chtMultiRegionFoam cyclic issue
Like Tree2Likes
  • 1 Post By pete20r2
  • 1 Post By Bloerb
Old   November 12, 2018, 09:41
Default chtMultiRegionFoam cyclic issue
Arthur
amdk136 is on a distinguished road
HI,
I am having trouble with chtMultiRegionFoam cyclic simulations. I have set up and run mesh/splitMesh on my geometry and they both work fine, however when I try and run my simulation, I get the following error:
--> FOAM FATAL ERROR:
Negative initial temperature T0: -19569.9rom objectRegistry twoBlocksCyclic12_11 failed
available objects of type objectRegistry are
2
fluid
solid
From function Foam::scalar Foam::species::thermo<Thermo, Type>::T(Foam::scalar, Foam::scalar, Foam::scalar, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar)const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar)const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar)const) const [with Thermo = Foam::hConstThermo<Foam::rhoConst<Foam::specie> >; Type = Foam::sensibleEnthalpy; Foam::scalar = double; Foam::species::thermo<Thermo, Type> = Foam::species::thermo<Foam::hConstThermo<Foam::rho Const<Foam::specie> >, Foam::sensibleEnthalpy>]
in file /sw/OpenFOAM/OpenFOAM-6/src/thermophysicalModels/specie/lnInclude/thermoI.H at line 54.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::error::abort() at ??:?
#2 Foam::species::thermo<Foam::hConstThermo<Foam::rho Const<Foam::specie> >, Foam::sensibleEnthalpy>::THs(double, double, double) const at ??:?
#3 Foam::heRhoThermo<Foam::rhoReactionThermo, Foam::SpecieMixture<Foam::singleComponentMixture<F oam::constTransport<Foam::species::thermo<Foam::hC onstThermo<Foam::rhoConst<Foam::specie> >, Foam::sensibleEnthalpy> > > > >::calculate() at ??:?
#4 Foam::heRhoThermo<Foam::rhoReactionThermo, Foam::SpecieMixture<Foam::singleComponentMixture<F oam::constTransport<Foam::species::thermo<Foam::hC onstThermo<Foam::rhoConst<Foam::specie> >, Foam::sensibleEnthalpy> > > > >::correct() at ??:?
#5 ? at ??:?
#6 __libc_start_main at ??:?
#7 ? at /home/abuild/rpmbuild/BUILD/glibc-2.22/csu/../sysdeps/x86_64/start.S:121
Aborted (core dumped)
I think it is an issue with my boundary conditions, but I don't know what is wrong with them.
Any help would be greatly appreciated! I have attached my '0' folder for my simulations.
Thank you!
Arthur
amdk136 is offline   Reply With Quote
Old   November 12, 2018, 22:29
Peter Baskovich
pete20r2 is on a distinguished road
I think the problem is in you boundary files or regionProperties, if you post them I can tell more.
Also, I'd avoid using the keywords "solid" and "fluid" as region names, it's kind of asking for trouble.
amdk136 likes this.
pete20r2 is offline   Reply With Quote
Old   November 13, 2018, 06:04
Bloerb will become famous soon enough
The likely error is that inside your boundary file the entry for the region is missing. Please post those files.
amdk136 likes this.
Bloerb is offline   Reply With Quote
Old   November 13, 2018, 06:06
Arthur
I resolved the problem, it was a wrongly defined p_rgh file!
Thank you for your responses!
Arthur
boundary conditions, chtmultiregionfoam, conjugate, heat transfer
Why Menter's SST model low-Re issue has not been seriously investigated? vkrastev OpenFOAM 58 January 8, 2018 16:20
Setting up cyclic boundary condition KateEisenhower OpenFOAM Pre-Processing 6 January 11, 2017 18:17
Tube bank unit cell w/ cyclic BC ajonuz OpenFOAM Running, Solving & CFD 0 August 28, 2015 09:48
chtMultiRegionFoam and cyclic BC Lada OpenFOAM Pre-Processing 2 January 4, 2014 10:31
Cyclic bc. and overlapGgi Pekka OpenFOAM 12 February 15, 2012 08:10
