Oscillatory Issues with 2nd Order Schemes |
Pi-Man
Rep Power: 8 ![]() |
Dear Fellow CFD Enthusiasts,
I am currently attempting a mesh independence study on a simple 2D rectangular channel. I am using a modified icoFoam application that solves the transport of a passive tracer at every time step. My issue is, is that I have realized how diffusive the first order divergence schemes can be (thus requiring extreme mesh refinement), and so I am trying my mesh independence study using 2nd order accurate differential operators. However, it seems that my simulation's performance indicator (some mixing coefficient calculated) shows unrealistic oscillatory behavior when attempting simulations using these 2nd order operators. Please find attached an image that shows some of the case tests I have run, and screenshots of the fvSchemes and fvSolution used on Test 5. Test 1, Test 2 and Test 3 have their mesh sizes refined and they are using 1st order operators. Test 4 is the same as Test 3 but has a smaller time step. Test 5 uses the same mesh and time step as Test 3 but is using 2nd order accurate differential operators. I am sure the behavior is unphysical in Test 5 because of the extremely steep time responses and the negative values along the ordinate. Any advice on how to use these 2nd order operators and yield stable results would be highly appreciated. Best, Kris |
Pi-Man
By the way, the value "mu" as seen on the graph's ordinate displays some inherent oscillatory behavior that should be differentiated from the numerical oscillations. This inherent behavior is due to my choice of inlet boundary conditions (necessary to my study).
Alireza Maleki
Rep Power: 9 ![]() |
yep. i have this problem to. but not at mesh independence study.as you can see there are some waveLike oscillation in my domain. i need to eliminate them but i dont know exactly why i have them in my simulation. my guess is, they are due my second order scheme but i dont know how eliminate them
![]() any tip would be appreciated. |
Pi-Man
Dear Ali,
I actually solved this problem ![]() The issue is most definitely with the 2nd order schemes being used. I'm not sure what type of physics you're simulating, but make sure the scheme chosen is non-oscillatory. I bounded my solvers and it removed all the ugly and strong oscillations in the problem. If you would like some more details, let me know. Best, K |
Alireza Maleki
thank you for your fast replay. actually i'm working on a step simulation as the picture. i have this wavelike as you see and i want eliminate them. my guess is that they are due the second order scheme, because they are oscillating.
you said that " I bounded my solvers . . . " how exactly did you do that? as you see my scheme are linear. what do you recommend ? Last edited by alireza94; June 12, 2018 at 03:55. |
Pi-Man
I'm honestly not quite sure what is causing your pressure waves because I don't know what exactly you're doing, but maybe you should try more stable schemes. You should definitely test out multiple schemes, and check the change in the strength of these oscillations USING GRAPHS and not a paraview snapshot.
Check out the solvers I used for my problem, maybe they can help you start with the testing. |
Alireza Maleki
thank you for your scheme.
![]() i will give it a shot, and search more on the internet ![]() |
Pi-Man
Best of luck Ali,
Just make sure as well that the waves aren't part of the actual physics involved ![]() Peace, K |
#9 | |
Arjun
Rep Power: 34 ![]() ![]() |
this is an example of checkerboarding. If you run the same thing with refined mesh you are unlikely to see it. So try it out. If you don't see the issue on refined mesh then it was checkerboarding due to lack of pressure velocity de-coupling. |
#10 | |
Alireza Maleki
moreover my professor got good result with fluent and I wanna get those in openfoam, additionally I got probe pressure too. a probe at cavity shows steady oscillation completely , the things that before was gatten in fluent. but I got some noise behiver too at my probe pressure, that's problem |
#11 | |
Hosein
Rep Power: 14 ![]() |
Just for curiosity, have you tried the same simulation (with 2nd order schemes) but with Euler for time instead of CN 0.9 ? was the behaviour again oscillatory? |
#12 | |
Arjun
Yaa you are right it could be something else too. I overlooked the fact that you said that second order calculation has this issues. PS: Fluent is different solver though, so there might be other reasons to this issue. I hope someone more knowledgeable of openfoams helps you out here. |
#13 | |
Alireza Maleki
Attachment 63958Attachment 63958
i,m not completely sure about the reason but second order is my best guess. and this is my probe output. actually i need to eliminate this kind of noise behavior in my solution. |
#14 |
Pi-Man
Dear Ali,
I strongly suggest you run a test with different solvers, and with different mesh sizes. Have you tried running first order schemes? They're usually diffusive and very stable. Next you can start testing different types of available schemes. Also try to run at least two different mesh sizes for this problem, and check to see whether there is a significant difference in the noise produced. Best, K |
#15 |
Santiago Lopez Castano
Rep Power: 15 ![]() |
Your case, as described, seems too simple to require all the rather "complex" schemes you're using. The first thing to note is that the "gauss linear orthogonal" scheme assumes your grid to be orthonormal. Meaning that mesh is uniform and orthogonal. The wiggles you see are a clear sign that the interpolation schemes are failing to accurately collocate the controvariant fluxes to the faces of the mesh. The discretization of the convective term is secondary here, compared to the LAPLACIAN.
#16 |
Pi-Man
Dear Einstein,
I have thoroughly tested this problem of mine as I am attempting to write a research paper on the subject. The issue turned out to be coming from the high Peclet numbers in the system, and that not all the solvers I was trying were "numerically incompatible" with my system. Some solvers gave me such large gradients in my field "c" (the scalar field being simulated) that they would result in negative scalar magnitudes, which was completely nonphysical. This ended up translating into an extremely noisy "mu" behavior (as can be seen in my original images. It had nothing to do with my time scheme (as far as I can tell). Best, K |
#17 | |
Alireza Maleki
dear Santiago what do you suggest for my situation? my mesh is completely orthogonal so can i use "Gauss linear orthogonal" and "orthogonal"?? do you think the noise behavior is due the schemes or something else? |
#18 |
You are solving a compressible flow, maybe an entropy preserving scheme would better serve your needs. Anyway, im not an expert in hllc or roe schemes.
#19 |
Alireza Maleki
just for the record:
after changing most of the scheme in fvscheme i noticed that by changing div(phi,U) linear; to div(phi,U) linearUpwind grad(U) the problem will solve and the noise behavior vanish completely. ![]() ![]() |
accuracy, divergence schemes, mesh independency |
kEpsilon and RNGkEpsilon not converging with second order schemes | alpha23 | OpenFOAM Running, Solving & CFD | 1 | September 2, 2015 10:47 |
2nd order upwind vs 2nd order upwind!!! | Far | Main CFD Forum | 7 | March 14, 2013 12:29 |
hypersonic HLLC/AUSM 2nd order | melrose | SU2 | 1 | January 31, 2013 00:22 |
first and second order schemes | Thomashoffmann | Main CFD Forum | 3 | January 22, 2013 07:50 |
2nd order (convection) schemes | Ford Prefect | Main CFD Forum | 5 | January 18, 2012 06:38 |
