Outer Correctors Residual Control for PIMPLE algorithm
Like Tree4Likes
  • 4 Post By clapointe
Old   May 15, 2018, 03:17
Default Outer Correctors Residual Control for PIMPLE algorithm
Ed Barry
ed_bar is on a distinguished road
Hi All,
I have tried specifying in my fvSolution a subdict in PIMPLE controls called
nOuterCorrectorsResidualControl
As per lines 71-80 of
OpenFOAM-dev/src/finiteVolume/cfdTools/general/solutionControl/convergenceControl/singleRegionConvergenceControl/singleRegionConvergenceControl.C
        if (iter().isDict())
    FatalErrorInFunction  << "Solution convergence criteria specified in "
    << control_.algorithmName() << '.' << residualDict.dictName()
    << " must be given as single values. Corrector loop "
    << "convergence criteria, if appropriate, are specified as "
    << "dictionaries in " << control_.algorithmName()
    << ".<loopName>ResidualControl." << exit(FatalError);
I specify what I think this is asking for, yet when it comes to run time, it says that no corrector convergence criteria was found and the calculations will do n iterations. I have uploaded the case with the changed PIMPLE dictionary in system/fvSolution.
Any help would be appreciated.
Ed
ed_bar is offline   Reply With Quote
Old   June 4, 2018, 15:42
clapointe is on a distinguished road
You've almost got it -- try using outerCorrectorResidualControl for the name of the dict, as in this tutorial : https://github.com/OpenFOAM/OpenFOAM...tem/fvSolution.
Caelan
mechy, sinvastil, mnikku and 1 others like this.
clapointe is offline   Reply With Quote
Old   February 27, 2019, 04:26
Dongxu Wang
wdx_cfd is on a distinguished road
Caelan
Hi Caelan,
I am reading PIMPLE algorithm recently and I have some questions.
Firstly, I find that if we use the PIMPLE algorithm in OpenFOAM v6, the class which controls the residuals of outer loop will only be the "singleRegionCorrectorConvergenceControl". In other words, the subDict with the name of "outerCorrectorResidualControl" in "fvSolution.PIMPLE" is valid rather that the "residualControl" in the previous version. The "residualControl" will only be valid if we use SIMPLE algorithm. Am I right?
Secondly, I cannot understand how the words defined in the subDict work. For example, in the judgement function named "convergence.corrCriteriaSatisfied()":
bool Foam::singleRegionCorrectorConvergenceControl::
corrCriteriaSatisfied() const
    if (!hasCorrResidualControls())
        return false;
    bool achieved = true;
    bool checked = false; // ensure that some checks were actually performed
    if (control_.debug)
        Info<< control_.algorithmName() << ": Correction residuals" << endl;
    // Here I don't understand. What is this "mesh_.solverPerformanceDict()"?
    const dictionary& solverDict = mesh_.solverPerformanceDict();
    forAllConstIter(dictionary, solverDict, iter)
        const word& variableName = iter().keyword();
        const label fieldi =
            convergenceControl::residualControlIndex
                variableName,
                corrResidualControl_
        if (fieldi != -1)
            scalar firstResidual, residual;
            convergenceControl::getInitialResiduals
                mesh_,
                variableName,
                corrResidualControl_[fieldi].solveIndex,
                iter().stream(),
                firstResidual,
                residual
            const scalar relativeResidual =
                residual/(firstResidual + ROOTVSMALL);
            const bool absCheck =
                residual < corrResidualControl_[fieldi].absTol;
            const bool relCheck =
                relativeResidual < corrResidualControl_[fieldi].relTol;
            checked = true;
            achieved = achieved && (absCheck || relCheck);
            if (control_.debug)
                Info<< control_.algorithmSpace() << "  " << variableName
                    << ": tolerance " << residual << " ("
                    << corrResidualControl_[fieldi].absTol << ")"
                    << ", relTol " << relativeResidual << " ("
                    << corrResidualControl_[fieldi].relTol << ")"
                    << (absCheck || relCheck ? " CONVERGED" : "") << endl;
    return checked && achieved;
There is a dictionary with the name of "solverDict". I print this object during the run time and I get the information just like this:
    pcorr             ;
    p_rgh            ;
There are only two words in this dictionary. In other words, no matter what I put in the sub dictionary, the only valid words are "p_rgh" and "pcorr". Therefore, if we put the subDict like this:
PIMPLE
    // other words
    // subDict in OF v6 for residual control
        p_rgh   // valid
            tolerance    1e-8;
            relTol          1e-6;
       U          // invalid
            tolerance    1e-8;
            relTol          1e-6;
U will be invalid at the moment of residual judgement. This makes me confused and I don't know if there is something wrong in my understanding.
