OpenFoam
Like Tree1Likes
  • 1 Post By syntex
Old   October 19, 2018, 10:23
Default OpenFoam
Christophk
syntex is on a distinguished road
I just started using OpenFoam. I tried to use an old simulation, which runs into an error, using cyclic for boundary conditions:
--> FOAM FATAL IO ERROR:
Old-style cyclic definition. Splitting patch fan into two halves fan_half0 and fan_half1
Alternatively use new 'boundary' dictionary syntax.
file: /opt/openfoam6/src/OpenFOAM/root-6/run/fan/constant/polyMesh/blockMeshDict.patches at line 90.
From function void Foam::blockMesh::readPatches(const Foam::dictionary&, Foam::faceListList&, Foam::wordList&, Foam::wordList&, Foam::wordList&)
in file blockMesh/blockMeshTopology.C at line 206.
Does anyone have any idea, what I should do?
Thanks for help.
Gerhard likes this.
syntex is offline   Reply With Quote
Old   October 21, 2018, 11:53
Christophk
Does really noone have any idea?
Old   October 22, 2018, 12:52
Lee Strobel
Time4Tea is on a distinguished road
I don't have a lot of experience with OpenFOAM, but will try to help if I can.
Firstly, what operation are you trying to perform, when you get that message?
Form the error message, it looks like it something to do with the boundary conditions and/or the mesh. Have you tried re-meshing? If so, perhaps see if it will work with some alternative boundary conditions.
Time4Tea is offline   Reply With Quote
Old   October 23, 2018, 01:42
Peter Baskovich
pete20r2 is on a distinguished road
Hi Cristoph,
Could you provide the blockMeshDict you are trying to run? It seems that the way to define cyclic patches has changed between the old case you are trying to run and the new OF environment.
It is always helpful around here to mention which version exactly you are running as there can be differences in implementations and available functionality.
pete20r2 is offline   Reply With Quote
Old   October 24, 2018, 10:16
Christophk
blockmeshdict:
| \\ / O peration | Version: 1.2 |
| \\ / A nd | Web: http://www.openfoam.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
root "";
case "";
instance "";
local "";
class dictionary;
object blockMeshDict;
convertToMeters 1;
x0 0.0;
x1 4.0;
x2 4.0;
x3 8.0;
y0 0.0;
y1 1.0;
z0 0.0;
z1 0.5;
vertices
( $x0 $y0 $z0 )
( $x1 $y0 $z0 )
( $x1 $y1 $z0 )
( $x0 $y1 $z0 )
( $x0 $y0 $z1 )
( $x1 $y0 $z1 )
( $x1 $y1 $z1 )
( $x0 $y1 $z1 )
( $x2 $y0 $z0 )
( $x3 $y0 $z0 )
( $x3 $y1 $z0 )
( $x2 $y1 $z0 )
( $x2 $y0 $z1 )
( $x3 $y0 $z1 )
( $x3 $y1 $z1 )
( $x2 $y1 $z1 )
blocks
hex ( 0 1 2 3 4 5 6 7 ) upstream ( 40 10 5 ) simpleGrading ( 1 1 1 )
hex ( 8 9 10 11 12 13 14 15 ) upstream ( 40 10 5 ) simpleGrading ( 1 1 1 )
boundary
inlet
type patch;
faces
( 0 4 7 3 )
outlet
type patch;
faces
( 9 10 14 13 )
walls
type wall;
faces
( 0 1 2 3 )
( 8 9 10 11 )
( 0 1 5 4 )
( 8 9 13 12 )
( 4 5 6 7 )
( 12 13 14 15 )
( 3 7 6 2 )
( 11 15 14 10 )
fan_half0
type cyclic;
neighbourPatch fan_half1;
faces
( 1 2 6 5 )
fan_half1
type cyclic;
neighbourPatch fan_half0;
faces
( 8 12 15 11 )
mergePatchPairs
I changed the file, so the meshing works now. The solver requests a turbulenceproperties file now, and I tried to run with kOmegaSST, but then I need a nut-File.
If I tried to copy that as well from tutorials/lagrangian/reactingParcelFoam/verticalChannelLTS/0 it searches for a patchType inlet, which doesn't exists here. I'm not really sure how to change the nut-file.
