Error in heat conduction rate calculation in OpenFOAM while using rhoCentralFOAM |
Gaurav Kumar
Rep Power: 0 ![]() |
Hello!
This chunk of code represents viscous correction for energy equation in rhoCentralFoam solver in OpenFOAM-dev. Code:
if (!inviscid) { solve ( fvm::ddt(rho, e) - fvc::ddt(rho, e) - fvm::laplacian(turbulence->alphaEff(), e) ); thermo.correct(); rhoE = rho*(e + 0.5*magSqr(U)); } So, above equation effectively translates into ![]() But, it should be only ![]() Since, it would not make much difference if ![]() ![]() I have same question regarding calculation of wallHeatFlux. Should it be calcWallHeatFlux(turbModel.alphaEff(), turbModel.transport().he()) or calcWallHeatFlux(turbModel.kappaEff(), turbModel.transport().T()) in file https://github.com/OpenFOAM/OpenFOAM...wallHeatFlux.C at line 220 Thanks Last edited by Daedalus; January 29, 2019 at 05:57. Reason: formating error |
janafthermo, rhocentralfoam, wallheattransfer |
OpenFOAM Heat Insulation Boundary Condition for Heat Conduction in Solids | abkahraman | OpenFOAM Running, Solving & CFD | 3 | August 15, 2020 10:11 |
Heat Release vs. Apparent Heat Release // Comparison with GT Power | MFGT | CONVERGE | 10 | August 17, 2016 02:38 |
Problem with total heat transfer rate | aswathy_raghu | FLUENT | 0 | July 26, 2016 07:39 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
