CFD 0 February 14, 2012 20:38
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 07:25
coupling OpenFOAM with other programs Martin123 OpenFOAM Running, Solving & CFD 3 June 3, 2009 19:13
