non-Orthogonal correction for a rungeKutta solver |
Vu
Rep Power: 9 ![]() |
Dear Foamers,
I implemented a Navier-Stokes solver using a 3 step Runge-Kutta scheme following these steps: 1.png The solver works fine with orthogonal mesh as I validated it with the lid-driven cavity. However, when it comes to the flow over cylinder problem, where the mesh consists of multi-block and is non-orthogonal, the simulation diverged. The results before it crashed: 2.png As far as I know with simpleFoam or pisoFoam, nonOrthogonality can be treated by choosing a corrected scheme for the laplacianSchemes and the snGradSchemes, along with nonOrthogonalCorrectors loops. In my current solver, it clearly doesn't need non-Orthogonal correction loops. I think that when choosing the corrected scheme, the correction term would be automatically evaluated in the discretization process of the laplacian term. So I expected the following setup would work, but it doesn't: Code:
ddtSchemes { default Euler; } gradSchemes { default Gauss linear; } divSchemes { default none; div(phi,U) Gauss linearlimitedLinearV 1; div(phi,k) Gauss limitedLinear 1; div(phi,epsilon) Gauss limitedLinear 1; div(phi,R) Gauss limitedLinear 1; div(R) Gauss linear; div(U) Gauss linear; div(phi,nuTilda) Gauss limitedLinear 1; div((nuEff*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; interpolate(U) linear; } snGradSchemes { default corrected; } Am I wrong about the corrected scheme? I would appreciate any suggestion! |
Vu
Here is the main loop of the solver:
while (runTime.run()) { #include "readTimeControls.H" #include "CourantNo.H" #include "setDeltaT.H" runTime++; Info<< "Time = " << runTime.timeName() << nl << endl; const dimensionedScalar dT = runTime.deltaT(); for(int k=1; k<nStep+1; k++) { //.1- Explicitly calculate u tildle. if (k==1) { Uk_1 = U.oldTime(); pk_1 = p.oldTime(); surfaceScalarField phik_1 ( "phik_1", linearInterpolate(Uk_1) & mesh.Sf() ); U_tildle = Uk_1 + dT*( 2.0*alpha[k]*nu*fvc::laplacian(Uk_1) - 2.0*alpha[k]*fvc::grad(pk_1) - gamma[k]*fvc::div(phik_1, Uk_1) ); } else { surfaceScalarField phik_1 ( "phik_1", linearInterpolate(Uk_1) & mesh.Sf() ); surfaceScalarField phik_2 ( "phik_2", linearInterpolate(Uk_2) & mesh.Sf() ); U_tildle = Uk_1 + dT*( 2.0*alpha[k]*nu*fvc::laplacian(Uk_1) - 2.0*alpha[k]*fvc::grad(pk_1) - gamma[k]*fvc::div(phik_1, Uk_1) - zeta[k]*fvc::div(phik_2, Uk_2) ); } //2. calculating UStar volVectorField UStar(U); forAll(UStar.internalField(), cellI) { UStar[cellI] = vector::zero; } fvVectorMatrix UStarEqn ( fvm::laplacian(UStar) ); for (label i=0; i<mesh.nCells(); i++) { UStarEqn.diag()[i] -= mesh.V()[i]/(alpha[k]*nu.value()*dT.value()); } solve ( UStarEqn == - (U_tildle/dT + ibForce_ + gradP)/(nu*alpha[k]) + fvc::laplacian(Uk_1) ); //3. Solve for immediate pressure volScalarField pImd(p); forAll(pImd.internalField(), cellI) pImd[cellI] = 0.0; fvScalarMatrix pImdEqn ( fvm::laplacian(pImd) == fvc::div(UStar)/(2.0*alpha[k]*dT) ); pImdEqn.solve(); //4. Correct velocity Uk = UStar - 2.0*alpha[k]*dT*fvc::grad(pImd); //5. Update pressure pk = pk_1 + pImd - alpha[k]*nu*dT*fvc::laplacian(pImd); Uk_2 = Uk_1; Uk_1 = Uk; pk_1 = pk; } U = Uk; p = pk; #include "continuityErrs.H" phi = fvc::flux(U); U.correctBoundaryConditions(); runTime.write(); Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s" << " ClockTime = " << runTime.elapsedClockTime() << " s" << nl << endl; } |
Santiago Lopez Castano
Rep Power: 15 ![]() |
Which is the source/article on which you base the algorithm?
Vu
Hi Santiago,
Its been a while and until now I have time to back to this work. Actually, I was implementing the immersed boundary method as in this journal: https://arxiv.org/abs/1809.08170 The immersed boundary technique, however, does not work well with the PISO algorithm as I expected. That's why I wanted to try it with the 3step runge Kutta described in the article. |
PEMFC model with FLUENT | brahimchoice | FLUENT | 22 | April 19, 2020 15:44 |
Divergence detected in AMG solver: pressure correction | CMICT | FLUENT | 4 | June 14, 2016 12:08 |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 20:02 |
why the solver reject it? Anyone with experience? | bearcat | CFX | 6 | April 28, 2008 14:08 |
Explicit Solver and pressure correction | hjasak | OpenFOAM Running, Solving & CFD | 1 | October 5, 2006 07:16 |
