Simulation just stops output writing, but keeps running
Like Tree2Likes
  • 2 Post By blaise
Old   December 20, 2018, 09:55
Default Simulation just stops output writing, but keeps running
P.A.
blaise is on a distinguished road
Hello all,
I am stumbling across a weird issue when running a certain parallel case in OFv1712. The simulation stops writing any output at a certain time step (in time step 1.165 s of simulation time), but keeps running on the involved CPUs. Looking at what the processes are doing I get the following output:
poll([{fd=6, events=POLLIN}, {fd=14, events=POLLIN}], 2, 0) = 0 (Timeout)
The solver endlessly repeats these poll system calls forever and does not return.
The case is run with an overWaveDyMFoam solver which I fiddled together from the waves2Foam (of Niels Gjoel Jacobsen) package and overInterDyMFoam. This solver already run successfully on several different test cases I set up before the one at hand.
What I did try until now:
- Running the case locally parallel to exclude any nfs related issues
- Running the case on a single CPU
- Running the case on other computers
- Changing fixed time steps, changing to dynamic time step
- Changing the number of partitions
Everything to no avail: The simulation keeps stopping to write output every time at the very same situation.
The usual output of the last time step - i.e. the time step this issue occurs in - looks like:
Time = 1.165
PIMPLE: iteration 1
forces forces:
    Not including porosity effects
6-DoF rigid body motion
    Centre of rotation: (-2.335 0 0.194664)
    Centre of mass: (-2.335 0 0.194664)
    Orientation: (0.999663 0 0.0259474 0 1 0 -0.0259474 0 0.999663)
    Linear velocity: (0 0 -0.0109389)
    Angular velocity: (0 -0.111191 0)
    Euler angles: (0 1.48684 0)
inverseDistance : detected 2 mesh regions
    zone:0 nCells:755040  voxels:(53 53 53) bb:(-30 -4.50004 -4.24004) (3.27277 4.50004 4.00004)
    zone:1 nCells:435686  voxels:(53 53 53) bb:(-150 -22.5001 -20.7201) (-89.9999 -13.4999 -12.4799)
Overset analysis : nCells : 1190726
    calculated   : 1154246
    interpolated : 24794 (interpolated from local:0  mixed local/remote:0  remote:24794)
    hole         : 11686
Execution time for mesh.update() = 10.34 s
smoothSolver:  Solving for alpha.water, Initial residual = 2.38881e-05, Final residual = 1.53679e-09, No Iterations 1
Phase-1 volume fraction = 0.533664  Min(alpha.water) = -5.76508e-09  Max(alpha.water) = 1.00002
MULES: Correcting alpha.water
Phase-1 volume fraction = 0.533664  Min(alpha.water) = -1.93627e-06  Max(alpha.water) = 1.00002
smoothSolver:  Solving for alpha.water, Initial residual = 2.388e-05, Final residual = 1.54164e-09, No Iterations 1
Phase-1 volume fraction = 0.533664  Min(alpha.water) = -6.33039e-09  Max(alpha.water) = 1.00002
Phase-1 volume fraction = 0.533664  Min(alpha.water) = -2.05242e-06  Max(alpha.water) = 1.00002
I have attached a text file containing the output when I turn on several debug switches, but actually I am not sure what switches to turn on for an effective analysis of the problem...
Any hint is appreciated!
Best regards,
Pascal.
mbots and tuncm18 like this.
blaise is offline   Reply With Quote
Old   June 26, 2022, 11:14
gfilip is on a distinguished road
Hi Pascal,
This is an old post but I'm curious if you ever resolved this mysterious overset stopping? I too see this behavior with a waves2Foam + overInterDyMFoam solver or just a pure interDyMFoam solver. I saw in another post (overInterDyMFoam stops without error message) a similar problem that was resolved by making the bottom boundary a slip condition, which seems odd.
Anyway, please let me know if you ever found the source of the problem or a solution.
Thanks
gfilip is offline   Reply With Quote
Old   August 5, 2022, 04:02
Tunc
tuncm18 is on a distinguished road
I am also facing with the same problem. My dsmcFoam+ solver is also giving same treatment, analysis running but there is no output. I am trying to solve my problem with changing boundary conditions, I will update here.
tuncm18 is offline   Reply With Quote
Old   August 5, 2022, 05:25
Tunc
Apparently there is something wrong with my initialize dictionary. At first I was setting initial velocity and initial particle number to zero. After I change initial values to my supposedly final values it worked. But before that, serial analysis was working without any problem, only parallel analysis was stuck. I think it might be related to some kind of weird bug.
I will check mean Courant number, max Courant number and min Courant number to see anything wrong with it.
Old   April 14, 2023, 07:59
Default overwavedymfoam
Yinyin
Yiny is on a distinguished road
Hi, did you succeed in coupling the slovers of waves2foam and overinterdymfoam? I am also trying this work and have encountered an unsolvable problem:
I finished compiling overwavedymfoam and no error was reported. But when I run a case, I find the case diverged after 35s which is close to stability. I tried various modifications but couldn't change the divergence phenomenon and the version of OpenFoam I used is OF2206. Can you give me some advice? Thanks.
I will attach my case and solver below.
Yiny is offline   Reply With Quote
Old   March 25, 2024, 07:43
Default Same issue
Ashok Kumar
ashkum2527 is on a distinguished road
I face the same problem now. my simulation shows it is running but no new values are printed. Did you debug this error? I use dsmcFoam+ solver to simulate flow through micronozzle operating at exit vacuum condition.
ashkum2527 is offline   Reply With Quote
Old   March 27, 2024, 05:49
Tunc
Unfortunately not. I discovered dsmcFoam+ just waits before writing new positions in processor files after some time. As a crude solution, I send my analyzes with time limit and delete last written writing interval before sending them again.
Hope it helps.
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 03:36
[Other] refineWallLayer Error Yuby OpenFOAM Meshing & Mesh Conversion 2 November 11, 2021 12:04
Slow Running Simulation rsoni451 CONVERGE 10 September 15, 2017 10:20
Simulation stops and starts randomly Galactus OpenFOAM 1 July 30, 2017 22:14
Output Excel File in Transient Simulation Soon CFX 5 July 11, 2005 07:11
