Strange behavior of water surface near solid body
Like Tree1Likes
  • 1 Post By vatavuk
Old   January 14, 2019, 14:57
Unhappy Strange behavior of water surface near solid body
Justine
JBrake is on a distinguished road
I am experiencing strange initial behavior of my water surface near a solid body at the beginning of my simulation.
The water level starts out flat from setFields, and I took away the waves that I will eventually be including. Even with calm initial conditions, the water level dips near the solid flap (the flap is hinged at the bottom so that it may rotate).
My boundary conditions on the flap are movingWallVelocity for U, and similar to a normal wall for all others.
I am using rigidBodyMotion solver to generate movement of the flap, and an AMI patch rotates a cylindrical portion of the mesh surrounding the flap. In previous simulations, I used a prescribed motion of the flap (with constant rotational velocity) and did not experience the strange initial water surface behavior.
JBrake is offline   Reply With Quote
Old   January 15, 2019, 09:18
Paulo Vatavuk
vatavuk is on a distinguished road
Hi Justine,
See the link below for instructions on how to include an image in a post:
Picture doesn't appear
Best Regards,
Paulo
JBrake likes this.
vatavuk is offline   Reply With Quote
Old   January 15, 2019, 19:07
Justine
Thanks, I have posted an image. As an update, this water surface issue occurs even when I go back to a prescribed flap motion and set the angular velocity to zero (so indeed there is no flap motion, yet still a disturbance near the flap). I am trying to retrace my steps and determine what is causing this issue. Any help would be greatly appreciated.
Old   January 16, 2019, 06:37
Peter Baskovich
pete20r2 is on a distinguished road
Why movingWallVelocity? Seems wrong to me.
pete20r2 is offline   Reply With Quote
Old   January 16, 2019, 14:14
Justine
I used movingWallVelocity based on a tutorial case that had a floating object or something of that nature (it might have been the propeller case). Like everything I try to do with OpenFOAM, I find examples and work from there.
The flap is a moving solid body and needs to rotate about a "hinge" point, which happens to be the origin in my model.
Old   January 16, 2019, 17:12
Justine
I have removed the flap entirely and found that the behavior continues. It is likely due to the circular AMI. If I plot velocity, there is definitely something going on around the AMI when it shouldn't be.
Old   January 16, 2019, 18:51
Default checkMesh
Justine
Additional information: when I run checkMesh, it "Failed 1 mesh checks" but it doesn't say which check it failed. Does it have to do with "***Number of edges not aligned with or perpendicular to non-empty directions: 24057"? Here is a picture of the circular/cylindrical part of the mesh:
Could it be it simply needs more refinement, or is something else possible going wrong with the AMI?
No conjugate heat transfer between solid (cast iron) and fluid (water) part Rajaero FLUENT 5 June 25, 2023 04:07
Propulsion of solid body in two phases Nautiker87 OpenFOAM Pre-Processing 0 September 29, 2017 07:45
[DesignModeler] Boolean Subtract of a body and a surface KrishnaSandeep ANSYS Meshing & Geometry 2 April 1, 2015 16:55
Rigid Body State Variables in Solid Immersed Simulation Hamidreza CFX 1 October 19, 2009 07:14
uptodate water distribution network fredius,magige,tanzanian,(e.a) Main CFD Forum 0 January 27, 2002 08:10
