David
Rep Power: 7 ![]() |
Hello all,
I need to simulate the filling process of a basin under atmospheric conditions. I guess it's really not that difficult but as a beginner I do not really progress. I've built a simplification of my original geometry in FreeCAD and meshed it with gmsh. I chosed the blue sides as inlet and the black walls as wall. Now that the basin shall get filled with 3m³/s I don't want to define an outlet. But trying to solve it with simpleFoam doesn't work because of the missing outlet it says. Is it even possible to do a simulation without outlet in simpleFoam and if yes what boundary conditions do I have to select for the outlet? freecad.JPG Below I'll post an example of the case I have to simulate. Would be very thankful if someone could give me some specific advices for such a case. I'm really struggling. Bildschirmfoto 2018-11-28 um 23.13.50.JPG Tanks a lot Dave |
ssa
Try with interFoam.
Rep Power: 11 ![]() |
Hi Fool,
I'm no expert, but here are some thoughts: 1) simpleFoam is a steady-state solver, and yours is a transient situation. You need a transient solver. 2) When the water comes in, the corresponding amount of air must leave (or be compressed). If it leaves, you need an outlet. 3) You have two fluids in your simulation (water and air), so (as far as I know) you need a multiphase solver. Looking at https://www.openfoam.com/documentati...rd-solvers.php, and assuming you don't need (and therefore don't want) compressible effects, I think interFoam looks like something to explore. Good luck! Ed |
#4 | |
Robert
Rep Power: 12 ![]() |
with most of the OpenFoam solvers it is assume that you numerical domain is filled with water/air/... . E.g. you can define an inlet as a velocity inlet accelerating the water within your domain, but it will allways be full of water. As such it needs an outlet the pressure can be released somewhere and the volume that comes in has to go out somewhere. Keyword: Navier-Stokes eqn., conservation laws. Imagine a close cube and you attach a hose to a hole in the top to fill your cube. Remember a OpenFoam cube will allways be filled. Without a release the pressure in your cube would rise unti it bursts at some point. If you want to simulate the filling of an air-filled domain with water you will need a multiphase solver that can capture the air/water interface.
If you liked my answer to your question, please consider leaving a "Like" in return ![]() |
David
Thanks for your help.
I now tried interfoam and the results are getting better. But I do have a problem with the boundary conditions for my inlet. In my case the whole basin shall be filled with air at time 0 and after that a constant flow of 3m³/s shall flow into the basin. But the only possibility I see is to set alpha.water=1 for the inlet and U to flowrateinletvelocity with a volumetricflowrate of 3, but then the whole inlet is full of water and it doesn't really rises from the bottom as a flow in reality would do, which I guess is not the perfect solution. I will post the files below (laminar case). I tried to play around with variableHeightFlowRateInletVelocity and variableHeightFlowRate but then I either get an error message in openFoam or no solution for alpha.water that can be displayed in paraview. Does anyone know if it is even possible to simulate it as I imagine it and is it maybe more useful to work with a velocity instead of the volumetricflowrate? And can someone explain me the variableHeightFlowRate condition and what the upper and the lower bound stands for? /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object p_rgh; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 0.0; boundaryField { wall { type fixedFluxPressure; value uniform 0.0; } atmosphere { type totalPressure; p0 uniform 0.0; } inlet { type fixedFluxPressure; gradient uniform 0.0; } defaultFaces { type empty; } } // ************************************************** *********************** // /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object alpha.water; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 0 0 0 0 0]; internalField uniform 0.0; boundaryField { wall { type zeroGradient; } atmosphere { type inletOutlet; inletValue uniform 0.0; value uniform 0.0; } inlet { type fixedValue; value uniform 1; } defaultFaces { type empty; } } // ************************************************** *********************** // /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volVectorField; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0.0 0.0 0.0); boundaryField { wall { type fixedValue; value uniform (0 0 0); } atmosphere { type pressureInletOutletVelocity; value uniform (0 0 0); } inlet { type fixedValue; value (1 0 0); } defaultFaces { type empty; } } // ************************************************** *********************** // |
ssa
I think the problem is not with boundary conditions, but with the geometry. Instead of selecting whole face as inlet, select only the bottom few cells as inlet using toposet and createpatch and I hope the water will increase from bottom.
basin, filling, simplefoam |
how to track/view the filling of resin inside a mold using viscid/laminar modelFluent | gtuncol | FLUENT | 0 | August 6, 2010 23:49 |
Mold Filling simulation using VOF model. | Nitin Pathak | FLUENT | 1 | August 21, 2009 11:54 |
FILLING RESTART | AMP | FLOW-3D | 6 | December 19, 2008 03:48 |
Regarding mold filling simulation in Fluent | Nitin Pathak | FLUENT | 0 | August 10, 2007 14:19 |
Filling | Pietro Poesio | FLUENT | 0 | March 31, 2000 06:56 |
