OpenFOAM Parallelization MPI Cluster Problem
Like Tree2Likes
  • 1 Post By wyldckat
Old   August 11, 2018, 02:27
Default OpenFOAM Parallelization MPI Cluster Problem
Arslan Ali
arslan.ali is on a distinguished road
Hello FOAMers,
Recently I have been working on parallelization of OpenFOAM on BeoWulf clusters. Basically I’m having a very minor problem in my cluster setup which I’m unable to debug.
I have a cluster of 2 laptops.
Ubuntu 18.04LTS (dual-boot with windows)
OpenFOAM-v1806 installed on home directory
i7 processor, quad core, 64-bit
These specifications are same on both laptops.
- LAN connection has been setup between both laptops using a switch and
cables.
- Both laptops ping(0.3ms-0.6ms), and password-less ssh is also working
perfectly.
- Both laptops have the same case folder in the home directory.
- And in both laptops we run decomposePar separately after editing its Dict
file correctly.
- /etc/hosts file has been also edited on both laptops.
- Master node has the ‘machines’ file in the home folder.
Now we run the mpirun command but it doesnt run. After typing the command:
‘mpirun -np 8 --hostfile ~/machines pisoFoam -parallel’
We press enter and the terminal freezes on the next line. (Nothing happens)
I have uploaded screenshots of all necessary information you might need.
Thanks in Advance.
https://imgur.com/a/mWe0ZSF
https://imgur.com/a/TIQBEkc
https://imgur.com/a/hXe4DLq
https://imgur.com/a/k8FlHjC
arslan.ali is offline   Reply With Quote
Old   August 22, 2018, 09:43
Retired Super Moderator
Bruno Santos
Greetings arslan.ali,
I don't know if you have solved this issue, but from what I can see, the problem is that OpenFOAM is installed in different folders.
I don't know how you are sourcing the OpenFOAM environments on each machine, but the idea is that you should let them be sourced when your "/home/*/.bashrc" file is called.
The other possibility is to use multiple launch calls, namely as explained here: https://www.open-mpi.org/faq/?category=running#mpmd-run
My guess is that in your case, you should make the launch command something like this:
mpirun --hostfile ~/machines  -np 4 $HOME/OpenFOAM/OpenFOAM-v1806/bin/foamExec pisoFoam -parallel : -np 4 /home/otherUserAtSecondMachine/OpenFOAM/OpenFOAM-v1806/bin/foamExec pisoFoam -parallel
But the simplest would be to either have the same username on both machines or to simply install OpenFOAM at "/opt".
Best regards,
Bruno
Aabadani likes this.
wyldckat is online now   Reply With Quote
Old   August 22, 2018, 12:42
hokhay is on a distinguished road
It can be the communication problem. Have you make sure the passwordless ssh is working on both sides. The node also needs to be able to ssh into the master
hokhay is offline   Reply With Quote
Old   September 13, 2018, 08:31
Arslan Ali
Thanks wyldckat and hokhay for your replies.
Soon after this post I solved this problem by changing my openFoam installation directory to /opt. Just as wyldckat mentioned. However, later we received an error on the mpi command stating that "point files in polymesh could not be found".. We solved that issue aswell by using NFS shared directory method.
At this point we were able to run OpenFoam simulations using multiple processors from multiple PCs.
However, right now the problem we're facing is that our simulation clocktimes dont make sense. Basically, using 1 PC and 8 cores we get a simulation clocktime of 271s on a vortex shedding case while on a cluster of 2 PCs, 16 cores we get a clocktime of 530s which doesnt make sense. Also we dont think that there are critical communication barriers between PCs since the ping between the PCs is 0.1-0.3ms.
Cluster specifications for both PCs are:
i7-4770
3.3GHz x 8.
8Gb RAM.
UBUNTU 14.04 LTS
Can you please guide us on what can be the issue. We're really hhoping to hear from you soon. Thanks for your time.
Old   September 23, 2018, 14:50
Bruno Santos
Quick answer: The slow down you are seeing may be because either:
  1. The number of cells in each subdomain should be at least 50000 cells. Below that, you will start seeing little benefit in performance; perhaps you only have 5000 cells in each subdomain (in each "processor" folder).
  2. The case might be monstrous, for example, 50 million cells total, where it takes a ton of time to transfer information between machines.
  3. Or you forgot to add the argument "-parallel" to the command that calls the solver, as I indicated in a previous post.
  4. Or you are saving to disk too frequently.
There is a thread that tries to explain the following: How to give enough info to get help
beowulf, cluster, mpi, openfoam, parallelization
How to contribute to the community of OpenFOAM users and to the OpenFOAM technology wyldckat OpenFOAM 17 November 10, 2017 16:54
[Other] Openfoam for windows 16.02 [CFD support] -problem with paraview ditmeyer OpenFOAM Installation 3 May 15, 2017 13:04
Problem with parallelization on cluster GiuMan OpenFOAM Running, Solving & CFD 12 August 14, 2015 06:11
How to setup a simple OpenFOAM cluster? TommiPLaiho OpenFOAM Installation 3 October 27, 2013 16:15
Sgimpi pere OpenFOAM 27 September 24, 2011 08:57
