Is there a way to define couple a wall with more than one wall in chtMultiRegionFoam |
July 17, 2018, 13:11 |
Rep Power: 8 |
I have a geometry where I have a cylinder and inside it I have many smaller cylinders made of different materials. Is there a way I could define a mappedWall condition for the big cylinder's inner wall with each of the smaller cylinders' walls?
It's impractical to divide the big cylinder into the same number of regions. I have more than 50 cylinders inside. Edit: I apologize about the typo in the title. |
July 17, 2018, 22:51 |
Peter Baskovich
Rep Power: 12 |
I had a similar problem to this.
I found if I blockMesh the entire mesh, then use topSet to make cellZones, then used splitMeshRegions -cellZones the boundaries are automatically created in the form: Code:
FoamFile { version 0.0; format ascii; class polyBoundaryMesh; location "constant/cell_1/polyMesh"; object boundary; } cell_1_to_channelT { type mappedWall; inGroups 1 ( wall ); nFaces 1600; startFace 445600; sampleMode nearestPatchFace; sampleRegion channelT; samplePatch channelT_to_cell_1; } By doing this and having default p,T,U fields in 0 when doing the split, I can control all of the patches in the similar regions by using a linux trick. I create a system folder for cell_1 and then link the system folder for cell_2-16 to cell_1 I have this script in the system folder to make it quickly: Code:
#!/bin/bash cd ${0%/*} || exit 1 # run from this directory for i in cell_2 cell_3 cell_4 cell_5 cell_6 cell_7 cell_8 cell_9 cell_10 cell_11 cell_12 cell_13 cell_14 cell_15 cell_16 do ln -s cell_1 $i done It's written using widcards for the region numbers so it can run on all regions: Code:
FoamFile { version 2.0; format ascii; class dictionary; object changeDictionaryDict; } T { internalField uniform 300; boundaryField { "cell_.*_to_channel.*" { type compressible::turbulentTemperatureCoupledBaffleMixed; Tnbr T; thicknessLayers ( 1.5e-05 ); kappaLayers ( 2 ); kappaMethod solidThermo; value uniform 300; |
July 18, 2018, 04:45 |
#3 | |
Rep Power: 8 |
July 19, 2018, 01:00 |
Peter Baskovich
Rep Power: 12 |
I'm using a mapped inlet to develop the inlet velocity profile.
U is zeroGradient on outlet. p is zeroGradient on inlet, fixedMean 0 on the outlet. I know there are no flow reversals across my boudaries so I'm getting away with it, inletOutlet is a good idea to start with to improve the chances of getting a converged solution. Might not be accurate but will get you running. There are 2 fluid channels contacting 16 solid regions, each solid region has a patch to each fluid region. |
[Commercial meshers] Fluent3DMeshToFoam | simvun | OpenFOAM Meshing & Mesh Conversion | 50 | January 19, 2020 15:33 |
[mesh manipulation] mergeMeshes problem | Attesz | OpenFOAM Meshing & Mesh Conversion | 3 | July 29, 2015 04:15 |
[ICEM] Export ICEM mesh to Gambit / Fluent | romekr | ANSYS Meshing & Geometry | 1 | November 26, 2011 12:11 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
REAL GAS UDF | brian | FLUENT | 6 | September 11, 2006 08:23 |
