Boundary Condition for Variable Velocity
Like Tree1Likes
  • 1 Post By Taataa
Old   April 18, 2018, 15:34
Default Boundary Condition for Variable Velocity
Hyllon is on a distinguished road
Hello, I'm new to OF. I'm running an axi-symmetric case. It's just a pipe.
Geometry: https://imgur.com/a/YsK1o
The problem is: The velocity varies according to an equation.
This is the equation: https://imgur.com/a/8jDCc
The ONLY variable is ' r ', which is the distance between the center of the tube and any cell in y direction.
I need a boundary condition for that. Any help is appreciated.
Sorry for bad english.
Hyllon is offline   Reply With Quote
Old   April 19, 2018, 05:17
Robert
RobertHB is on a distinguished road
You might take a look at the codedFixedValue boundary conditon or the vectorCodedSource entry for the fvOptions dictionary. But i haven't work with any of those and can't tell you if it will work or not.
RobertHB is offline   Reply With Quote
Old   April 19, 2018, 05:20
Hosein
einstein_zee is on a distinguished road
Hey,
A subtle way is discussed here. "https://www.youtube.com/watch?v=K-nAF3qAPTc"
einstein_zee is offline   Reply With Quote
Old   April 19, 2018, 13:22
Taher Chegini
Taataa is on a distinguished road
Here is the code that you can put in U file:
inlet
        type            codedFixedValue;
        value           uniform (0 0 0);
        redirectType    parabolaProfile;
        code
            const fvPatch& boundaryPatch = patch();
            const vectorField& Cf = boundaryPatch.Cf();
            vectorField& field = *this;
            scalar Ut = 1;
            scalar C  = 1;
            scalar R0 = 1;
            scalar nu = 1;
            scalar n  = 1;
            scalar vel;
            forAll(Cf, faceI)
                scalar dis = Cf[faceI].y() < R0 ? Cf[faceI].y() : Cf[faceI].y() - R0;
                vel = Ut*C*pow(dis*Ut/nu, n);
                field[faceI] = vector(vel, 0, 0);
Change the variables based on your dimensions. Keep it mind that I assumed that your equation is written considering the origin is at the center of the pipe but you mesh origin is at the bottom of the pipe. If the mesh origin matches the origin of the equation you use the original form of the equation which changes is straight forward.
Rvadrabade likes this.
Taataa is offline   Reply With Quote
Old   April 19, 2018, 13:47
Thanks so much for your help, guys. Im gonna take a look.
Old   April 20, 2018, 03:11
Default Another option is to use swak4foam/groovyBC
Rahul Vadrabade
Rvadrabade is on a distinguished road
This is very interesting implementation.
If you are familiar with swak4foam/groovyBC ( if not i recommend you/Everyone must learn) .
I am assuming that flow direction is x and radial is y.
Just look at implementation, images are attached.
One can correct mistakes if any.
All the best.
(If swak4foam not compiled, then ask)
Rvadrabade is offline   Reply With Quote
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
Out File does not show Imbalance in % Mmaragann CFX 5 January 20, 2017 11:20
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
CFX fails to calculate a diffuser pipe flow shenying0710 CFX 7 March 26, 2013 05:13
Velocity inlet boundary condition for porous medium Chander CFX 3 March 11, 2012 22:18
