chtMultiRegionFoam heat transfer issue
Like Tree2Likes
  • 1 Post By peterhess
Old   October 23, 2018, 10:04
Unhappy chtMultiRegionFoam heat transfer issue
Arthur
amdk136 is on a distinguished road
I am new to OpenFOAM and I am trying to model a conjugate heat transfer model of a solid block being heated through conduction from the bottom surface and being cooled by a flowing 'block' of fluid flowing over the top surface. So far I have the solid block conducting completely fine, however the fluid block is not heating or cooling (or interacting with) the top surface of the block at all.
Could this issue be because of the way that the interface is defined? I have included the code for the 0/T file for the solid below (the formatting issue is only from when i copy/pasted it onto the website). *I can supply any additional code if required.*
Any help would be greatly appreciated!
Thank you!
FoamFile
version 2.0;
format ascii;
class volScalarField;
location "0/solid";
object T;
dimensions [ 0 0 0 1 0 0 0 ];
internalField uniform 300;
boundaryField
#includeEtc "caseDicts/setConstraintTypes"
heater
type fixedValue;
value 500;
"solid(solidToFluid|Base)"
type zeroGradient;
solid_to_fluid
type compressible::turbulentTemperatureCoupledBaffleMix ed;
value $internalField;
Tnbr T;
kappaMethod solidThermo;
amdk136 is offline   Reply With Quote
Old   October 23, 2018, 10:39
Peter Hess
peterhess is on a distinguished road
Which Version of OF are you using?
If OF6 then be sure that you are simulating steady state.
Check up the ddt sheme (in the solid and fluid), if euler or steasy state.
If you are simulating transient, a solution will be reached. But you need to simulate long.
Turn the simulation to steady state or increase the time steps.
If the version is OF5 older than 6 then the simulation is transient and you should use: chtMultiRegionSimpleFoam
You dont talk about any deconvergence or crashing, that means at least the simulation runs ad produce results...
Or you are making a post processing mistake.
After running the simulation type:
paraFoam -touchAll
paraFoam -region "your fluid region"
Like that you use the fluid results alone.
Be sure the time is the last one in paraFoam.
Print temperature.
What do you see?
Print a shot of a time step from the log file please.
Regards
Peter
amdk136 likes this.
peterhess is offline   Reply With Quote
Old   October 23, 2018, 11:02
Arthur
If the version og OFis older than 6 then the simulation is transient and you should use: chtMultiRegionSimpleFoam
paraFoam -touchAll
Like that you upload the fluid results alone.
Print temperature.
What do you see?
Regards
Peter
Peter,
OpenFOAM 6 is being used.
The simulation runs fine and the tempoerature of the solid block on the bottom changes correctly. When running "paraFoam -region -fluid" it shows a 0.05K increase.
As you have asked for, here is the time step from the log file:
Solving for fluid region fluid
diagonal:  Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCGStab:  Solving for Ux, Initial residual = 7.07547e-11, Final residual = 7.07547e-11, No Iterations 0
DILUPBiCGStab:  Solving for Uy, Initial residual = 2.28422e-09, Final residual = 2.28422e-09, No Iterations 0
DILUPBiCGStab:  Solving for Uz, Initial residual = 1.17482e-09, Final residual = 1.17482e-09, No Iterations 0
DILUPBiCGStab:  Solving for h, Initial residual = 9.78777e-06, Final residual = 6.28479e-09, No Iterations 1
Min/max T:300 420.101
GAMG:  Solving for p_rgh, Initial residual = 6.15382e-08, Final residual = 6.15382e-08, No Iterations 0
time step continuity errors : sum local = 2.02462e-13, global = 3.82798e-15, cumulative = 3.82798e-15
Min/max rho:1.225 1.225
Solving for solid region solid
GAMG:  Solving for h, Initial residual = 0.000433589, Final residual = 3.47651e-16, No Iterations 1
Min/max T:400.094 1000
ExecutionTime = 272.54 s  ClockTime = 288 s
Region: fluid Courant Number mean: 0.197803 max: 0.998812
Region: solid Diffusion Number mean: 0.000329392 max: 0.0235509
deltaT = 0.00194175
Time = 4.8932
Would I be correct in saying that from the log it appears that the fluid is heating up and that ParaView is just not showing the heating up?
I have also set it to run for a larger time.
Thank you for your help.
Regards,
Arthur
Old   October 23, 2018, 11:21
Peter Hess
Originally Posted by amdk136 View Post
Peter,
deltaT = 0.00194175
Time = 4.8932
Well, from the log file, the temperature of the fluid is 420.
The temperature of the fluid is increasing...
I would say you still have a postprocessing problem...
Are you simulating steady state?
Regards
Peter
amdk136 likes this.
Old   October 23, 2018, 11:46
Arthur
Regards
Peter
Peter,
Thank you for your confirmation about the log file.
I will take it on board that it is a post-processing problem and try and figure that out!
I am simulating transient conditions, and am using chtMultiRegionFoam in OpenFOAM 6.
Thank you again for your help, it is much appreciated!!
Regards,
Arthur
conduction, conjugate, heat transfer, openfoam
Problem with total heat transfer rate aswathy_raghu FLUENT 9 April 21, 2022 11:36
chtMultiregionFoam, very low heat transfer mwaqas OpenFOAM Running, Solving & CFD 2 July 25, 2018 05:57
Forced convection conjugate heat transfer with chtMultiRegionFoam JohnJohn8 OpenFOAM Running, Solving & CFD 2 August 3, 2016 06:52
Problem with total heat transfer rate aswathy_raghu FLUENT 0 July 26, 2016 08:39
Multiphase heat transfer pkladisios CFX 8 June 7, 2016 02:41
