chtMultiRegionFoam -- Problem Simulating a Channel
Like Tree2Likes
  • 2 Post By Bloerb
Old   May 30, 2018, 07:12
Unhappy chtMultiRegionFoam -- Problem Simulating a Channel
Anirudh Kulkarni
Tempest is on a distinguished road
Dear Foamers,
I am trying to simulate flow across a channel, which has an absorber plate in it (rough schematic attached). I have also atttached the case. Currently, I getting this error.
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2  ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3  Foam::heRhoThermo<Foam::rhoThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate() at ??:?
#4  Foam::rhoThermo::addfvMeshConstructorToTable<Foam::heRhoThermo<Foam::rhoThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > > >::New(Foam::fvMesh const&, Foam::word const&) at ??:?
#5  Foam::autoPtr<Foam::rhoThermo> Foam::basicThermo::New<Foam::rhoThermo>(Foam::fvMesh const&, Foam::word const&) at ??:?
#6  Foam::rhoThermo::New(Foam::fvMesh const&, Foam::word const&) at ??:?
#7  ? at ??:?
#8  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#9  ? at ??:?
Floating point exception (core dumped)
Please help me out with this issue.
Thanks.
Tempest is offline   Reply With Quote
Old   May 30, 2018, 07:46
Bloerb will become famous soon enough
Most of your boundary condtions are set up wrong. Your Allrun script does not call changeDictionary for one region, you have no fvSolution and fvSchemes in your region folders etc....
Attached is a cleaned up version. Might not work with your 2.1.x release. I recommend upgrading. Otherwise you should be able to tell which changes have been made.
wyldckat and Tempest like this.
Bloerb is offline   Reply With Quote
Old   May 30, 2018, 09:41
Anirudh Kulkarni
Thank you so much Bloerb. I apologise I had attached an older version of case file. I tried to run the case you attached. It is not running. Can you tell me what's missing. Again, thank you for replying.
It is giving error
--> FOAM FATAL ERROR:
cannot find file "/home/rudh/Desktop/SAH2/0/wall/p"
From function virtual Foam::autoPtr<Foam::ISstream> Foam::fileOperations::uncollatedFileOperation::rea dStream(Foam::regIOobject&, const Foam::fileName&, const Foam::word&, bool) const
in file global/fileOperations/uncollatedFileOperation/uncollatedFileOperation.C at line 505.
FOAM exiting
Old   May 30, 2018, 14:06
Anirudh Kulkarni
I have figured it out. Thankyou again Bleorb. In the new case that you have sent and my case the only difference was that I was not including the script to call changeDictionary. This issue I have resolved now. Thank you very much.
channel, chtmultiregionsimpefoam, collector, openfoam 2.0.x, solar
Problem simulating transient flow for iced conductor Alvise FLUENT 2 March 16, 2018 10:48
Problem with laminar 2d channel flow Quarkz Main CFD Forum 6 October 7, 2015 13:24
problem when simulating overflow at a sharp-crested weir Ya_Squall2010 OpenFOAM 2 January 9, 2013 18:26
Phase selection problem in open channel flow shoumo_30 FLUENT 1 December 1, 2011 03:48
Problem simulating wave propagation in a tube cKnoop OpenFOAM Running, Solving & CFD 6 August 22, 2011 16:28
