Uneven velocity profile as inlet
Like Tree5Likes
  • 1 Post By hyFoam
  • 2 Post By piu58
  • 2 Post By Tobi
Old   September 25, 2018, 03:57
Default Uneven velocity profile as inlet
Elm
Elm is on a distinguished road
Hi Foamers,
i do have an cylindric geometry with some inlet pipes at the bottom (see attachment).
Do you know if there is some inlet boundary conditions to model these pipes or an uneven velocity boundary?
I dont want to mesh all the small pipes, so please help me
(The picture of the pipes is just an example)
Elm is offline   Reply With Quote
Old   October 2, 2018, 16:59
Vince
hyFoam is on a distinguished road
Hi Elm,
Have you considered created two different patches while meshing? You could then use two different fixed values in 0/.
Cheers,
Vincent
Elm likes this.
hyFoam is offline   Reply With Quote
Old   October 3, 2018, 03:49
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
You may give the velocity at your patch as nonuniform List<vector> . If you don't made this before I recommend to start with uniform velocity and analyze one of the result files. All you gave compact will be nonuniform there and you may see which velocity belongs to which coordinate.
You have to give a 0 file in the same structure.
atulkjoy and Elm like this.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   October 5, 2018, 06:18
Elm
@hyFoam: Yes, the two patches way is my "dirty" solutions ;-)
@piu58 Thanks for that hint, that seems the perfect solution for me!
Old   October 5, 2018, 09:34
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
both ways will work, but I would prefer the first one - building two patches based on the following reason:
  • If you have two patches, you will catch the circular behavior of the inlets
  • If you have one patch, you will probably get a uniform mesh at the inlet (depending on the meshing strategy), and therefore, you can apply the velocities only to flat, non-curved faces which might influence your result.
However, personally, two patches do not seem to be a 'dirt' workflow. The way, Piu is explaining would be excellent, if:
  • The flat/curvature inlets does not influence your solution
  • You have the center points of the inlet pipes; a small codedFixed boundary condition while reading a file that contains the center while calculating the area of the circles and evaluate the included face centers while applying the velocity field, is beautiful, simple and modifiable
piu58 and Elm like this.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   October 8, 2018, 04:18
Elm
Thanks for you detailed answer Tobi!
I misunderstood the solution of hyFoam, i'll try both ideas
combining parabolic inlet velocity profile with time varying velocity vector values jawapasu OpenFOAM 3 July 10, 2023 06:41
Velocity inlet BC profile antonio.c FLUENT 1 November 1, 2017 15:22
[swak4Foam] Inlet velocity profile for turbulent pipe flow using swak4Foam zordiack OpenFOAM Community Contributions 5 February 23, 2016 02:52
Strange velocity profile at the inlet for a flow inside a cylindrical pipe michmich OpenFOAM Running, Solving & CFD 0 July 2, 2012 04:37
Export & Import Velocity profile as Inlet eRzBeNgEl STAR-CCM+ 6 March 26, 2012 06:16
