UDF for planetary motion
Like Tree2Likes
  • 1 Post By wyldckat
Old   October 9, 2018, 02:08
Default UDF for planetary motion
Ansh
Ansh is on a distinguished road
Hello everyone, iam new to openfoam and for my project i need to describe planetary motion for two blades around one center blade. iam using overPimpleDyMFoam so can anyone point out the right direction to achieve this. Where and how to write UDF?
And how to link it with my present solver?
thanks
Ansh is offline   Reply With Quote
Old   October 13, 2018, 07:54
Retired Super Moderator
Bruno Santos
Greetings Ansh and welcome to the forum,
No UDF should be necessary. Since you are likely using OpenfOAM-v1806, please study the respective OpenFOAM Tutorial Guide: https://www.openfoam.com/documentation/tutorial-guide/ - this will give you a better basis on how to get things to work.
Then once you are more familiar with how OpenFOAM works, check the tutorial case "tutorials/multiphase/overInterDyMFoam/boatAndPropeller/" and in the file "constant/dynamicMeshDict" you will start to see how the moving parts are defined...
Best regards,
Bruno
Old   October 15, 2018, 03:36
Ansh
thanks for quick reply, i have started looking into mentioned tutorials. after adjusting that dynamicmeshdict according to my need iam getting following error
--> FOAM FATAL ERROR:
Could not find rho:rho
From function void Foam::functionObjects::forces::initialise()
in file forces/forces.C at line 204.
FOAM exiting
i have found other threads related to this bug and i have changed my rhoName to rho as you mentioned there still iam getting this error. Any suggestions
function for force in controldict:
functions
forces
type forces;
functionObjectLibs ("libforces.so");
writeControl timeStep;
writeInterval 5;
patches (hole1);
rho rhoInf;
rhoInf 1;
CofR (0 0 0);
p p;
U U;
log yes;
verbose true;
Old   October 20, 2018, 16:35
Bruno Santos
Quick answer: Details, details, details... I need details... Please check the following thread for more information on how to provide mode details: How to give enough info to get help
Because my best guess right now is that you've used the wrong command to start the simulation...
What I mean is that the "rho" field should exist when the solver starts running... so if it doesn't exist, then it might mean that you've tried using it with the wrong application.
Tobi likes this.
Old   October 22, 2018, 02:17
Default overPimpleDymFoam rigid body motion rho not found
Ansh
iam intending to use rigid body motion in overPimpleDyMFoam since i want to give planetary motion to the blades (fig is attached) mesh.jpg
where outer two blades will rotate and revolve arround the centre blade.
I have followed the overInterDyMFoam from multiphase flow to achieve that motion
iam attaching my conrolDict,forceCoeffs and dynamicMeshDict for reference
dynamicMeshDict
motionSolverLibs    ("librigidBodyMeshMotion.so");
dynamicFvMesh       dynamicOversetFvMesh;
//dynamicOversetFvMeshCoeffs
//    layerRelax 0.3;
motionSolver          rigidBodyMotion;
solver
        type Newmark;
        gamma   0.1;    // Velocity integration coefficient
        beta    0.1;    // Position integration coefficient
    accelerationRelaxation 1.0;
    //- prescribedRotation requires some sub-iterations to converge faster
    //  to desired value.
    nIter   3;
bodies
        movingzone2
            type            rigidBody;
            parent          root;
            // Cuboid mass -- very simple setup. For more complicated shapes
            // see utility surfaceInertia
            mass            9;
            rho             1;
            inertia         (0.05 0 0 0.05 0 0.05);
            centreOfMass    (0.21 -0.07 0); // relative to the centreOfMass
                                            // of parent body
                                            // (here root = global coord system)
            // Transformation tensor and centre of rotation
            transform       (1 0 0 0 1 0 0 0 1) (0.21 0 0);
            joint
                type            composite;
                joints
                        type Pxyz;  // Allow movement in any direction
                        type Rxyz;  // Allow rotation along any axis
                                    // (local - body CS)
            patches         (hole2);
            innerDistance   100;    // With overset we want to avoid the mesh
                                    // deformation so have large innerDistance
            outerDistance   200;
        } // end hull
        movingzone1
            type            rigidBody;
            parent          movingzone2;
            centreOfMass    (-0.228 0.0 0);
            mass            1;
            rho             1;
            inertia         (0.001 0 0 0.001 0 0.001);
            transform       (1 0 0 0 1 0 0 0 1) (-0.228 0 0);
            patches        (hole1);
            innerDistance   100;
            outerDistance   200;
            joint
                type            Rx;
        } //end propeller
        movingzone3
            type            rigidBody;
            parent          movingzone2;//root;
            centreOfMass    (-0.265 0 0);
            mass            1;
            rho             1;
            transform       (1 0 0 0 1 0 0 0 1) (-0.265 0 0);
