Simplefoam Convergence Problem after Scaling by 0.001 |
July 14, 2018, 06:46 |
Hi everyone,
I have prepared a very simple case to test the capability of simplefoam to simulate turbulet flow with KOSST turbulence model. The mesh was created using snappyhexmesh in mm, and it is a simple 20 mm (diameter) pipe. If we solve this without scaling, i.e for a pipe having a diameter of 20 meters, the solution converges for inlet velocity of 10 m/s. However, once the grid us scaled by 0.001 (in all the directions) no convergence can be achieved, and the velocity develops very high and unreasonable magnitudes. What could be a problem? How can this be corrected? This problem does not exist if I run pisoFoam. Thank you in advance. |
July 15, 2018, 23:23 |
Peter Baskovich
Rep Power: 12 |
What are your boundary conditions?
July 16, 2018, 03:38 |
Robert
Rep Power: 12 |
I had similar problems when scaling my blockMesh to micrometer scale (1e-6 m). As for my problem, i accounted it to be to many trailing zeros, but maybe i'm wrong.
To offer a solution: You can always make use of dynamic similarity (i.e. Bolster et al., 2011) by scaling your viscosity instead of your mesh size. This will give you the same results as on your smaller scale, but on your larger mesh.
If you liked my answer to your question, please consider leaving a "Like" in return |
July 21, 2018, 06:56 |
I don't think that this is a solution. If additional dimensionless numbers must be matched , adjusting the viscosity will not provide accurate and required results.
July 23, 2018, 04:27 |
Robert
Rep Power: 12 |
You are right. It doesn't suffice to only scale the Reynolds number. All other dimensionless numbers important to the problem must match on both scales as well.
[blockMesh] FATAL ERROR: face 6 in patch 2 does not have neighbour cell face: 4(8 9 21 20) | robingilbert | OpenFOAM Meshing & Mesh Conversion | 28 | November 23, 2023 07:32 |
Convergence issue in natural convection problem | chrisf90 | FLUENT | 5 | March 5, 2016 09:30 |
Submerged fin, Convergence problem | supermouniette | FLUENT | 10 | July 6, 2009 11:47 |
CONVERGENCE PROBLEM - oil boiler | MM | FLUENT | 1 | February 15, 2007 06:24 |
convergence problem with SIMPLER | NURAY KAYAKOL | Main CFD Forum | 1 | February 24, 1999 14:43 |
