Conjugate Heat transfer for Incompressible Fluids
Like Tree2Likes
  • 1 Post By pete20r2
  • 1 Post By Bloerb
Old   January 1, 2019, 02:29
Post Conjugate Heat transfer for Incompressible Fluids
Shiromani Chandra
shiromaniac is on a distinguished road
Hello Everyone!
I am new to OpenFOAM and I am currently working on chtmultiregionSimpleFoam and chtmultiregionfoam. Both the solvers mentioned are meant for compressible fluids but I need to run these solvers for incompressible fluids. What should I do? Does anyone have done this before( I bet many of you must have)? Please Help!
shiromaniac is offline   Reply With Quote
Old   January 1, 2019, 07:10
Peter Baskovich
pete20r2 is on a distinguished road
Hi Shiromani, the last time I set up a case like this I recompiled the solver to use heThermo instead of psiThermo. Then you can use the const settings in thermophysicalProperties or polynomial functions if you wish.
shiromaniac likes this.
pete20r2 is offline   Reply With Quote
Old   January 1, 2019, 09:02
Bloerb will become famous soon enough
simply run them with incompressible settings inside thermoPhysicalProperties (rho=const) and you are good.
Bloerb is offline   Reply With Quote
Old   January 2, 2019, 01:01
Post
Shiromani Chandra
Hey Bloerb,
Happy New Year and Thank you so much! It is of great help. Could you please also tell me if I want to do Forced Convection Conjugate heat transfer what should I do?? Thanks in advance!
Old   January 2, 2019, 03:48
Well heat transfer can happen by natural and forced convection inside a liquid. Lets look at how this effects the motion of the fluid:
\frac{\partial \rho\mathbf{v}}{\partial t} + \mathbf{v}\cdot\nabla(\rho  \mathbf{v}) =-\nabla p + \nabla\cdot T + f
Natural Convection
  • Happens due to temperature depended density differences and gravity
  • Hence enters the momentum balance via rho and f
  • Temperature changes the fluid flow
Forced convection
  • Happens due to pressure gradients
  • Temperature does not change the fluid flow since the pressure gradient is not caused by a temperature difference but e.g a pump.
Since you have already set the density to constant and hence incompressible flow you have already eliminated free convection. This is also why all heat transfer solvers are compressible inside OF. If you are solving incompressible flow, heat transfer and fluid flow are not coupled. This means fluid flow will be the same with or without heat transfer (assuming that your liquids properties are not temperature depended e.g temperature depended viscosity).
Hence you can use the chtMultiRegion class of solvers for forced and natural convection. You "simply" need to create your mesh and choose the right boundary conditions.
Old   June 17, 2019, 07:39
Raza Javed
Raza Javed is on a distinguished road
Natural Convection
Forced convection
Your answer is very helpful for my case also. because I am also stuck in incompressible and compressible thing.
I have heat transfer and fluid flow also. The walls of the fluid region are hot and fluid is flowing from inlet and outlet. and it must take this heat out at the outlet.
So, in this case, if I set (rho = constant) in constant/fluid/thermophysicalProperties, it means that my flow is incompressible NOW, and there is no coupling between fluid flow and heat transfer?
And in case I want to simulate compressible flow, then what should I write for "rho" in themophysicalProperties?
I shall be very thankful if you can clear my doubts.
Thank you
Raza Javed is offline   Reply With Quote
Old   June 17, 2019, 08:25
Yes, if rho is set to constant your flow solution does not depend on temperature. If you want to simulate something compressible you need to switch from rhoConst to e.g perfectGas or one of the many other possibilities:
https://cfd.direct/openfoam/user-gui...hermophysical/
Old   June 17, 2019, 09:17
Raza Javed
Thank you so much for your help.
I have one question here, when I set these options, then how to decide the rhomax and rhomin in the system/fluid/fvSolutions file?
because before I was using (rho = 1000) in constant/thermophysicalProperties, so I set the rhomax and rhomin = 1000, but now I changed the rho from constant to icoPolynomial.
Old   June 17, 2019, 10:49
Well you need to set a maximal and a minimal value that could occour in your simulation.
For example 0 and 10000000000000 would suffice. Setting closer ranges might make it more stable during start up
For water with rho from 900 to 1100 e.g 700 and 2000 for stability
Old   June 17, 2019, 11:16
Raza Javed
Hi.
Thank you so much. It was very helpful.
Thank you once again.
Regards
Raza
Old   June 19, 2019, 07:09
Raza Javed
I have one question relating to relaxation factor.
1. What is relaxation factor and what is under relaxation?
2. How can we decide that what value of relaxation factor do we need?
3. what is the upper and lower limit of relaxation parameter? OR we can put any value?
4. In my simulation, when I reduced the relaxation factor to a very very lower value then my residuals goes to minimum value very fast.
But I couldn't exactly get, that how relaxation factor affecting my simulation and how can I change it to get the desired results.
I shall be thankful for your help.
Thank you
Old   June 19, 2019, 08:45
If you do not know what a relaxation factor is, you should not do numerical simulations. That is the harsh truth. The more modest response would be to not touch them, since the standard values are fine. And in this case it is not to much to ask to google it and read a wikipedia article.
Old   August 8, 2019, 06:52
Default Explaination to Underrelaxation
  #13
Owais Shabbir
Owais Shabbir is on a distinguished road
Originally Posted by Raza Javed View Post
Thank you
I will try to give basic explaination. And Bloerb is right you should invest sometime in learning the basic about convergence, residuals and underrelaxation (U).
residual_new = residual_old + U (residual_new_predicted - residual_old)
So underrelaxation factors are basically to supress the oscillation in the flow solution. These osciallation are a result of numerical errors.
Smaller the underrelaxation means, for sake of the simplicity lets say, allowed to much of 'acceptance' to have errors in your solution. The residuals will start to converge and you might think the solution is converged when in reality it is not.
Recommended is to use as high as possible. But note high underrelaxation lead to oscillation in the solution so that's why as high as possible so you don't have oscillations. If you are studying the tutorials and do not wish to learn about the convergence rate, I'd say they are already good.
U < 1 means underrelaxation. Slows down speed of convergence but increases stability (Hence in your case residuals reach low value)
U=1 means no relation. Good for predicting values of the variable
U>1 means over relaxation. Good if you want to accelerate your convergence but decreases the stability
Hope this helps.
OS
Owais Shabbir is offline   Reply With Quote
Old   April 22, 2020, 16:43
ardim is on a distinguished road
Well, that’s not true if you are modeling natural convection in incompressible air with the Boussinesq approximation. I’ve opened a new thread, asking for examples, here: Example or tutorial suitable for this buoyancy coupled problem?
Does this mean there’s no solver in OpenFoam for solving a model like the one in that thread? (actually the conjugate heat transfer could be very simple in my model: radiation from walls to other walls could be ignored, and the temperature in the contiguous rooms can be assumed a constant value).
Thank you very much for any help you could provide!!
ardim is offline   Reply With Quote
chtmultiregionfoam, chtmultiregionsimpefoam, conjugate heat transfer, openfoam
conjugate heat transfer in OpenFOAM skuznet OpenFOAM Running, Solving & CFD 99 March 16, 2017 06:07
Heat Transfer with supercritical fluids anon_l STAR-CCM+ 4 November 24, 2016 03:40
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
Conjugate heat transfer and radiation modeling questions shankara.2 FLUENT 0 April 21, 2009 16:55
Conjugate heat transfer problem with porous media piko Siemens 1 April 17, 2009 16:41
