Setup of cyclicAMI in chtMultiRegionSimpleFoam
Like Tree3Likes
  • 3 Post By pete20r2
Old   December 9, 2018, 08:05
Default Setup of cyclicAMI in chtMultiRegionSimpleFoam
charles
chuck2018 is on a distinguished road
Dear Sir /Madam,
I have a simple geometry consisting of a small cyllinder inside a large rectangular box. Pretty much it is a flow over a cylinder. The 2D case is of interest so the faces in the z direction was set to empty. I am trying to setup a cyclicAMI boundary conditions for the top and bottom surface. The solver is chtMultiRegionSimpleFoam I have been stuck on the following error for a long time now. Any assistance would be appreciated. Thanks.
Error code using the command
PHP Code:
Create time
--> FOAM Warning :
    From function static Foam::IOstreamOption::compressionType Foam::IOstreamOption::compressionEnum(const Foam::word&)
    in file db/IOstreams/IOstreams/IOstreamOption.C at line 86
    Unknown compression specifier 'uncompressed', assuming no compression
Create fluid mesh for region Air for time = 0
Create solid mesh for region cylinder for time = 0
*** Reading fluid mesh thermophysical properties for region Air
    Adding to thermoFluid
Selecting thermodynamics package
    type            heRhoThermo;
    mixture         pureMixture;
    transport       const;
    thermo          hConst;
    equationOfState perfectGas;
    specie          specie;
    energy          sensibleEnthalpy;
AMI: Creating addressing and weights between 125 source faces and 125 target faces
--> FOAM Warning :
    From function void Foam::AMIMethod<SourcePatch, TargetPatch>::checkPatches() const [with SourcePatch = Foam::PrimitivePatch<Foam::face, Foam::SubList, const Foam::Field<Foam::Vector<double> >&>; TargetPatch = Foam::PrimitivePatch<Foam::face, Foam::SubList, const Foam::Field<Foam::Vector<double> >&>]
    in file lnInclude/AMIMethod.C at line 57
    Source and target patch bounding boxes are not similar
    source box span     : (0.25 0 0.01)
    target box span     : (0.25 0 0.01)
    source box          : (-0.075 -0.05 0) (0.175 -0.05 0.01)
    target box          : (-0.075 0.05 0) (0.175 0.05 0.01)
    inflated target box : (-0.08751 0.03749 -0.01251) (0.18751 0.06251 0.02251)
--> FOAM FATAL ERROR:
Unable to find initial target face
    From function bool Foam::AMIMethod<SourcePatch, TargetPatch>::initialise(Foam::labelListList&, Foam::scalarListList&, Foam::labelListList&, Foam::scalarListList&, Foam::label&, Foam::label&) [with SourcePatch = Foam::PrimitivePatch<Foam::face, Foam::SubList, const Foam::Field<Foam::Vector<double> >&>; TargetPatch = Foam::PrimitivePatch<Foam::face, Foam::SubList, const Foam::Field<Foam::Vector<double> >&>; Foam::labelListList = Foam::List<Foam::List<int> >; Foam::scalarListList = Foam::List<Foam::List<double> >; Foam::label = int]
    in file lnInclude/AMIMethod.C at line 127.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::error::abort() at ??:?
#2  Foam::AMIMethod<Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> >, Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > >::initialise(Foam::List<Foam::List<int> >&, Foam::List<Foam::List<double> >&, Foam::List<Foam::List<int> >&, Foam::List<Foam::List<double> >&, int&, int&) at ??:?
#3  Foam::faceAreaWeightAMI<Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> >, Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > >::calculate(Foam::List<Foam::List<int> >&, Foam::List<Foam::List<double> >&, Foam::List<Foam::List<int> >&, Foam::List<Foam::List<double> >&, int, int) at ??:?
#4  Foam::AMIInterpolation<Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> >, Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > >::update(Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&, Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&) at ??:?
#5  Foam::AMIInterpolation<Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> >, Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > >::constructFromSurface(Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&, Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&, Foam::autoPtr<Foam::searchableSurface> const&) at ??:?
#6  Foam::cyclicAMIPolyPatch::resetAMI(Foam::AMIInterpolation<Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> >, Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > >::interpolationMethod const&) const at ??:?
#7  Foam::cyclicAMIPolyPatch::AMI() const at ??:?
#8  Foam::cyclicAMIPolyPatch::applyLowWeightCorrection() const at ??:?
#9  Foam::cyclicAMIFvPatch::makeWeights(Foam::Field<double>&) const at ??:?
#10  Foam::surfaceInterpolation::makeWeights() const at ??:?
#11  Foam::surfaceInterpolation::weights() const at ??:?
#12  Foam::surfaceInterpolation::makeDeltaCoeffs() const at ??:?
