compressible k-epsilon model in OpenFOAM
Like Tree1Likes
  • 1 Post By cryabroad
Old   January 28, 2019, 00:48
Default compressible k-epsilon model in OpenFOAM
Ruiyan Chen
cryabroad is on a distinguished road
Recently I've been looking into the k-epsilon model in OpenFOAM, and quite confused based on what is shown here https://www.openfoam.com/documentati...k-epsilon.html.
In the above link, it says the standard k-epsilon model solves the transport equations of k and epsilon as shown in the StandardkEpsilon.png figure, while OpenFOAM solves the ones shown in the OpenFOAMkEpsilon.png figure. I noticed that the standard one is also used by ANSYS Fluent.
For constant density flows without buoyancy forces, Gb in the k equation from the standard k-epsilon model vanishes, and div(u) = 0. The two forms of the k-epsilon model are exactly the same. However, for variable density flows without buoyancy forces, although Gb goes away, div(u) is in general not equal to 0. Does this suggest that Fluent will give a wrong solution but OpenFOAM will produce a right one because it explicitly takes into account effects of the variable density?
Thanks in advance.
simrego likes this.
cryabroad is offline   Reply With Quote
compressible, k-epsilon model
OpenFOAM v3.0+ ?? SBusch OpenFOAM 22 December 26, 2016 15:24
Blow of compressible solver while using K-epsilon model in openfoam Amit Mathur OpenFOAM 16 October 6, 2013 12:09
OpenFOAM: LES turbulence model names Ollie OpenFOAM 5 January 7, 2013 11:24
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 07:55
OpenFOAM: LES turbulence model names Ollie Main CFD Forum 1 April 11, 2011 14:03
