Constant mass flow rate in channel flow LES
Like Tree1Likes
  • 1 Post By RobertHB
Old   May 10, 2018, 03:29
Default Constant mass flow rate in channel flow LES
Vishwesh Ravi Shrimali
vishwesh is on a distinguished road
Hi!
I am trying to simulate channel flow simulation in OpenFOAM for constant mass flow rate. I found a test case for channel flow which uses a
momentumSource
in
fvOptions
file:
momentumSource
    type            pressureGradientExplicitSource;
    active          on;            //on/off switch
    selectionMode   all;       //cellSet // points //cellZone
    pressureGradientExplicitSourceCoeffs
        fieldNames  (U);
        Ubar        ( 0.1335 0 0 );
How can we use constant mass flow rate in Channel flow case? The test case can be found here.
Thanks in advance
Vishwesh
vishwesh is offline   Reply With Quote
Old   May 10, 2018, 04:12
Robert
RobertHB is on a distinguished road
Originally Posted by vishwesh View Post
Hi!
momentumSource
in
fvOptions
file:
momentumSource
        fieldNames  (U);
Thanks in advance
Vishwesh
Why not use the fvOptions entry you've found?
If you liked my answer to your question, please consider leaving a "Like" in return
RobertHB is offline   Reply With Quote
Old   May 10, 2018, 04:15
I actually want to make changes in the geometry and see the affect it has on the wallShearStress and I thought it would be easier to use constant mass flow rate for the analysis rather than the constant pressure.
Old   May 10, 2018, 04:30
Robert
Ah okay. You can take a look at the other possible fvOptions entries. Maybe you find something you can use. Possible sources are explained on this website: http://www.geocities.jp/penguinitis2...fvOptions.html
Just use google chrome or google translate on the website
vishwesh likes this.
Old   May 10, 2018, 10:10
Santiago Lopez Castano
Santiago is on a distinguished road
Although a bit incidental to the discussion, I'm curious to know how does using a constant mass fliw rate make the analysis easier? I mean, i would expect that by virtue of Newton's second law it'd be easier to analyse and balance shear stress with pressure gradients
Santiago is offline   Reply With Quote
channel flow, constant mass flow, openfoam 3.0.x
Mass flow rate boundary condition with negative values hebe2u. CFX 1 December 27, 2016 04:53
Shape Optimization Problem of Mass Flow Rate ggc1991 SU2 Shape Design 1 December 1, 2016 21:24
Mass flow rate boundary condition with negative values ashtonJ CFX 3 November 26, 2014 06:21
Wrong Pressure countors for channel flow driven by mass flow rate or press gradient ash-khan FLUENT 0 June 21, 2009 11:02
Constant mass flow rate / choking outlet bounardy condition Min Zhu Main CFD Forum 1 September 29, 1998 16:33
