April 13, 2018, 04:40 |
Negative alpha.water value in interFoam
Vivekananda
Rep Power: 9 |
Hello all,
I am simulating a pulse column case in interFoam. While solving I am getting negative alpha value in the calculations ..but that is too small ..it is in the order of e-12. Is it an error? This is the following message I am getting PIMPLE: iteration 1 smoothSolver: Solving for alpha.water, Initial residual = 0.00162047, Final residual = 1.25822e-09, No Iterations 3 Phase-1 volume fraction = 0.647771 Min(alpha.water) = -1.27725e-08 Max(alpha.water) = 1 MULES: Correcting alpha.water MULES: Correcting alpha.water Phase-1 volume fraction = 0.647771 Min(alpha.water) = -6.51804e-06 Max(alpha.water) = 1.00001 DICPCG: Solving for p_rgh, Initial residual = 0.0278935, Final residual = 0.00110561, No Iterations 2 time step continuity errors : sum local = 5.69383e-05, global = -6.09452e-09, cumulative = -6.0192e-07 DICPCG: Solving for p_rgh, Initial residual = 0.00119511, Final residual = 5.10015e-05, No Iterations 9 time step continuity errors : sum local = 2.62867e-06, global = -9.61851e-10, cumulative = -6.02881e-07 DICPCG: Solving for p_rgh, Initial residual = 0.000109429, Final residual = 9.72348e-08, No Iterations 420 time step continuity errors : sum local = 5.01138e-09, global = -2.42982e-11, cumulative = -6.02906e-07 ExecutionTime = 3239.45 s ClockTime = 3445 s Any kind of help will be appreciated.... |
April 13, 2018, 05:44 |
Rep Power: 8 |
Hello snihavivekananda318,
By experience, it is only some numerical fluctuations during your simulation. As long as your minimum value stays around e-6 it is not an error to me. If you want to reduce it you should reduce the tolerance in the fvSolution file. Cheers |
April 13, 2018, 07:09 |
Vivekananda
Rep Power: 9 |
actually I was thinking that being a physical quantity the value alpha should be between 0 to 1..negative value would be unphysical..but I am getting negative value of alpha..though it is very very small but still it is negative..that is why this doubt is here...if you could clarify pls....
April 13, 2018, 11:24 |
Taher Chegini
Rep Power: 12 |
Generally, you should use a bounded scheme for alpha (usually vanLeer for (phi,alpha) and interfaceCompression for (phirb,alpha). Also if you're NOT using MULES you can use vanLeer01.
Anyhow, in your case it doesn't seems to an issue. |
November 20, 2018, 13:28 |
Rep Power: 8 |
Hi Taher,
Can you elaborate on why you can't use vanLeer01 with MULES? Thanks. Mimi |
November 20, 2018, 13:54 |
Taher Chegini
Rep Power: 12 |
because MULES iteself takes care of under- and over-shoots and you don't want to over smooth the solution.
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
negative min.(alpha1) value interFoam | Arjun Jayakumar | OpenFOAM | 11 | December 21, 2019 10:59 |
Free surface issues with interDyMFoam for hydroturbine | oumnion | OpenFOAM Running, Solving & CFD | 0 | October 6, 2017 14:05 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
