Omar
Rep Power: 8 ![]() |
Hello Everyone,
I am currently working on a VAWT project, so far I have created a two bladed design by Pointwise and exported the files, I have managed to do checkMesh and it is OK. however, I could not run PimpleDyMFoam where errors message of Floating point exception (core dumped) occur as bellow, //************************************************** *****// Employing Ashford correction Reading/calculating face velocity Uf No finite volume options present Courant Number mean: 0.0201699 max: 31.9954 Starting time loop Courant Number mean: 0.0126062 max: 19.9971 deltaT = 0.000625 Time = 0.000625 solidBodyMotionFunctions::rotatingMotion::transfor mation(): Time = 0.000625 transformation: ((0 0 0) (0.999995 (0 0 0.00312499))) AMI: Creating addressing and weights between 118 source faces and 398 target faces AMI: Patch source sum(weights) min/max/average = 1.00008, 1.00014, 1.00012 AMI: Patch target sum(weights) min/max/average = 1, 1.00005, 1.00001 PIMPLE: iteration 1 #0 Foam::error: PrintStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib64/libc.so.6" #3 Foam::smoothSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #4 ? at ??:? #5 ? at ??:? #6 ? at ??:? #7 ? at ??:? #8 __libc_start_main in "/lib64/libc.so.6" #9 ? at ??:? Floating point exception (core dumped) //***********************************************// please could you let me know whats the problem here? Have a good day! ![]() |
Oskar
Rep Power: 10 ![]() |
Hello.
For now your Counrat Number is little too high. Try to decrease timestep to get max Cournat number close to 1-2. Sheaker. |
Omar
Hello Sheaker,
Thanks for your reply, I have induced the timestep for the Counrat value and made the maximum range around 1.6. However, still the same error is occuring and baring in mind that my mesh is ok. Could you have any other suggestions about the issue cause? Have a great day ![]() |
Omar
Hello Sheaker,
please could you check the attached file of '0' and 'system' to check if there are any issues ? Thanks |
Problem with interFoam; Wave/wiggle alpha1 behavior | JonW | OpenFOAM | 10 | February 4, 2023 07:27 |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 14:52 |
