How to applying surface roughness in Openfoam damBreak?
Like Tree7Likes
  • 5 Post By Phicau
  • 1 Post By Phicau
  • 1 Post By mAlletto
Old   April 4, 2018, 20:50
Question How to applying surface roughness in Openfoam damBreak?
Jesse Cheung
kcc49 is on a distinguished road
Hello, I am a new OpenFOAM user and currently working on how the effect of surface roughness affecting the impact introduced by dam break.
As a result, I am building a model through using the damBreak in OpenFoam Tutorial. Is there any way to introduce surface roughness into damBreak?
sincerely,
Jesse
kcc49 is offline   Reply With Quote
Old   April 4, 2018, 21:49
Pablo Higuera
Phicau is on a distinguished road
Hi Jesse,
you need to run the case with a turbulence model and specify nutkRoughWallFunction for nut.
Ks is the equivalent grain roughness (Nikuradse) and Cs is a roughness constant, check the details here: https://cpp.openfoam.org/v3/a01666.html#details
All this is put into play in the damBreakWithObstacle tutorial.
Best,
Pablo
burbur, aow, oumnion and 2 others like this.
Check out my new project: olaFlow --> The olaFlow Support Thread
Phicau is offline   Reply With Quote
Old   April 4, 2018, 22:44
Jesse Cheung
Originally Posted by Phicau View Post
Hi Jesse,
Best,
Pablo
thanks Pablo for your response!
However, I still not quite sure how to run the case with a turbulence model and specify nutkRoughWallFunction for nut.
Do you mind elaborate more?
Many thanks!
Jesse
Old   April 5, 2018, 07:01
Jesse Cheung
Hi Jesse,
Best,
Pablo
Hello Pablo,
Does it mean all I need to do is to change the value of Ks and Cs (in bold text) nut file in file 0 in order to control the surface roughness?
boundaryField
atmosphere
type zeroGradient;
walls
type nutkRoughWallFunction;
Ks uniform 100e-6;
Cs uniform 0.5;
value $internalField;
Old   April 5, 2018, 07:19
Pablo Higuera
Exactly, select the appropriate values for your case and check damBreakWithObstacle tutorial if you can't make it work at first.
Pablo
kcc49 likes this.
Old   April 5, 2018, 07:22
Jesse Cheung
Many thanks for your help!
Old   April 5, 2018, 09:41
Jesse Cheung
Pablo
I have another question for building up the case
int the nut file, do i need to include those 'faces' as zeroGradient? see the following quote
atmosphere
type zeroGradient;
wall
type zeroGradient;
structure
type zeroGradient;
slope
Ks uniform 0.05;
Cs uniform 1;
side
type empty;
Old   December 19, 2018, 17:19
Nicola D'Ettole
ing.nicola.dettole is on a distinguished road
For velocity , pressure, k, epslion i have to use rough functions ?
ing.nicola.dettole is offline   Reply With Quote
Old   January 16, 2020, 19:15
Nic86 is on a distinguished road
Hello. The nutkRoughWallFunction requires 3 entries:
Ks
Cs
value
What does it mean "value"?
For example In the dam break with obstacle tutorial the entries are:
Ks uniform 0.0001;
Cs uniform 0.5;
value uniform 5e-07;
What does it mean value uniform 5e-07?
Also what does
means?
Sorry for the stupid question but I cannot find valid documentation.
Thank you.
Nic86 is offline   Reply With Quote
Old   January 19, 2020, 09:18
Michael Alletto
mAlletto will become famous soon enough
I'm not sure if the value is really required. It is written to the file since the nutwallfunctions are derived from the fidedValue boundary condition.
mAlletto is offline   Reply With Quote
Old   January 20, 2020, 02:08
I am quite sure that a value is needed because if i delete that line the code does not run and gives me error. It could be that the value is uninfluential when using the nutkwallfunctions but how can i be sure about it? Where can i find official reference about this function??
Thank you
Old   January 20, 2020, 05:36
Michael Alletto
You find some reference here:
https://www.openfoam.com/documentati...8H_source.html
https://www.openfoam.com/documentati...8C_source.html
some good explanation about wall functions in general (read the chapter standard wall function):
http://www.tfd.chalmers.se/~lada/pos..._report_WF.pdf
wall functions in openfaom
http://www.tfd.chalmers.se/~hani/kur...nfoamFinal.pdf
Unfortunately the nutkroughwallfunction is not described. But the only difference to the nutkwallfunction is the assumed velocity profile in the first cell adjacent to the wall.
Hope this helps
Best
Michael
frantov likes this.
Old   January 22, 2020, 00:01
Excellent! Thank you!
Old   October 13, 2020, 06:14
Red face
  #14
Feng
wind_ is on a distinguished road
Hi Jesse,
Best,
Pablo
Do it need other Rough wall functions? such as nutURoughWallFunction
wind_ is offline   Reply With Quote
dambreak, openfoam, roughness, surface
[ANSYS Meshing] generation mesh for simulation surface roughness in fluent kamyarmech ANSYS Meshing & Geometry 2 February 29, 2016 14:09
simulation of effect surface roughness on aifoil kamyarmech FLUENT 1 February 28, 2016 10:33
Simulation of surface roughness in fluent sagarmore FLUENT 3 January 12, 2016 15:55
Using Surface Roughness to Approximate Dimple Surface Fang54 Main CFD Forum 1 January 8, 2016 10:40
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 07:25