The working U-file looks like this :
FoamFile
version 2.0;
format ascii;
class volVectorField;
location "0";
object U;
dimensions [ 0 1 -1 0 0 0 0 ];
internalField uniform ( 1 0 0 );
boundaryField
inlet
type pressureInletVelocity;
phi phi;
value uniform ( 0 0 0 );
outlet
type inletOutlet;
inletValue uniform ( 0 0 0 );
walls
type fixedValue;
fan_half0
type cyclic;
fan_half1
type cyclic;
The nut-File loks like this now:
FoamFile
version 2.0;
format ascii;
class volScalarField;
location "0";
object nut;
dimensions [0 2 -1 0 0 0 0];
internalField uniform 0;
boundaryField
back
type symmetryPlane;
front
type symmetryPlane;
inletCentral
type calculated;
value uniform 0;
inletSides
type calculated;
value uniform 0;
outlet
type calculated;
value uniform 0;
walls
type nutkWallFunction;
Cmu 0.09;
kappa 0.41;
E 9.8;
value uniform 0;
fan_half0
type cyclic;
fan_half1
type cyclic;
I'm sorry if I did some obvious mistakes and can't see them, since I am new to this stuff.
Old   February 19, 2020, 09:15
Gerhard
Gerhard is on a distinguished road
Hi Christoph,
You just need to use the same boundary names in the nut-file, i.e. inlet, outlet, walls, fan_half0, fan_half1.
Then assign the correct types etc., which you can get an idea of in the tutorial files etc.
Get rid of the front, back, and those things that do not correspond to the boundaries in the U-file.
Regards.
Gerhard is offline   Reply With Quote
Old   February 26, 2024, 12:09
Marion Sant
edo2822 is on a distinguished road
Originally Posted by syntex View Post
blockmeshdict:
FoamFile
version 2.0;
format ascii;
root "";
case "";
instance "";
local "";
class dictionary;
convertToMeters 1;
x0 0.0;
x1 4.0;
x2 4.0;
x3 8.0;
y0 0.0;
y1 1.0;
z0 0.0;
z1 0.5;
vertices
( $x0 $y0 $z0 )
( $x1 $y0 $z0 )
( $x1 $y1 $z0 )
( $x0 $y1 $z0 )
( $x0 $y0 $z1 )
( $x1 $y0 $z1 )
( $x1 $y1 $z1 )
( $x0 $y1 $z1 )
( $x2 $y0 $z0 )
( $x3 $y0 $z0 )
( $x3 $y1 $z0 )
( $x2 $y1 $z0 )
( $x2 $y0 $z1 )
( $x3 $y0 $z1 )
( $x3 $y1 $z1 )
( $x2 $y1 $z1 )
blocks
boundary
inlet
type patch;
faces
( 0 4 7 3 )
outlet
type patch;
faces
( 9 10 14 13 )
walls
type wall;
faces
( 0 1 2 3 )
( 8 9 10 11 )
( 0 1 5 4 )
( 8 9 13 12 )
( 4 5 6 7 )
( 12 13 14 15 )
( 3 7 6 2 )
( 11 15 14 10 )
fan_half0
type cyclic;
faces
( 1 2 6 5 )
fan_half1
type cyclic;
faces
( 8 12 15 11 )
mergePatchPairs
FoamFile
version 2.0;
format ascii;
location "0";
object U;
boundaryField
inlet
phi phi;
outlet
type inletOutlet;
walls
type fixedValue;
fan_half0
type cyclic;
fan_half1
type cyclic;
FoamFile
version 2.0;
format ascii;
location "0";
object nut;
boundaryField
back
type symmetryPlane;
front
type symmetryPlane;
inletCentral
type calculated;
value uniform 0;
inletSides
type calculated;
value uniform 0;
outlet
type calculated;
value uniform 0;
walls
Cmu 0.09;
kappa 0.41;
E 9.8;
value uniform 0;
fan_half0
type cyclic;
fan_half1
type cyclic;
Hey, I'm having the same problem. Did you find a solution by chance?
edo2822 is offline   Reply With Quote
Frequently Asked Questions about Installing OpenFOAM wyldckat OpenFOAM Installation 3 November 14, 2023 12:58
OpenFOAM Foundation releases OpenFOAMŪ 3.0.0 CFDFoundation OpenFOAM Announcements from OpenFOAM Foundation 1 November 7, 2015 16:16
OpenFOAM Foundation Releases OpenFOAM v2.3.0 opencfd OpenFOAM Announcements from OpenFOAM Foundation 3 December 23, 2014 04:43
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 10:04
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 19:07
