concerning the fvOptions of explicitPorositySource |
January 28, 2019, 01:30 |
Rep Power: 13 |
Hi, everyone here, I have some questions about the default fvOptions of explicitPorositySource.
What I was trying to solve was a tube reactor filled with catalyst, so I applied a explicitPorositySource to simulate the DarcyForchheimer law. The result seems very good and no problem. But when I reading the code, I was confused. I found a reference called "Porous Media in OpenFOAM" written by Haukur Elvar Hafsteinsson. In the file, he gave the momentum equation like in which the Si represents the porous resistance calculated by explicitPorositySource, and there is a porosity(Gamma) appearing in the time derivative term. However, the code of the solver is like in which the time derivative term do not contain the porosity. So, does anyone know why is this? Does this mean that if I want to simulate a porous media, I just set the explicitPorositySource, and do not need to modify the time derivative term in other equations such as the mass and species and energy equations? Thanks |
July 31, 2019, 09:45 |
#2 | |
Honey
Rep Power: 15 |
Hi, I have a similar question. In fvOptions, we have the option to define the Darcy and Forcheimer coefficients for the momentum sink term, as well as the porosity (Gamma) which appears in the time derivative term. However, I noticed that by specifying various different porosity ranging from 0.5 to 0.99, there is no change in the solution. So, does this mean that the porosity defined in fvOptions is not used in the time derivative term of a transient solver (i.e. pimpleFoam)?? B.R. Honey |
August 9, 2019, 04:24 |
Rep Power: 13 |
Which fvOptions you used? I used explicitPorositySource, and found that I have nowhere to specify porosity (Gamma). The only coefficients I can change is d and f and coordinateSystem. if you change the Darcy and Forcheimer coefficients accordingly when porosity changes, then the solution should change, such as the pressure drop. |
March 10, 2020, 10:58 |
#4 | |
roshan
Rep Power: 7 |
Yes, I noticed that by changing porosity form 0.9,0.7-0.5, nothings is changed.
June 1, 2021, 06:18 |
#5 | |
pop
Rep Power: 16 |
D is actually the porosity/permeability. so modify the value of D to apply porosity. |
July 10, 2023, 14:27 |
Constant Value
Vittorio Nardin
Rep Power: 3 |
What constant is C2 and what is its value?
interFoam and scalarTransport function object with fvOptions sources | fusij | OpenFOAM Running, Solving & CFD | 4 | April 18, 2022 08:12 |
Can I use fvOptions to couple a solid region and a fluid region? | titanchao | OpenFOAM Running, Solving & CFD | 4 | January 14, 2022 08:55 |
fvMatrix, fvOptions and SuSp: automatic implicit/explicit source-term treatment | Zeppo | OpenFOAM Programming & Development | 7 | December 15, 2021 11:20 |
New output variable for source term in fvoptions - without changing the solver | vincent.clary | OpenFOAM Programming & Development | 2 | June 26, 2018 06:21 |
problem with fvOptions in twophase eulerfoam | Hamzeh_Mirab | OpenFOAM Running, Solving & CFD | 0 | January 27, 2015 12:04 |
