Radiation model fvDoM get huge radiative heat flux
Like Tree1Likes
  • 1 Post By fxzf
Old   April 23, 2018, 11:28
Default Radiation model fvDoM get huge radiative heat flux
ff
fxzf is on a distinguished road
I am doing conjugate heat transfer using chtMultiRegionSimpleFOAM. If I switch off radiation model, everything is ok. But I need to result with radiation model since the temperature difference is a bit large 300 ~ 1500K.
Now, the problem is there is always a small area that radiation model get huge positive or negative radiative heat flux (+/-1E+14) level, then I will got a very large temperature or very small negative temperature, which then crash simulation. The problem is there are some bad cells, but I cannot get better mesh since geometry is very complex.
I want to ask if there is a way to bound fvDoM radiation model or other tricks to apply to improve stability of the fvDoM radiation model?
Thanks a lot.
derekm likes this.
fxzf is offline   Reply With Quote
strange extreme low radiation heat flux on fixed Temperature surface fxzf OpenFOAM Running, Solving & CFD 0 March 7, 2018 17:09
Solver refuses to run: Monte Carlo Radiation Model Zaphod'sSecondHead CFX 9 February 14, 2017 10:20
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
GETVAR Error in Multiband Monte Carlo Radiation Simulation with Directional Source silvan CFX 3 June 16, 2014 10:49