#13  Foam::surfaceInterpolation::deltaCoeffs() const at ??:?
#14  Foam::fvPatch::deltaCoeffs() const at ??:?
#15  Foam::fvPatchField<double>::snGrad() const in ~/OpenFOAM/OpenFOAM-v1806/platforms/linux64GccDPInt32Opt/bin/chtMultiRegionSimpleFoam
#16  Foam::heThermo<Foam::rhoThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::heBoundaryCorrection(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&) at ??:?
#17  Foam::heThermo<Foam::rhoThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::init(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&) at ??:?
#18  Foam::heThermo<Foam::rhoThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::heThermo(Foam::fvMesh const&, Foam::word const&) at ??:?
#19  Foam::rhoThermo::addfvMeshConstructorToTable<Foam::heRhoThermo<Foam::rhoThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > > >::New(Foam::fvMesh const&, Foam::word const&) at ??:?
#20  Foam::autoPtr<Foam::rhoThermo> Foam::basicThermo::New<Foam::rhoThermo>(Foam::fvMesh const&, Foam::word const&) at ??:?
#21  Foam::rhoThermo::New(Foam::fvMesh const&, Foam::word const&) at ??:?
#22  ? in ~/OpenFOAM/OpenFOAM-v1806/platforms/linux64GccDPInt32Opt/bin/chtMultiRegionSimpleFoam
#23  __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6
#24  ? in ~/OpenFOAM/OpenFOAM-v1806/platforms/linux64GccDPInt32Opt/bin/chtMultiRegionSimpleFoam
Aborted (core dumped)
My "Air constant/plymesh/boundary' and "cylinder constant/plymesh/boundary" file are attached.
Current methodology used:
-Geometry exported to Openfoam using ideasUnvToFoam
-changed the "emptywalls" patch in constant/plymesh/boundary to "empty"
Run the command:
PHP Code:
splitMeshRegions -cellZones -overwrite
-Impliment cyclicAMI in " constant/Air/polymesh/boundary";
FoamFile
    version     2.0;
    format      ascii;
    class       polyBoundaryMesh;
    location    "constant/Air/polyMesh";
    object      boundary;
6
    inlet
        type            patch;
        nFaces          50;
        startFace       33892;
    outlet
        type            patch;
        nFaces          50;
        startFace       33942;
    emptyWalls
        type            empty;
        inGroups        1(empty);
        nFaces          40156;
        startFace       33992;
    bottom
        type            cyclicAMI;
        nFaces          125;
        startFace       74148;
    matchTolerance  0.0001;
    neighbourPatch  top;
        transform       noOrdering;
    top
        type            cyclicAMI;
        nFaces          125;
        startFace       74273;
    neighbourPatch  bottom;
    Air_to_cylinder
        type            mappedWall;
        inGroups        1(wall);
        nFaces          100;
        startFace       74398;
        sampleMode      nearestPatchFace;
        sampleRegion    cylinder;
        samplePatch     cylinder_to_Air;
After this I run the following two commands:
PHP Code:
changeDictionary -region Air
PHP Code:
changeDictionary -region cylinder
checkMesh gives the following result:
Create time
--> FOAM Warning :
--> FOAM Warning :
    From function static Foam::instantList Foam::timeSelector::select0(Foam::Time&, const Foam::argList&)
    in file db/Time/timeSelector.C at line 267
    No time specified or available, selecting 'constant'
Create mesh for time = constant
Time = constant
Mesh stats
    internal points:  0
    faces:            77703
    internal faces:   35337
    cells:            21008
    faces per cell:   5.380807
    boundary patches: 5
    point zones:      0
    face zones:       1
    cell zones:       2
Overall number of cells of each type:
    hexahedra:     8000
    prisms:        13008
    wedges:        0
    pyramids:      0
    tet wedges:    0
    tetrahedra:    0
    polyhedra:     0
Checking topology...
    Boundary definition OK.
    Cell to face addressing OK.
    Point usage OK.
    Upper triangular ordering OK.
    Face vertices OK.
    Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces...
    Patch               Faces    Points   Surface topology
    inlet               50       102      ok (non-closed singly connected)
    outlet              50       102      ok (non-closed singly connected)
    emptyWalls          42016    29360    ok (non-closed singly connected)
    bottom              125      252      ok (non-closed singly connected)
    top                 125      252      ok (non-closed singly connected)
Checking faceZone topology for multiply connected surfaces...
    FaceZone            Faces    Points   Surface topology
    cylinderSurface     100      200      ok (non-closed singly connected)
Checking basic cellZone addressing...