Any suggestion will be appreciated.
Thank you very much!
wdx
wdx_cfd is offline   Reply With Quote
Old   February 27, 2019, 12:07
Not too much time to go into this, but lets see...
You are right about outerCorrector... vs residualControl -- at least from memory. I hardly use any of the SIMPLE algorithms, but this sounds right.
As for the dictionary question, it looks like a series of dictionaries are stored (as a list? someone can be more technically correct here, I'm sure) in solverDict, which we then loop through. I am not sure what you are printing (or from where), so I cannot answer that question. However, if you check out the tutorial I linked to previously you'll see that a series of fields are checked -- take a look at the tutorial to see how.
Caelan
Old   February 27, 2019, 21:58
Dongxu Wang
Caelan
Hi Caelan,
Thank you for your reply! According to your advice, I think I have totally understood how this function works. I will try my best to depict it clearly and I hope one day it maybe useful for someone else.
Firstly, my print function is added as:
	// newly added to print the solverDict
        Info << "solverDict  = " << solverDict << endl;
                variableName,
In my previous understanding, the solverDict should be a list which consists of subDicts read from fvSolution. However, I find that the content in solverDict may be constant for a specific solver. And the the subDicts read from the PIMPLE dict will try to match these content for residual judgement. In the function I list above, the word "variableName" stands for the constant content and the lable "fieldi" represents if the subDict read from fvSolution matches the content (0 means yes, -1 means no).
When using interFOAM, the solverDict is read as:
solverDict  =
    pcorr           1 ( ( GAMGPCG pcorr 1 1.12278473072e-09 9 1 ( 0 ) ) );
    p_rgh           2 ( ( GAMG p_rgh 1 0.00354306144809 1 1 ( 0 ) ) ( GAMGPCG p_rgh 0.0151588085227 2.81533804904e-09 5 1 ( 0 ) ) );
In your case mentioned above, the solverDict is read as:
solverDict  =
    U               1 ( ( smoothSolver U ( 1 1 1 ) ( 0.076108 0.0914346 0.059271 ) ( 5 4 5 ) 0 3 { 0 } ) );
    e               1 ( ( smoothSolver e 1 0.0730702 2 1 ( 0 ) ) );
    p               1 ( ( DICPCG p 1 9.44311e-08 115 1 ( 0 ) ) );
    rho             1 ( ( diagonal rho 0 0 0 1 ( 0 ) ) );
    epsilon         1 ( ( smoothSolver epsilon 0.983447 0.0191881 2 1 ( 0 ) ) );
    k               1 ( ( smoothSolver k 1 0.00447597 1 1 ( 0 ) ) );
In other words, for my case only p_rgh and pcorr are valid. Other variables, if presented, should have a -1 fieldi value, which means they are not used for residual judgement.
wdx
Problem with chtMultiregionFoam radiation boundary condition baran_foam OpenFOAM Running, Solving & CFD 10 December 17, 2019 18:36
Suppress twoPhaseEulerFoam energy AlmostSurelyRob OpenFOAM Running, Solving & CFD 33 September 25, 2018 18:45
Compressor Simulation using rhoPimpleDyMFoam Jetfire OpenFOAM Running, Solving & CFD 107 December 9, 2014 14:38
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 14:12
calculation stops after few time steps sivakumar OpenFOAM Running, Solving & CFD 7 March 17, 2013 07:37
