simpleFoam - validating Drag Coefficient of thin plate |
Eduardo Firvida
Rep Power: 15 ![]() |
Hi, in the follow image I show my case setup, the main idea is to get the Cd of well documented shapes, starting by the thin plate.
![]() To do this i´m using simpleFoam, I upload my case setup too. The simulation runs without problem but I can´t never reach the Cd=1.9 for Re > 10e4 as the reference value. it always give me Cd > 3. So i´m not sure about what i´m doing wrong. |
Uwe Pilz
You cannot expect a correct result if you run this high Re numbers with a laminar solver. Even with advanced turbulence modesl it is hard to get an deviation as low as 20%. It is nearly impossible to confirm the drag crisis at even higer Re numbers.
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
#3 | |
Eduardo Firvida
Now I have a problem, I have same case, but I change the plate, with a square cylinder, of 1m*1m of size. When I use the case configuration, I get Cd from 1.6 to 1.8 and the reference value must be from 2.1 to 2.3 so the prediction its not good. And I dont understand why, If my case was correct for the previous geometry, rigth now I only change the width of the plate to be equal to the heigth. But now think as i know if the relation of heigth/width increase the Cd have to decrees, its not a rule but that what I know and what my simulation say. but the books says other thing. Well... I made another test changing the solver to pimpleFoam to made the case transient, and with this I get the 2.2 average value of the Cd. But if I use pimpleFoam in the thin plate, I get a Cd, over 4. So I dont have a clue of how to set a basic case to this kind of geometries to get the referenced values of the Cd. |
Andrei Cojocea
Rep Power: 7 ![]() |
I saw your post and I was wondering if you still have the files and you can upload them here. I am trying to solve a 2D incompressible flow past a square cylinder and I cannot get the right solution, after the vorteces start shedding. Maybe I can get some insight with the problem. |
Calculation of lift and drag coefficients on airfoil | CoolHersheys | OpenFOAM Post-Processing | 5 | September 27, 2021 06:04 |
Drag coefficient CEL expression | sarrazs | CFX | 2 | September 28, 2017 10:21 |
Problem: calculating drag coefficient | RFH_student | FLUENT | 3 | February 8, 2011 08:36 |
Plot drag coefficient against Y(distance) | edwin | FLUENT | 0 | February 4, 2008 09:41 |
Drag coefficient Oscillating plate | Anant | Main CFD Forum | 0 | September 6, 2001 10:31 |