    CellZone            Cells        Points        BoundingBox
    Air                  20078        28528        (-0.075 -0.05 0) (0.175 0.05 0.01)
    cylinder             930          1032         (-0.01 -0.01 0) (0.01 0.01 0.01)
Checking geometry...
    Overall domain bounding box (-0.075 -0.05 0) (0.175 0.05 0.01)
    Mesh has 3 geometric (non-empty/wedge) directions (1 1 1)
    Mesh has 3 solution (non-empty) directions (1 1 1)
    Boundary openness (3.447573e-18 2.555959e-17 3.598241e-15) OK.
    Max cell openness = 7.67138e-16 OK.
    Max aspect ratio = 486.1139 OK.
    Minimum face area = 1.294343e-08. Maximum face area = 3.63502e-05.  Face area magnitudes OK.
    Min volume = 1.294343e-10. Max volume = 4.148001e-08.  Total volume = 0.00025.  Cell volumes OK.
    Mesh non-orthogonality Max: 21.23835 average: 2.974656
    Non-orthogonality check OK.
    Face pyramids OK.
    Max skewness = 0.3563187 OK.
    Coupled point location match (average 0) OK.
Mesh OK.
And them run chtMultiRegionSimpleFoam command.
chuck2018 is offline   Reply With Quote
Old   December 9, 2018, 14:44
Peter Baskovich
pete20r2 is on a distinguished road
You need to specify the position of the opposite patch since they are not in the same place.
Add:
transform translational;
separationVector (x y z);
to both AMI patches in boundary.
The vector should be the offset to the other patch.
lplooooo, chuck2018 and saidc. like this.
pete20r2 is offline   Reply With Quote
Old   December 10, 2018, 22:21
charles
Thanks you. Your solution solved this particular issue. So if there is a particular orientation, "no ordering" doesn't work?
Old   December 10, 2018, 22:48
Peter Baskovich
no ordering is for interfaces where the two patches are physically in the same place, such as a translational sliding interface or a rotating region (typically used for a fans local mesh to interface to global static mesh). This does not mean the mesh points are in the same place (hence we use AMI) but the overall patch surfaces should be very close. This is why you get the error about the bounding boxes not being similar, AMI is doing a quick check to see if the patches are in the same place.
Old   October 27, 2020, 11:05
ESI
ht2017 is on a distinguished road
Dear Sir /Madam,
PHP Code:
Create time
--> FOAM Warning :
    type            heRhoThermo;
    transport       const;
    thermo          hConst;
    specie          specie;
--> FOAM Warning :
FOAM aborting
Run the command:
PHP Code:
FoamFile
    version     2.0;
    format      ascii;
    object      boundary;
6
    inlet
        type            patch;
        nFaces          50;
        startFace       33892;
    outlet
        type            patch;
        nFaces          50;
        startFace       33942;
    emptyWalls
        type            empty;
        inGroups        1(empty);
        nFaces          40156;
        startFace       33992;
    bottom
        type            cyclicAMI;
        nFaces          125;
        startFace       74148;
    neighbourPatch  top;
    top
        type            cyclicAMI;
        nFaces          125;
        startFace       74273;
    Air_to_cylinder
        type            mappedWall;
        inGroups        1(wall);
        nFaces          100;
        startFace       74398;
PHP Code:
PHP Code:
Create time
--> FOAM Warning :
--> FOAM Warning :
Time = constant
Mesh stats
    internal points:  0
    faces:            77703
    cells:            21008
    boundary patches: 5
    point zones:      0
    face zones:       1
    cell zones:       2
    hexahedra:     8000
    prisms:        13008
    wedges:        0
    pyramids:      0
    tet wedges:    0
    tetrahedra:    0
    polyhedra:     0
    Point usage OK.
    Face vertices OK.
    Face pyramids OK.
Mesh OK.
do you resolve this problem? Now I am facing the same your problem. could you tell me how to fix it?
ht2017 is offline   Reply With Quote
Old   May 3, 2021, 06:47
Peter Baskovich
The quoted message is resolved, is your problem different to the OP?
Using createPatch and cyclicAMI in FOAM Extend to create periodicbox manuc OpenFOAM Running, Solving & CFD 1 April 12, 2022 12:36
cyclicAMI - kOmegaSST - divergence issue cyln OpenFOAM Running, Solving & CFD 1 October 5, 2018 11:06
time step continuity problem in VAWT simulation lpz_michele OpenFOAM Running, Solving & CFD 5 February 22, 2018 20:50
cyclic / cyclicAMI boundary conditon - ICEM Mesh cyln OpenFOAM Running, Solving & CFD 0 November 7, 2017 16:26
Boundary Layer strange result fernexda OpenFOAM Running, Solving & CFD 14 January 15, 2015 08:21
