November 3, 2018, 09:57 |
Doubts about twophaseeulerfoam
krishnan
Rep Power: 8 |
Greetings!!!
I have questions regarding twophaseeulerfoam. While performing euler-euler simulations on fluent, I see that for the continuous phase, there is no need to input the continuous phase diameter. TwophaseEulerFoam however requires this value. Is this because of the inclusion of the blending option to include phase inversion? What is a reasonable estimate for the continuous phase dia? For eg: in the bubblecolumn case, the water dia is 1e-4. If I need to perform a spray simulation (where air is the continuous phase), can I use the same value of 1e-4. Regards, |
June 15, 2021, 11:33 |
Lourenço SM
Rep Power: 12 |
Have you found an answer?
regards, |
openfoam, phase diameter, phasproperties, twophaseeulerfoam |
twoPhaseEulerFoam: sudden crash | hcen | OpenFOAM Running, Solving & CFD | 18 | September 29, 2020 04:04 |
twoPhaseEulerFoam fluidized bed wrong results | FabianB | OpenFOAM Running, Solving & CFD | 0 | June 14, 2017 04:48 |
Is twoPhaseEulerFoam applicable to 3D cases / delivering erroneous results? | ThomasV | OpenFOAM | 0 | November 11, 2013 09:10 |
Something wrong in UEqns.H within twoPhaseEulerFoam | cheng1988sjtu | OpenFOAM | 2 | June 24, 2011 11:48 |
twoPhaseEulerFoam | freemankofi | OpenFOAM | 0 | May 23, 2011 17:24 |