            patches        (hole3);
            innerDistance   100;
            outerDistance   200;
            joint
                type            Ry;
         solid-background
            type            rigidBody;
            mass            1;
            rho             1;
            patches        (hole3);
            innerDistance   100;
            outerDistance   200;
            joint
                type            Ry;
    restraints
        movingzone1Rotation
            type                    prescribedRotation;
            body                    movingzone1;
            referenceOrientation    (1 0 0 0 1 0 0 0 1);
            axis                    (0 1 0);    // Axis of rotation
            omega                   sine;       // Function1 entry
            omegaCoeffs
                frequency   4;
                amplitude   0.2;
                scale       (0 1 0);
                level       (0 1 0);
        movingzone3Rotation
            body                    movingzone3;
            axis                    (1 0 0);
            omega                   table
                (0 (0 0 0))
                (1 (16 0 0))
controlDict
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      controlDict;
libs            ("liboverset.so" "librigidBodyDynamics.so");
application     overPimpleDyMFoam;
startFrom       startTime;
startTime       0;
stopAt          endTime;
endTime         5;
deltaT          0.0000000025;
writeControl    adjustableRunTime;
writeInterval   0.005;
purgeWrite      0;
writeFormat     binary;
writePrecision  10;
writeCompression off;
timeFormat      general;
timePrecision   6;
runTimeModifiable true;
adjustTimeStep  yes;
//maxCo           1;
maxCo           5.0;
maxAlphaCo      5.0;
maxDeltaT       1;
functions
     #include "forceCoeffs"
forceCoeffs
forceCoeffs
    timeInterval    1;
    patches         (walls);
    rho         rhoInf;      // Indicates incompressible
    rhoInf      1;
    p           p;
    U           U;
    // Redundant for incompressible
    liftDir         (0 0 1);
    dragDir         (1 0 0);
    CofR            (0 0 0);  // Axle midpoint on ground
    pitchAxis       (0 1 0);
    magUInf         20;
    lRef            1.42;        // Wheelbase length
    Aref            0.75;        // Estimated
    binData
        nBin        20;          // output data into 20 bins
        direction   (1 0 0);     // bin direction
        cumulative  yes;
and error that iam getting
Creating interpolatedCells field
Selecting incompressible transport model Newtonian
Selecting turbulence model type laminar
Selecting laminar stress model Stokes
Reading/calculating face velocity Uf
No MRF models present
No finite volume options present
Courant Number mean: 0 max: 0
Starting time loop
deltaT = 2.9999994e-09
Time = 3e-09
forces forces:
    Not including porosity effects
FOAM exiting
1)does that mean i cannot use rigid body motion with overPimpleDyMFoam(since while using it only i have started facing this error )
2)can anyone recommend any literature available related to this?
pardon my immaturity with openfoam
Old   October 27, 2018, 14:14
Bruno Santos
Quick answers:
1. I've tested with OpenFOAM-v1806 as a Docker image. I used the tutorial case "incompressible/overPimpleDyMFoam/twoSimpleRotors" as a basis and did the modifications that you mentioned to the controlDict file, namely:
  1. Added the entry for "forceCoeffs" in the "functions"...
  2. And created the file "system/forceCoeffs", although I had to add this line in order for it to work:
        type forceCoeffs;
    namely having the content of the file like this:
    forceCoeffs
        type forceCoeffs;
        timeInterval    1;
        patches         (walls);
        rhoInf      1;
        p           p;
        U           U;
        liftDir         (0 0 1);
        dragDir         (1 0 0);
        pitchAxis       (0 1 0);
        magUInf         20;
        binData
            cumulative  yes;
Then I run the solver and everything works just fine, namely it will make the calculations while it is simulating.
It also worked when I ran the solver with the "-postProcess" option, after I had a few time steps already written to disk:
overPimpleDyMFoam -postProcess
Mmmmm... this sounds like either a bug or some detail is missing for that type of rigid body motion... You may want to report this at http://develop.openfoam.com/ - although you may need to provide a simple test case, so that it's easier to reproduce the problem and fix it.
2. The documentation provided here: https://www.openfoam.com/documentation/ - should already have a considerable amount of information... check the "Extended Code Guide" page for more details, although it may be a bit confusing at first to navigate there.
Ansh likes this.
openfoam, planetary mixer, udf
UDF CG motion Sam1990 Fluent UDF and Scheme Programming 1 May 9, 2017 17:22
Display Zone motion of a dynamic mesh????Checking my UDF motion Irenedea FLUENT 0 March 20, 2014 03:17
UDF to control motion NOT about CG LenDawg0220 Fluent UDF and Scheme Programming 0 July 28, 2012 13:54
UDF: DEFINE_CG_MOTION for vertical jump motion of an electrode! alban Fluent UDF and Scheme Programming 2 June 8, 2010 19:54
UDF error CG Motion Alex FLUENT 0 March 22, 2006 18:40
