Can interFoam be used as a heat transfer solver? |
Rep Power: 8 ![]() |
Hello everyone,
I have been using OF for a few months to analyze the flow of two in-compressible fluid in a pipeline with T junction by using interFoam solver. Now, I want to consider heat transfer from the mixture which has high temperature to the the environment through the pipe wall which has low temperature as the same with the environment. Can I do that with interFoam changing the source codes based on the heat transfer solvers and adding the needed case files? What is the best thing I can solve heat transfer problem of the same system without chancing main set-up? If you can share your knowledge and opinion, I will be so happy. Thank you in advance. |
anonymous
Rep Power: 14 ![]() |
Is it a free surface flow or just water in a pipe, and air around it?
Peter Baskovich
Rep Power: 12 ![]() |
There is a tutorial on adding a T field to icoFoam (on my phone so I'll leave it to you to google). I haven't tried it myself but being incompressible, it should be just like any other scalar transport.
Thank you all for quick reply. It is oil-water flow in a pipe and the pipe is located under the ocean, so there is cold water around it. That means I need to define all wall temperature about 3 C and the fluid temperature is 200 C. I can create T files for these but how can I provide interFoam solve heat transfer?
#6 | |
Peter Baskovich
Vivek
Hi guys,
I am also having similar clarifications related to interFoam solver. Can interFoam able to analyze primary breakup process in spray atomization ?? or is there any solvers suitable to be used for primary breakup process in spray. Guys please reply to this thread i am beginner in OpenFoam. Thanks, Vivek |
anonymous
Hi!
If you have a problem first go through the solvers if you have a proper one for your application or not: https://cpp.openfoam.org/v6/dir_fdd1...79c87ac3c.html Maybe sprayFoam? https://cpp.openfoam.org/v6/sprayFoam_8C.html "Transient solver for compressible, turbulent flow with a spray particle cloud." There is a tutorial for this solver in the lagrangian folder. |
#9 | |
Vivek
Actually i want to simulate primary breakup process in OF using interFoam solver but in my case the liquid is coming out as a solid jet ..thats ok but it even not showing any droplet. i dont know where i am making mistake. |
Solver for gas flow through porous media including heat transfer in OpenFOAM v3.0+ | Germilly | OpenFOAM Running, Solving & CFD | 30 | May 10, 2024 07:37 |
Interphase mass transfer of a reaction | cfx_ws1992 | Main CFD Forum | 0 | May 15, 2017 21:42 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
No Display of Heat Transfer Graphs For Double Pipe Heat Exhanger in CFX Solver | Shomaz ul Haq | CFX | 17 | November 25, 2015 22:44 |
Concentric tube heat exchanger (Air-Water) | Young | CFX | 5 | October 6, 2008 23:17 |
